Question about Samsung DV419AGW Dryer
Buzzing noise no matter what setting I choose, after the first 20 seconds or so, there is a buzzing noice that kicks on and off throught the different drying cycles - I can't locate anything about in my manual nor does changing the different cyle configurations seem to turn it off... It is quite loud and seems to signify a cycle but can't be sure.....for a quiet dryer this noise is quite irritating
  • seedubs
    seedubs Mar 31, 2016
    I know this is old, but I just got this problem fixed and would like to help other people with this issue. It's the heating coil. It's faulty, and mine came that way, and i lived with it for years. When the coil clicks on, it rattles and buzzes super loud. Samsung charges 200$+ for the replacement heating element. However, my repair guy found that the part that came with the dryer was actually made by Maytag!! They swapped out the Maytag coils with a working part and the buzzing has stopped. Hope this helps.
    New Friend:
Did you ever figure this out @flushigitty? I have the same problem and would love a quieter dryer.
Posted on Jul 20, 2015
Not sure exactly what part is causing the noise. But...I took off the steel plate at the bottom rear of the dryer. I found (with the dryer running) that the buzzing sound coinsides with the lighting of the glow plug (this ingnites the gas). This happens several times during a cycle because the dryer is programmed to turn the gas off and back on to maintain a constant heat during the cycle while still saving gas. I suspect its the electronic component responsible for turning on the glow plug thats doing the buzzing. will continue to search the web for more answers. cheers
Posted on Oct 22, 2012
  • Samsung Master
  • 43,501 Answers
There can be many reasons why your dryerbuzzing noise - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The drbuzzing noise - 2_bing.gifc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 03, 2010
I have a Whirlpool solid-state mark to washing machine powers on but when I hit the run button it just buzzes
See if buzzing noise stops after 10 to 20 seconds if not your cycle timer stuck. Change cycle to a different selection and try to start.
Aug 02, 2014 | Washing Machines
Buzzing noise-Model #KX-TGA931T
There should be a "CH" or 'CHAN" button. Press it till it stops.( It is the channel button). or turn down the volum on the hand set.
Dec 26, 2013 | Panasonic Lands Phones
Loud pop and then buzzing noice mitchubishi 1080 p
Unplug the set and do not plug back into power until see is opened and examined. It says Mitsubishi here but what is the model number as it is not indicated here.
Jun 03, 2012 | Mitsubishi Televison & Video
There is a squeaking noise upon starting the dryer no matter what size load is in there. it lasts throught the whole cycle. its a pretty loud screeching noise.
Unplug dryer. Remove front kick panel, Remove door. Lift top and lay it back, be sure to support it. Take tension off belt. Remove drum. Replace all worn parts the hold up drum. Check belt tensioner for ware and replace if needed.
Jun 03, 2011 | Whirlpool Maytag Bravos MGD6600TQ Dryer
My powered mixer Behringer is buzzing
Make sure the buzz doesn't happen because of feedback of speakers into mics. When feedback is processed it often goes to a buzz instead of the usual howl.
Also check that you are running adequate inout into the effect since a very low inout will incur digitizing noise and loss of signal=to-noise ratio.
Jun 02, 2010 | Behringer POWERED MIXER, 20 CH, 400 WTS...
My 1986 2kr FZR250 won't kick
sounds like the fuel pump my freind its just under the fuel tank on the fzr,s near the back of the tank sounds like replacement pump will sort it hope his helps
Dec 16, 2009 | 1987 Yamaha FZR 250
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Carrier 58GS150-CB ignites but fan will not blow (Loud Buzzing)
The loud buzzing soud i found to be the fan blower motor. I removed the fan bracket assembly and sprayed a little WD-40 on the set screws and protruding shaft so that sqirrel cages could be removed. (Also marked position of set screws on shaft) once squirrel cages were removed I removed 4 motor mounting bolts. Cleaned sqirrel cages and housings with industrial strenghth rim cleaner to remove solid dirt and will replace motor and capacitor.
BTW thanks for nothing
Nov 22, 2008 | Goodman GMS90703BXA Heater
Samsung DV419AGW Dryer Logo
876 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
