Question about Samsung Cameras
Hi - I have a Samsung TL100 compact digital camera. I have started seeing "spots" in the photos - like there is dirt on the lens, but I have cleaned the lens carefully and they are still in the image. Any ideas?
  • jeff_sakaguc Aug 02, 2010
    I know the white randomized dots due to flash-on-dust. These are dark spots, same location in image as though there are dust particles or fibers on the lens. But they must be inside the optics? Or on the image sensor (though not sure if that makes sense)? How does one remove these particles other than sending camera back to manufacturer?
  • 182 Answers
Well yes most probably its the dust particle and fungi floating around in the air
Cause: Light from the flash has reflected off dust particles or
insects in the air. This occurs more frequently in the following
conditions:
- When shooting at the wide angle end.
- When shooting with a high aperture value in the aperture-priority
mode.
Solution: This is a phenomenon that occurs with digital cameras and
does not constitute a malfunction
And definately the are not ghost...as speculated by many ghost hunters :)
Posted on Aug 02, 2010
Canon A530 black spot on LCD which is visible in the photos tried to clean the lensa but was in vain canyou help pls?
A blck spot on your pictures, means there is something blocking light on the sensor. Could be dirt, but more lightly is there has formed some mould.
Because you can't open a compact camera to clean the sensor, I think you can't solve this problem. Opening the camera is no option, because without skills, tools and manual, you won't be able to put the camera together. A repair shop most likely won't start the job, because the repair will cost more than a new camera.
Sorry I can't bring a more positive story.
Jan 26, 2014 | Canon PowerShot A530 Digital Camera
Why my ST50 Samsung camera cannot work even after battery being charged. If I put on photo taking or video icon it will beep and then it gets turn off. Thanks Helen
It could be a lens error or battery already malfunctioning. Do you get any error message or any message at all before it turns off?
Nov 01, 2011 | Samsung TL100 / ST50 Digital Camera
I just bought the canon rebel xs and every picture that I take has a black spot "burned" into the picture. Any suggestions as to what I should do? Or should I just return the camera?
Sounds as if there is a fleck of dirt on the rear lens element. While in the house (to minimize dust and dirt) remove the lens and look at the rear of the lens see if there is dirt there. If so clean it gently with a soft lens cloth not a facial tissue. Reinstall the lens, if the dirt is still in the same spot return the camera because I suspect the dirt is on the sensor and will need to be cleaned.
Dec 27, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Samsung L100 camera, battery charger shows battery is fully charged, camera powers on, lens extends then immediately retracts and camera beeps three times
it sounds like a faulty battery try testing it with another battery and see if the problem persists if not then get a new battery,
let me know how it goes,
Jul 31, 2010 | Samsung L100 Digital Camera
I dont have the software that came with my samsung TL100
Click Here!! For your software!!!
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
Apr 17, 2010 | Samsung TL100 Digital Camera
My SAMSUNG TL100 CAMERA LENS STUCK OUT SIDE
It seems your camera Lens got stuck in open condition, This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace.
or
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery indicator on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Follow the instruction to retract camera lens:-
1) Turn on your camera.
2) Press the Playback button on the back of your camera. The lens on your camera should retract.
If problem still not resolved then your device need to be serviced (Repair).
Rating the solution is highly appreciated...Good Luck.
Mar 04, 2010 | Samsung TL100 Digital Camera
Dirt smudge inside lens
You did not mention the model of your camera but I assume its a compact camera.
It happened to me once. I opened the camera, strip the cards and cleaned the lens.
But I warn you, its very annoying operation. You need shakeless hands and super focusing abilities. And also it takes time, need patience. Use mild cleaner not strong one. You may use a hand blower, this method is more simple, dont need to go through lens and strip entire cards etc. Just open the back of the camera and look for a cavity to put nozzle through to lens area and cross your fingers than blow it lightly with hoping the dust gone. :)
Jul 08, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
CAMERA IS THREE MONTHS OLD. ON MY LAST OUTING I NOTICED A PERFECT CIRCLE SPOT ONLY IN SHOTS OF THE SKY. THE SPOT IS IN THE IDENTICAL PLACE ON ALL SKY SHOT PHOTOS NO MATTER WHAT FOCAL LENGHT IS USED. THE...
If you have another lens, switch it and take some shots of the sky. If the spot is gone, it probably was the lens that needs cleaning/servicing. However, it's more likely that there's dirt on your CCD. On your camera's menu, select mirror lockup/clean CCD (I can't remember the exact terminology but you get the idea).
After you select that, the mirror will stay up. Remove the lens and you'll see that the CCD is now exposed. Use a blower (don't use your mouth to blow as you will end up with spit in the camera) to clear out any dust/debris on the CCD. Don't touch the CCD.
Turn off the camera and you'll hear the mirror go back down. Re-attach your lens and try some shots.
Apr 13, 2009 | Canon EOS 40D Digital Camera with 28-135mm...
D50 black spot of photos
Ok, step one - find an appropriate cleaning solution - be it an air blower, like a rocket blower, a pads, alcohol and a qtip, etc. Keep in mind that it's not necessarily true more expensive means better cleaning... but I wouldn't go the dirt cheap route of alcohol and a qtip, though many claim they use it. Personally, I use a blower, but I havn't had anything more than dust thus far...
After that, prep a very clean environment, then take off your lens, and clean your mirror!!! Then when you think it's clean, try your camera again... if you still have spots, then you're going to have to clean the sensor... again, I'd use a blower, especially considering that if you ruin the sensor, you've pretty much ruined your entire camera.
If you STILL have spots, check your lens for dust, both front and back lenses. Still spots? Try another lense entirely (might be scratches). STILL on there? Then you probably have a bad sensor... see warranty information and pray :).
If any of this makes you queasy, look in your phonebook for stores that will offer repair, and try to locate the Nikon-qualified if possible.
Oct 05, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Cameras Logo
118 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
