Question about Panasonic PV-D4732 DVD Player / VCR Combo
I put a CD with photos into the DVD, and the screen tells me the disc needs cleaning or is scratched. The disc is clean and has no scratches.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems that the lens is unable to read discs or is dirty. To start with try running a lens cleaning disc, if that does not work then you have to open the unit and clean the lens with a Q-tip dipped in alcohol. If still the issue is not resolved then the lens should be replaced however, replacing a lens will cost you around $75 and a new one will cost you around $50. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 02, 2010
  • gbarker3x52 Aug 02, 2010
    The DVD unit has no problem reading DVD's, only CD's.??
Philips DVD 724 doesn't read disc. When put disc in, dvd players says no disc
Does the disc have a lot of scratches on the surface? Even the smallest scratch can make your disc unaccessable. Try a clean disc and see if the problem repeats itself. If it does, then the problem might be that the laser in your DVD is dirty, and needs to be cleaned. This can be done with a cd drive cleaner kit, which should be available at just about any electronics/gaming store.
Otherwise it might need a bit of a checkup from your local tech repair shop.
Hope that helps.
Cheers from NZ
May 24, 2011 | Video Game Consoles & Games
I have plastic cover migration to my CD's. Slight problem is removed by alcohol; but some discs will not clean, and the disc is not readable. Help.
Try cleaning CDs under tap water and dry them thoroughly with a soft cloth. May seem weird, but this often clean the CD better tan alcohol.
Ensure CD have no paper label on top before washing them.
Sep 13, 2008 | Audio Players & Recorders
Crc on almost every DVD
A CRC error is a data check - cyclic redundancy check,
Either the DVD discs are dirty or scratched OR the DVD drive needs the laser lens cleaned OR the DVD drive is faulty.
If the DVD discs are scratched you may be able to polish out the scratches with a CD scratch removal kit.
Try cleaning the DVD drive with a CD drive cleaning kit to clean the laser lens.
If none of this works the the DVD drive is faulty and needs to be replaced.
May 17, 2011 | Computers & Internet
Navigation not working get disk reading error message upon starting car and every few minutes afterward
Check for a scratched or dirty Navi DVD disc. Clean or have the scratches polish out at your local game store. Video game stores usually have a disc repair machine that polishes out scratches.
Note: In some cases the Navi unit can cause rotational scratches on the DVD. If this is the case than the Navi unit will have to be replaced.
Oct 05, 2010 | 2003 Honda Accord
Fifa 09 football problem. telling me to clean disc as it is unreadable i am cleaning the disc and restarting the console but it keeps telling me to clean the disc.
One common problem that video game players have all the time are scratched discs. A helpful way around buying a brand new game or a disc scratch remover, is to first:
a.) Borrow the same version of the game from a friend
OR
b.) Rent the same version of the game from a store
Now, take the unscratched disc, and install it to your hard drive.
And lastly, now you can put in the scratched disc and go to "Game Library", choose the game, and select "Play from Hard drive."
The reason this trick works, is because when you play your disc from the hard drive, it uses minimal memory from the disc itself.
NOTE: Installing a disc to your hard drive does NOT replace having to put in the game to play it.
You still need a copy of the game in order to run it from your hard drive. I believe this is some security feature so people don't go around copying the games and not buying them.
Also, I would NOT install the scratched disc to your hard drive, for this will not help your problem at all.
Jan 23, 2010 | EA Sports Video Game Consoles & Games
DVD player won't read discs
hi Carlos.
How do you clean a DVD player? CD and DVD players have a laser lens that needs to be cleaned periodically. To maintain your DVD player, occasionally unscrew the player's case, so you can get at the lens to clean it. You need a screwdriver, canned air or a soft brush, a foam swab or camera-lens cleaner, and lens cleaning fluid from a camera store.
How to Maintain Your DVD Player - dummies
www.dummies.com/home-garden/home.../how-to-maintain-your-dvd-player/ Search for: How do you clean a DVD player?
Don't blame your CD or DVD player every time your music or favorite movie starts skipping or refuses to play. The disc may be dirty or scratched. You can purchase a cleaning kit at an electronics store, but rubbing alcohol is a lot cheaper and you can get it at the grocery store or pharmacy. If the problem is dirt or dust, here are some tips for keeping your discs in top condition:
  • When you select a disc to play, the first thing you should do - every single time - is blow dust off, even if you faithfully keep your discs in their sleeves.
  • Next, wipe your discs with a lint-free cloth dampened slightly in rubbing alcohol every time you use them. They not only accumulate dust, but also oily fingerprints that make dust stick.
  • Put your fingers only on the edge and through the center hole.
And if your favorite disc is scratched, before throwing it out, try polishing it to remove the scratch. Disc repair kits are sold at electronics stores and some video stores.
Nov 26, 2017 | Sony DVP-NC85H Multi-disc DVD Player
When i put a dvd in the dvd player it just comes on screen saying theres no disc
Try cleaning the lens with a CD/DVD cleaning kit that you can buy at a local eletronics store. If you have tech skills, open the player up and clean the glass eye reader lens with some rubbing alcohol using a Q-tip. Make sure the DVD you are using is not too scratched up. If it still don't work after you cleaned it and tried different disc then replace the optical reader drive
Nov 04, 2009 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
I put DVD disc but it read as CD disc
try to clean the DVD-ROM with Cd cleaner also try to check if the DVD back is clear (not scratched)
Jun 29, 2009 | ASUS Computers & Internet
Dell Studio 1537 DVD not working
1. clean your cd, then put
2. clean your cd/dvd head
3. scratch cd/dvd shows this type of message
Jun 28, 2009 | Dell Studio 1537 Laptop
Skips or won't play disc if even slightly scratched
Hello opie440,
The optics might be dirty or the pickup assembly might need alignment. In the former case you can get an optics cleaning kit and try to clean the laser LED and pickup assembly. For the latter cause you will need to have thre unit aligned at a TV repair shop.
Feb 18, 2008 | Sony DVP-S530D DVD Player
Panasonic PV-D4732 DVD Player / VCR Combo Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
