Question about Hardware & Accessories
I am trapped inside my apartment. The bolt in the door is stuck and wont move and I don't know how to move these new hinge pins they need some kind of tool.
  • 142 Answers
Have you tried taking the door knob apart
Posted on Aug 02, 2010
How do I remove the front passenger door on a Citroen c5
Examine the hinges. They may be bolted from the outside at the door side. Another option is remove the 'drop pins' holding the two half's of the hinge together. Some hinge pins are only held in with a spring clip. Your only other option is to remove the front wing and unbolt the door with the hinges still on.
To remove the pins-
NOTE THIS IS A TWO PERSON JOB!!
Proceed as follows...
Support the weight of open the door.
Tap the spring clip sideways off the thin end of the pins,
(located top of the top hinge and bottom of the bottom hinge).
Tap the bottom pin upwards then the top hinge downwards.
You might need to wriggle the door to get them to move.
REFITTING
Put the bottom pin in first as it 'drops' in and the upper pin pushes up into position.
Again, you will have to wriggle the door and GENTLY tap the pins into place.
Swopping the the pins makes it easier to line up the new door as it closes.
Dec 26, 2017 | Citroen Cars & Trucks
Tip
How to Reverse Your Refrigerator Door (Most units)
1. Remove the toe grille.
2. Remove top hinge cover if available. Trace around the hinge with a soft lead pencil. This makes the re-installation easier. Remove top hinge and lift door off the center hinge pin, and set the door aside.
3. Unscrew the center hinge pin using an adjustable wrench and save for reassembly. Ensure that the plastic washer stays on hinge pin.
4. Lift the refrigerator door off of the bottom hinge and set aside.
5. Remove center hinge and shim by removing inside screw and loosening two outside screws enough to allow hinge and shim to slide out. Tighten screws.
6. Loosen two outside screws on opposite side of refrigerator, remove inside screw and install center hinge.
7. Remove two screws on bottom hinge with 3/8" socket wrench.
8. Install bottom hinge on opposite side with the two screws removed from Step 7.
9. Unscrew the bottom hinge pin using adjustable wrench. Move hinge pin to other hold in hinge and tighten with adjustable wrench.
10. Reverse door handles.
11. Move freezer and refrigerator door stops to opposite side. Before starting screws, use an awl to puncture the foam.
12. Position refrigerator door onto bottom hinge pin and screw center hinge pin through center hinge into the top of the door. Close refrigerator door to help align hinge hole.
13. Tighten center hinge pin with adjustable wrench.
14. Remove cabinet and hinge hold plugs and move to opposite side.
15. Lower freezer door onto center hinge pin (if you have a separate freezer door).
16. Close freezer door. Have an assistant lift up on opposite side of the door while tightening screws to install top hinge.
17. Flip top grille and reinstall.
18. Plug in electrical power cord and turn refrigerator temperature control to center position. Adjust setting as needed.
on Oct 19, 2011 | Frigidaire Refrigerators
Passenger door is offset, thus pushing the front fender in when the door is opened. What do I need to replace? The door hinge? I'm trying to troubleshoot and help my son fix all the issues with his car.
The problem is ur DOOR HiNGE BUSHiNG! Test ur DOOR if it moves by lifting up, if it moves look at how the hinge plays, the BOLTS might only be loose and needs tightening! Replacing the HiNGE BUSHiNG, pull out the PiN, that holds the hinge from the door to the body panel. Look at the center hole, notice a copper/brass bushing, take it off and replace w/ new one! U need 4 pcs. for each door! Hope that might help u out! Taah!
Nov 12, 2010 | 1995 Chrysler LeBaron
Driver door has dropped about 1/2". I see a torx
Before attempting to adjust the door, you need to check the wear on the hinge pins. Open the door fully and look at the middle of the hinge. See the pin there? Lift up on the latch side of the door as you watch the hinge pin. If you see the hinge moving around the pin or see the pin shifting back and forth then the metal grommet the pin goes through is worn and needs replacing. Motormite makes a replacement pin set that comes with new grommets ( or bushings to some). It's not so hard to change, but it can be a little tricky. Jack up the door to relieve the pressure on the pin.Start with the top pin. Watch the pin as you jack and keep going until the pin is in the middle of the movement range. Tap the old pin out and then inspect the grommet to see if it's worn past the outer edge of the metal. If it is worn past the edge then you'll need to replace that hinge. Otherwise, you can use that old pin to tap out the old grommet, and replace with the new one, then the new pin. slowly release the pressure on the jack and watch the new pin for excessive movement, then do the bottom pin and grommet.. Test door swing and alignment. If the door still hits low on the catch post, loosen those torq bolts after lifting the door slightly and now lift the door the distance it was low plus 1/8 inch. retighten torq bolts and release jack, then retest the door alignment to the catch post. Don't let the door strike the catch post hard - just let it slowly come into contact as you watch for alignment. Repeat procedure until door lines up centered on taht catch post.
