Question about Kenmore 63793 Convection / Microwave Oven
No power Prolonged pre-heating oven last night, smelled electrical-type singe--now unit not functioning. No vent, light, or power. Is it possible that a fuze in the unit burnt out (I checked the breaker)?
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 25, 2011
Have a Whirlpool MW Model MH6600XV with a vent hood; last night the vent went on by itself and I was unable to turn it off except by the circuit breaker; turned the breaker back on this morning and the...
If you got it hot enough from your soup there is a fan switch to turn the blower on to cool the unit. Maybe next time cook that on a different burner on the stove to try to not heat up that area under the microwave.
Sep 17, 2017 | Microwave Ovens
We have a Panasonic NN-CT579SBPQ. Using it last night there was several cracking noises then it stopped. The display showed the message you get when it is first plugged in. Tried it again, turntable...
The microwave oven needs to be replaced, the magnetron is the most likely problem, there is also a high voltage transformer, capacitor, and diode that are potential issues. But by your description it sounds like more than one part is involved.
Feb 23, 2011 | Panasonic Microwave Ovens
Last night my wife accidently turned on the microwave with nothing inside. It probably ran for 15-20 minutes before I noticed a burning smell (burnt wiring) After opening the door I noticed the unit had no...
well I can tell you roughly what happened. You overheated the oven, as there was nothing inside to absorb the radiation. So the sensor shout off the power ( safety switch) It returns when the oven reduces in temperature. The burning may be due to internal damage to some of the insulation compound. It takes foreverf to get rid of smells from microwaves no matter what you use including vanill or some other anti stink medicine. The unit is probably OK but overtime will now begin to deteriorate and may even leak radiation to greater extent.
Dump it is my suggestion, but make sure it is damaged sufficiently to prevent dump rats from salvaging it and using it.
The unusual noise ( almost missed that) is damage to the rotation motor bearins that have been expanded and are now out of alignment.
Too risky!
Jul 31, 2009 | Microwave Ovens
Was using it last night to heat something up. When almost done, microwave made a zizt type of sound and went off. I turned it back on and it continued cooking, but I started smelling burned plastic or
More common then you think, i have gone through a couple microwaves in the last ten years, they both failed very similar to what you describe. One popped the breaker one day, reset the breaker and it worked again but had an odd smell to it. I took it apart and couldn't find anything burnt or melted so i tossed it and got a new one, i didn't want a microwave burning the house down! I would suggest unless your really tied to that microwave that you just replace it for safety sake. Four years or forty years old don't matter anymore, i had one microwave, LG brand, that died two months after the warranty expired and it would cost more to repair it then replace the thing!
Jan 11, 2018 | Panasonic NN-H964 1200 Watts Microwave...
GE Spacemaker XL1800 does not heat. All other functions appear to be working normally, the light comes on and the turntable functions. When turned on, it makes a humming noise slightly louder than normal,...
Possible bad heating element, You should remove the cover of the unit and look at the heating element with the power off. Until you get your problem resolved I would recommend not to even turn it on due to the fact that you are unsure what is going on and you smelt some burnt smell. Just for safety until you fine the problem
Feb 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson 1100 microwave prolonged heating time
the magnatron is going out (this is what warms up the food!( would be cheaper to replace then to fix!)
Dec 09, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Daewoo kor-861h, electrical smell and will not heat.
Turn if off, and leave it alone, remove it, if you can remove the unit, take it in for service, something is wrong if you smell electrical, most people for some reason can smell and identify correctly electrical or at least insulation burning smells, which means something is burning internally, not safe, fire hazard, unit needs to be repaired by qualified technician or replaced with new unit, take no chances, nothing you can do to repair this, could be a shorting transformer, or shorting power cables, but to attempt to trouble shoot this with email is a long shot, and depends on your experience expertize and testing equipment.
I wish I could give you a short easy answer, but the hazard and your safety is more important than a microwave.
Will
Nov 30, 2008 | Daewoo KOR-860A Microwave Oven
Burning odor, no heat
A burning smell along with a different sound (growl) USUALLY indicates a breakdown in the High Voltage Side. This is not a direct short (short circuit) or the line fuse would have blown shutting everything down. The High Voltage Side is made up of-- The Secondary ,or High Voltage Side of The High Voltage Transformer, A High Voltage Diode, A High Voltage Capacitor, and The Magnetron. If The High Voltage Transformer is the problem it will smell like a florescent light ballast burning, and will smell each time you turn on the MW. A HV Diode burns and opens, thus no more smell. A HV Capacitor usually does not burn nor does the Magnetron. There is no Cheap-Fix unless you can see that the HV Diode is burned into and you can get to it to replace. CAUTION: Always unplug from power before attempting to repair. NOTE: If you replace a Diode make sure it goes back in the same direction it came out. Yes there is a front and back.
Jan 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 63793 Convection / Microwave Oven Logo
66 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
