Question about Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
MY BOSCH 590EVS JIG SAW WORKED GREAT FOR ABOUT A MONTH BUT NOW WHEN I'M TRYING TO CUT WITH IT , IT SLOWS DOWN TO A CRAWL THEN SPEEDS UP THEN SLOWS AGAIN, MAKING HARD TO USE. WHAT CAN I DO TO FIX THIS?
Sounds like the brushes have worn down.
Posted on Mar 30, 2015
  • 700 Answers
Seem like electrical problem, this is new model and should be still under warranty, i would suggest return it to place of purchase and replace/repair
Posted on Aug 02, 2010
  • tgrove60 Aug 31, 2010
    the electronic switch is failing i have read on other forums about this problem and i have gone through 2 in less than 2 years, they cost about £8 if out of warranty but this tool has been a dissapointment but i have at least 15 other bosch tools mostly blue proffesional and rate them first class tools
I need a blade clamp for a model 105112 Mastercraft jig saw. Is there a substitute or universal clamp that fits?
Jig Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/jig-saw.html
  1. Cached
  2. Similar
Shop online for jig saw replacement parts for fourteen of the world's most trusted brands at Tool Parts Direct. We have the largest online inventory of Bosch jigsaw parts, Dewalt jigsaw parts, Black and Decker jigsaw parts, as well as replacement parts from other top manufacturers ...
mastercraft jig saw model 105112 Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags
  1. Cached
  2. Similar
Find solutions to your mastercraft jig saw model 105112 question. ... i need a parts list for a mastercraft jigsaw/sabre saw model 105-106 See this webpage: ...
Craftsman Jig Saw Parts ' Great Selection ' Great Prices ...
www.ereplacementparts.com/craftsman-jig-saw-parts-c-158286_171667.html
  1. Cached
  2. Similar
Repair Parts Home Power Tool Parts Craftsman Parts Craftsman Jig Saw Parts. ... 07021 Craftsman Sabre Saw Parts. ... 315171600 Craftsman Sabre Saw 1/2 Inch Stroke Variable Speed Parts. 105112 Mastercraft jig saw Google Search
Nov 23, 2016 | Saws
My Bosch jigsaw suddenly seems to run too slowly. It just doesn't cut as agressively as when new, and seems to turn less rpm. what's going on with it?
This may seem dumb but did you accidentely turn the variable speed dial on the trigger down? Not sure which model you have but that is the most common problem that comes into my shop with certain models.
Dec 17, 2012 | Bosch Saws
Bosch 2604320913 Carbon-Brush Set
No If the saw is running the brushes must be working. Maybe the front end grease has dried causing too great of load on the motor. if not the motor must be defective (lost a winding in the feild) don't know how much you paid but unless its worth is greater than $150 I sugest buying another
Sep 18, 2012 | Bosch 2604320913 Carbon-Brush Set
Just noticed my 5 year old bosch top handle jig saw doesn't speed up past 4 on the dial. Seems to only run at half speed. what does that sound like? thnks
It sounds like you may have a faulty speed governor. If everything else sounds fine, (no grinding or other strange noises) then that should be the problem. If there is grinding or odd noises there may be bearings that are seizing causing the tool to run slower.
Nov 24, 2010 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
I was cutting 2" dense foam insulation board,
The problem you have is a faulty field coil, the Bosch saws unfortunatly have a bit of an issue with this. The coil can be replaced separatly so you won't have to replace the whole motor. Bosch has a 1 yr warranty on thier table saw so this is a warranty replacment provided the saw was purchased within the year. If not the coil replacment is still cheaper than buying a whole new saw, but should really be done by a service center because of the level of difficulty of the repair.
Nov 10, 2010 | Bosch 4100 10" Worksite Table Saw
Problem guiding the direction of cut with a jigsaw.
check that surface plate is square with the blade.don't push too hard,or force the saw,let it cut at it's own speed,guide rather than force.a scroll saw or band saw is more accurate as you control the work piece instead of the tool.
Oct 11, 2009 | Festool Jig Saw Circle Cutter - 490118
Not sure how the blade seats in saw pneumatic bosch jig saw i can get it to go in but the blade seems to wander and seems to be unstable
do you have the screwdriver that came with the saw? if not you need a longer straight slot screw driver and it must be ground down to fit into the blade clamp tightener. it is a narrower than usual screw driver. I lost mine and had to custom make one. good luck.
Sep 14, 2009 | Bosch 7561 - 118 Pneumatic Cutting Tools
Can you recommend the best blade for cutting 1" marine ply epoxy laminate?
Marine epoxies that I have encountered have been on tug boats and may be harder than what you are dealing with but it all boils down to speeds and feeds. Easy even pressure will work best and if it is gumming up then you are creating too much heat, so less strokes per minute. Also you can compressed air to remove the dust and cool the cut a little, epoxy dust is like plastic sandpaper and when it heats up it just melts to stick goo then solidifies.
Also if it is a round cut, a hole saw at a low speed with the cut cleared of debris regularly works well, and if it is a large hole, apply the same principals, and use a Recip saw or sawzall.
Hope this helps!!
Jim
Aug 05, 2009 | Bosch #T101A3 3PK 4" 14TPI Jig Blade
Hand jig saw stops cutting - makes whirring noise - then restarts
Jig saws are not made to cut through aluiminum espescially that size. That is really thick and it sounds like you have worn out the motor trying to cut it. If the saws are hot. Let them cool down then proceed but like I metioned before you are putting a lot of stress on something not made to cut aluminum even with a metal cutting blade
May 21, 2009 | Saws
Problems with Bosch T101BR 4 Inch 10 Tooth Jig Saw Blades
Hi, The reason for a down cutting blade is to see your cut on the finished side of laminates ( which include veneers, plywoods, plastics, formica . When using an upcutting blade on laminates the smooth cut is on the bottom, which you can not see till you are done and turn the work over. Reversing the teeth allows that smooth cut to be on the top. This is usually done on smooth flat surfaces as you have found out and does not work with orbital or tight scrolls. As far as the pushing or pulling, smooth cuts in laminates require the saw doing the work at a speed that allows the teeth to cut and remove material with biting. So if you are biting, (This is a much slower process than pushing your jigsaw through regular wood) check that you are not pushing too hard and that your blade is still sharp. Good Luck to you, this should Fixya!
Mar 08, 2009 | Bosch T101BR 4 Inch 10 Tooth Jig Saw...
Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw Logo
656 people viewed this question
Top Bosch Saws Experts
Craig Butler
Craig Butler
Tim Venetis
Gary Nitowski
Are you a Bosch Saw Expert? Answer questions, earn points and help others
