Question about Electric Eyeware Chicago Electric Hd 14" Industrial Cutoff Saw
How do I change brushes in a cutoff saw? I am not sure exactly how the new brushes are inserted with the locking screws. Do U just insert brushes and compress spring with screw on plastic lock nut?
    Guru:
  • 509 Answers
Yes. That's all there is to it. Just insert the new brush, making sure there are no pieces of the old brush still in the holder, compress the spring and install the plastic cap.
Posted on Aug 02, 2010
Ks656pe how do i change the blade? i don't have any instruction. Please
Quick-Change Blade Mechanism
Higher-end models, such as the Linefinder Orbital Jigsaw, feature a clamping lever to hold the saw blade. To change a blade, switch off the jigsaw, unplug it, and let the used blade cool down. Pull up the saw-blade locking lever and let the used blade fall out with a slight shake. Turn the jigsaw upside down. Hold the fresh blade with its teeth forward; insert the blade shank into the blade holder as deeply as it will go. Release the lever and wiggle the blade to confirm that it's snugly in place. For models with rollers, such as the Accu-Trak, nestle the blade against the rollers.
Clamp or Hex Screws
Loosen the pair of screws -- on the front of the mechanism of models such as the single-speed jigsaw -- a full turn counterclockwise with a flathead screwdriver, but do not remove them. The used blade will fall out. Insert the new blade fully into the clamp. Lightly tighten each screw alternately and then fully. On older models, you may find a single hex screw on the side of the blade. Loosen this enough to remove the blade, and then insert a new blade carefully so the teeth face forward. Retighten the screw.
Oct 03, 2017 | Saws
Bosch rs5 brushes how to replace them
most small wattage electrical motor brushes are held in by a plastic plug with a screw driver slot in the face in the side of the motor casing
with the power disconnected from the wall
remove those plugs and pull out the spring and brush
insert the new brushes
Jun 26, 2017 | Bosch Saws
How to change scroll saw blade
MAKE unknown to us we have no idea where to look or send you
Jun 25, 2016 | Saws
Can someone help me find a replacement table saw insert for model # 152.221140, part # OR91014
Sears is the place.
thanks for the inquiry and for using searspartsdirect.com.
the insert or91014 has changed to a new part of 27509.00, but will still be the equivalent of the original. the insert will just be the insert, none of the set screws or hardware come with it. if you have the original hardware and just need a replacement insert, you can use the originals with no issue.
hopefully this helps and let us know if we can be of any further assistance. thanks for using searspartsdirect.com.
152 2210040 Insert 152221040 Craftsman Table Sears PartsDirect
Dec 30, 2015 | Saws
How to put the blade into the black and decker 3.4 amp powered handsaw
#1) You have to locate the blade release button on the saw (see your manual). The opposite side of the release button is a screw-like OVAL shaped PIN. To insert the blade, the direction( or position) of this OVAL shaped PIN has to match the OVAL shaped hole in the blade. You could use a screw driver to change the direction/position of this OVAL shaped pin. You have to push down the release button when you use the screw driver to turn.
#2) Hold the blade in Vertical position in your right hand. The "Oval" hole is on top. The teeth is facing your left hand. You will see that the "oval" hole on the top of the blade is a "horizontal" oval.
#3) Hold the saw (handle) in your left hand as if you were going to saw using your left hand.
Now peek through the hole of the saw and find the direction of the OVAL PIN. It has to be a "horizontal" (or lied down) OVAL. If it is not, use the screw driver to adjust it.
#4) Hold the blade using your right hand. Oval hole on top, teeth facing your left hand. Insert
the blade from the bottom of the saw. What you needed to do is to insert the PIN into the hole
of the blade. When you inserted the pin into the hole of the blade, slowly turned the blade upward, the blade will lock by itself.
Oct 15, 2013 | Black & Decker PHS550B Powered Handsaw...
Husky thd750 wet saw changing blade
If this is the K750 cut off saw, then to change the blade you need to remove the 13mm fixing screw ( anti clockwise )if you cannot hold the old blade to remove the screw, insert a 6mm pin into the right hand belt cover, there is a hole to tale this, this will engage into the pulley and lock it, then remove the outer flange, the old disc will now come away, make sure the new disc has the same size centre as the old one, the size will be on the rating plate on the cutter guard.
Oct 29, 2011 | Garden
How can i change belt. model # 4235 az
I've posted the steps below, but I am also going to give you a link to the manual, as it includes pictures that might be helpful. Look for page 4.
http://www.eureka.com/service/manuals/81221.pdf
1) Use handle release to lower handle flat
onto floor (Fig. 1).
2) Remove 4 screws from brush roll cover.
(Fig. 2).
3) Lift off brush roll cover. (Fig. 3).
4) Remove brush roll and belt. Thread new
belt around motor shaft and brush roll
(Fig. 4).
5) Insert left end of brush roll first. Make
sure end cap fits into base. Pull right
side of brush roll to stretch belt and
insert right end cap into base (Fig. 5).
Make sure it slides into position.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover (Fig. 3).
8) Replace 4 screws (Fig. 6).
May 05, 2011 | Eureka 4235AZ Upright Vacuum
How to get the vacuum apart to change the belt
Turn power nozzle bottom up.
Remove the 5 screws.
Insert tip of a standard screwdriver into each square hole on either side of the wheels and twist to release the tabs.
Holding the power nozzle together, turn it over.
Lift the back of the cover up, then remove it.
Remove the screws at the ends of the brush.
Lift out brush.
Remove belt and replace with new belt.
Place brush back into slots and replace screws.
Check belt to make sure it's settled correctly and check tautness. It should have some give, but not much.
Replace cover by inserting front lip into the slot at the front of the base. Carefully manipulate into place, ensuring the latches click into place.
Turn PN bottom up.
Replace screws.
Feb 25, 2011 | Electrolux Epic 3500 Vacuum
How to remove the blade
If the saw doesn't have a locking blade button, you need to insert a ( most likely) 14mm thin wrench between the blade and the body of the saw, on the axle, to hold the axle. Unscrew the bolt of the axle and the blade is out. After you place a new one, the procedure is exactly the opposite. Keep the power cable unplugged during the entire time of the blade change. Safety first.
Sep 08, 2010 | Skil 18v Circular Saw saw 18 Volt 5995...
I have a Eureka Altima and not sure how to change the belt?
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
new belt around motor shaft and
brush roll
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Electric Eyeware Chicago Electric Hd 14" Industrial Cutoff Saw Logo
198 people viewed this question
Top Electric Eyeware Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Electric Eyeware Saw Expert? Answer questions, earn points and help others
