Question about Kenmore Dryers
The igniter glows but it wont heat - Kenmore Dryers
    President:
  • 1,554 Answers
The burner power circuit is good as indicated by the igniter glowing. The problem now lies in the gas valve solenoid coils failing to open the valves to allow gas to flow be ignited. The coils are located on top of the gas valves one with two terminals and the other with three. Replace both coils to make the dryer heat up again.
Posted on Aug 02, 2010
Why wont my bottom oven heat up, it will ignite but wont heat,has the bulb anything to do with it,its blown HELP ZANUSSI ZCG660GXC LPG gas with electric ignition and clock.
The gas valve for the lower oven won't open after the igniter starts glowing. If there is no orange glow from the igniter, then it needs to be replaced.
Jun 19, 2015 | Zanussi Ovens
Dryer will not heat. Just put in a new igniter but still wont heat
3 rules of heat, Fuel , Air , Ignition
Gas Valve turned on?
Is the ignitor either glowing or sparking pending on the type?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 22, 2013 | Roper 29 Gas Dryer
No heat had 2 gas valves replaced one year ago where are these valves located. i can not see a glow from igniter either
if the igniter wont glow then look for a white spot on the igniter. if you see it replace the igniter. it is most likely is bad if not glow. but you may have other problem. get me you model# if you continue to have problem. in my opinion you dont need to change the gas valve only the coils if they are bad. good luck to you and let me know.
Feb 06, 2011 | Dryers
Whirlpool lgn2000LG0.... flame wont ignite.. glow stem glows..
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 04, 2011 | Whirlpool LGN2000LWH Gas Dryer
Oven takes too long to heat up sometimes wont even go to the temperature ignitor is working well can see the glow magic chef model 3488vvv serial 13368882kz
Hello there:
When you turn the oven on, open the oven door and look down at the bottom and see if its glowing red, it should glow red for about 45-60 seconds then you should hear the gas ignite. If the gas doesn't ignite, then your igniter glow bar is bad.
Here's the oven glow bar igniter for your model:
Manufacturer's Number: 74007498
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=
partimage.aspx?imgid=z3bqljbfbxnfodk0nzawndcvq0fnl3nvdg9ochryyxav
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=74007498
Sep 28, 2010 | Ovens
Car wont start diesel engine Could it be the 'glow plug'? what is a glow plug? how can i test?
A glow plug is a small heating element in the cylinder. It heats the diesel so that starting can be made easy. Is your car standing in the open frozen parking If yes, then it would require a lot of battery power to first heat all the cylinders and then turn the engine to start. What we do in such conditions is to light up some fire under the car and heat the fuel system enough for the diesel to warm up a little and thus save the battery for glow plugs. Generally, all vehicles have an indicator light which comes on when the glow plugs are ready for starting. The diesel will ignite on compression, but it has to reach the cylinder and thus has to be flowing. In cold it freezes and hence the need for glow plugs and the heat. If it is parked in heated parking then the need for glow plugs decreases.
Jan 01, 2010 | 1991 Peugeot 405
I have a coleman evcon furnace and it wont work it gives me a flash code of 1 what does it mean
One flash mean ignition failure. The sequence is: T-Stats calls for heat, inducer motor comes on, igniter glows orange (look through glass), then gas comes on and burner lights, approximately 1 minute later the indoor blower comes on. If you don't see the glow, most likely the igniter is bad. If you see the glow but no flame, it's a gas problem, supply or defective valve.
Dec 26, 2009 | Tools & Hardware - Others
Igniter does not glow
probably not, its probably on the control board, remove the ignitor and depending the voltage it requires to heat take a power supply and double check it
Oct 02, 2009 | Kenmore 63942 Dryer
Dryers Logo
63 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
