Question about Mitsubishi VS-60607 TV
Wondering what smps is and lc is???
How do i find those...and once i do...is it something i can fix or should i pay someone to do it?
    President:
  • 4,402 Answers
Posted on May 28, 2008
Sharp Aquos LC-26D4U sound problem
Yes this is a common problem. You have to have it refered to a TV SHOP. I can fix it for you but in CA. the wiring on the speakers needs to be upgraded to a thicker wire. The gauge is to small for the current needed to flow evenly.
$75.00 Fix
Feb 13, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
I BOUGHT MY BROTHERS COMPAQ PRESARIO PC OVER A YEAR AGO AND THE GREEN LIGHT HAS GONE OUT AND I CANT GET IT TO TURN ON,BUT THE MONITOR STILL WORKS. I WOULD LIKE TO TRY AND FIX THIS ON MY OWN,OR WOULD IT BE...
I also think it has something to do with the SMPS.
MOST computer failure can be attributed to Power Supply failure.
MOST computers out there are dirty inside, as well as the Power Supply.
Also, your diagnosis of the green light going out indicates PSU failure.
(Power Supply Unit)
The two cooling components for an SMPS are it's Fan, and any Heatsink's used inside.
Heatsink:
Generally a metal plate that has tall, thin fins protruding from it.
The metal plate absorbs heat from whatever object it is placed against, and the fins absorb heat from the metal plate.
The fins then radiate the heat away.
If a cooling fan is used in conjunction with the Heatsink, the air movement helps to dissipate the heat, that has been absorbed by the fins.
Internal view of an average SMPS,
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Upper right photo. (You can enlarge the photo by Left-clicking on it. You can enlarge it twice)
Once the cooling components of the SMPS are clogged with 'Gunk', the cooling capacity drops tremendously.
Heat = Wasted Energy
The SMPS tries to keep up with the call for power, but eventually cannot, and hardware components inside the SMPS fail.
NEVER open a SMPS, and try to repair it, unless you are a qualified tech. A qualified tech, knows the proper procedure to drain the power from the capacitors, before working on the unit.
(Frankly it's not worth the effort. The procedure is to just replace the SMPS)
Inside the SMPS are Electrolytic Capacitors.
They are used as Filters.
They filter the incoming AC electricity, (Input Stage), and the outgoing DC electricity made by the SMPS. (Output Stage)
An Electrolytic Capacitor slowly builds up a charge, and then releases it all at once.
You may compare it to a large swimming pool being filled up by a garden hose, then one wall of the pool is taken down all at once.
Electrolytic Capacitors hold a charge for Weeks, Months, or even over a year, in some instances, after being removed from power.
(In this instance it would be unplugging the PSU from power)
IF, your finger/s touch the terminals on the bottom of a Radial Aluminum Electrolytic Capacitor, the charge could be released to You!
IF, your fingers complete a circuit, that one or more of those capacitors are in, the charge could be released to You!
Shock can be Bad to Fatal!
(See those two large Electrolytic Capacitors, in the SMPS link photo I provided?
Upper left corner of the SMPS photo. They have blue plastic sleeves around them. They are indicated by the letter B.
These are Electrolytic Capacitors used in the Input Stage. If they are good, they have enough power stored to put X's in your eyes)
Ready to test this puppy (SMPS), or replace it? Just post in a Comment. (Believe upper right of your page)
(The SMPS in your computer puts out three main Voltages.
A) 3.3 Volts (DC)
B) 5 Volts (DC)
C) 12 Volts (DC)
Two C cell flashlight batteries produce 3 Volts (DC)
The test is done with a multimeter, or a power supply tester.
One example of a power supply tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471 )
Buy a new Harddrive for it? Why?
If you do, be prepared to buy another genuine copy of Windows.
Information on the Compaq Presario SR1530F desktop computer;
HP Support>Compaq SR5301F desktop computer>Product Specifications main menu,
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=51284&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3644734
Jun 09, 2010 | Compaq Presario 5000 PC Desktop
Picture goes out
Check the other posts. This is a known problem with a known fix. Keep bugging Sharp till they send someone out. Or, pay a tech to fix it. Repair parts will be one set of screws. Cost of the labor may be worth not having to deal with Sharp customer service.
Nov 26, 2009 | Sharp Aquos LC-32D40U Television
Vertical output
the vertical output is a ic . If youre handy at soldering you may be able to repair it yourself. If youre not comfortable soldering close solder connections, it may be best to have a professional do the repair.
Sep 18, 2008 | Televison & Video
Need to hook it up to a pc what kind of cord do i need
i would never pay for someone to tell me on a web page how to fix something that is fuckin stupid if i pay some one they better come to my house and fix it in person
Sep 01, 2008 | Televison & Video
AKAI LCT2701TD SMPS Failure: Red flashing light
I do not think there aren't any new power supplies available to fix these LCDs. The only way to make the LCD work again is to have someone to repair the power supply.
You could send me an email to jah2mil@hotmail.com for more info.
May 16, 2008 | Televison & Video
What to do
thats impossible u have to pay it for service i suggest finding someone cheep and pay for it
Jan 08, 2008 | LG enV VX9900 Cellular Phone
Mitsubishi VS-60607 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
