Question about Toshiba 56HM66 56" Projection HDTV
Audio problem... channel with no sound
I bought the TV and I watch the local HD channels. One of my channels lost audio for some reason after a few months but I didn't really care since it was a hispanic channel that I don't usually watch. I even thought it was a problem with the TV station. But now another channel has the same problem. It is completely muted and I have no idea why. It happen all the sudden last month and it haven't recover itself. what can I do?
  • Anonymous Nov 09, 2008
    same thing hd lost sound
  • donaldkinsun Jan 12, 2009
    I double checked it already. It is set to Stereo. Please let me know if there is a SAP disable option. Actually right now I have 3 channels with problem. They recently added a new channel. 42-1 with English AC3, 62-1 Spanish AC3 and 62-2 Spanish AC3.
  • 108 Answers
Make sure your S.A.P feature is turned off. S.A.P. stands for separate audio program.
Posted on Jan 10, 2009
I just bought a samsung home theater in a box system, model Ht-D5500. And i also have a hd cable box. i was wondering how can i connect my cable box up so that i get audio from the speakers instead of the...
There are two ways of connecting to get cable TV audio from your Home Theater System.
1) If your HD cable box has a digital audio out ( either optical or coaxial ) you can connect this to the Samsung Home Theater Systems digital input. While watching a TV channel scroll through the Samsungs input ( source ) selector till you hear the sound. Remember to mute the TV sound while you are doing this.Most probably it will be the CBL/SAT input or Video AUX.
2) If your HD box does not have digital audio out you can connect the Red & White audio out of the same to your Samsungs Aux or TV or Video audio inputs . Ignore the yellow socket and connect only the Red and White audio inputs.For getting Video through the TV connect the HD box to TV via HDMI cable or connect the Yellow video out to the TV's Yellow video in. I am sure it is already connected .
Mar 21, 2011 | Audio Players & Recorders
Using my universal remote contol,lost sound on 2 TV channels
The solution is to change the audio input from SAP (secondary audio programming - default on TV sets sold in Canada) to Stereo or Mono. Your remote will need to be able to access the "Menu" settings screen for your television set.
May 07, 2009 | Samsung TV Remote Control
No Non-Hd sound
Best Buy owns some of the brands it sells. Best Buy currently has five private labels which include Insignia, Dynex, Init, Geek Squad, and Rocketfish. Insignia focuses on electronic equipment, including televisions, monitors, car stereos, home theater systems, and portable video and audio players.
The Best Buy televisions are made with substandard components. They are not produced with the same standard the orginal manufacture items.
With the factor of substandard pieces and flash/firmware glitches; it sound like you have a software problem.
I would contact the manufacture ASAP and have a field tech come by to update your television.
Jan 21, 2009 | Insignia LCDTV26 26 in. Television
VCR with intermittant audio and video problems
you have to connect VCR output cable to your TV input, thats all, it will be in series, if u want to record any program then on your TV and on record switch of your VCR.
Dec 30, 2008 | Sony SLV-N55 VHS VCR
Problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
Nov 05, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
Direct TV/Olevia 247 audio skipping
I have the same problem with comcast HD, completly useless talking to them, they do nothing to assist
Mar 26, 2008 | Televison & Video
Audio
How are you hooked up? I.E. terrestrial, satellite, ?
If the channel on HD isn't strong enough to pull the signal, sound won't play because it isn't locked. Because you have sound on non hd it is a signal issue not the tv.
Feb 16, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Sci Atlanta 8300 DVR HD sound in HD channels soft - analog channels OK
Experience has shown that with this relatively new mode of transmission, audio levels can be quite dynamic. If your set provides it, you may try turning on "Audio Compress" or whatever the name might be. Could also be called Dynamic audio also or some such. Reason for all the hubbub is that along with HD, mixing engineers are also providing the most range for the audio dynamics as well the most video composition info in the new broadcasts...Accordianman.
Oct 11, 2007 | Televison & Video
Toshiba 56HM66 56" Projection HDTV Logo
126 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