Good luck!!
Nov 07, 2010 | 2001 Dodge Durango
How do i replace the bushing on the slider door
1. Remove sliding door trim panel , watershield, and access hole cover plates.
2. Unlatch pizza sliding door.
3. Remove latch actuator rod retainer from center door retainer hole.
4. Disconnect pizza rear door latch actuator rod from pizza remote control assembly by opening pizza clip.
5. Open pizza door sufficiently to gain access to pizza three bolts attaching pizza rear latch to pizza sliding door. Remove bolts.
6. Remove pizza sliding door rear latch with pizza remote control actuator rod attached to pizza latch, from pizza sliding door.-------------
First you need to get the right tools for the job and the right parts to fix the problem.There is a hinge pin in both the upper and lower hinges and four brass bushings and there is two different size bushings in each hinge and also two hinge pin retaining washers.as for the tools you need a spring compressor,jack,hammer,punch. First open the door all the way,put jack under door,I like to use a 2by4 board on top of the jack to help spread the wieght of the door out a little,next if the door has a wireing harness in the jamp loosen the rubber insulation form both the door and the body this gives a couble of inches of slack in the wireing.Next use the spring compressor to remove the spring,then use the punch and hammer to drive out the pins.it is very hard to get them to move an first but gets easyer as they start to move.I would recomend having a helper to hold the door upright as it will fall when the pin is removed from the hinge.Onece the pins are out move the door and jack away from the body to gain more axcess room the replace the bushings,two in the door side and two in the body side,then slide door and jack back and align hinge holes and install new pins. I allways grease the bushing and pins before installing.Drive the new pins all the way flush with the hinge and install the retainers.Reinstall the spring and reattach the wireing insulation. ------- Open the door so it is directly above the bench. Observe how all the fasteners, be they bolts or pins with bushings, are aligned. Generally, the bolts and pins point toward the center of the hinge from the top or bottom, The bolts and bushings are on the body-side bracket for the upper bracket and the door bracket for the lower one. This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya
Apr 01, 2010 | Mercury Villager Cars & Trucks
93 silverado 2500need free online mechanical diagram of doors
GM Full-Size Trucks 1988-1998 Repair Information Doors - REMOVAL & INSTALLATION
R/V Series
See Figures 1, 2 and 3
If the door being removed is to be reinstalled, matchmark the hinge position.
  1. If the door is to be replaced with a new one, remove the trim panels weathersheets and all molding.
Fig. 1: Door hinge-R/V Series
  1. If the door is to be replaced with a new one, remove the glass, locks and latches.
  2. If equipped with a wiring harness, remove the trim panel and disconnect the harness. Guide the wiring out of the door.
  3. Support the door and remove the hinge-to-body attaching bolts. Lift the door from the truck.
  4. Install the door.
  5. Perform the alignment procedures indicated below.
Fig. 2: Door hinge components-C/K Series
Fig. 3: Removing the hinge spring
C/K Series
  1. On trucks with power components in the door, disconnect the battery ground cable.
  2. On trucks with power components in the door, remove the cowl side vent cover.
  3. On trucks with power components in the door, disconnect the wiring going to the door, under the dash panel. Feed the wiring through the door pillar.
  4. Cover the door hinge spring with a heavy towel. Using tool J-36604 or its equivalent, insert the blades of the tool between the spring coils and turn the barrel nut to compress and hold the spring. Remove the spring using the tool.
  5. Remove the lower hinge pin retainer.
  6. Using a plastic or rubber mallet and locking pliers, remove the lower hinge pin.
  7. Install a bolt through the lower hinges to hold the door while removing the upper hinge pin.
  8. Remove the upper hinge pin retainer.
  9. Remove the upper hinge pin.
  10. Support the door and remove the bolt from the lower hinge.
To install:
  1. Position the door and install the bolt in the lower hinge.
  2. Install the upper hinge pin. with the pointed end up.
  3. Install a new upper hinge pin retainer.
  4. Remove the bolt from the lower hinges.
  5. Install the lower hinge pin with the pointed end down.
  6. Install a new lower hinge pin retainer.
  7. Using tool J-36604, install the hinge spring.
  8. On trucks with power components in the door, connect the wiring going to the door, under the dash panel. Feed the wiring through the door pillar.
  9. On trucks with power components in the door, install the cowl side vent cover.
  10. On trucks with power components in the door, connect the battery ground cable.
ADJUSTMENTSee Figure 4 The holes for the hinges are oversized to provide for latitude in alignment. Align the door hinges first, then the striker.
C/K series utilize hinges that are welded to the door and frame. No adjustment is possible except when replacement hinges have been installed.
Fig. 4: Door adjustment check points
  1. If a door is being installed, first mount the door and tighten the hinge bolts lightly.
If the door has not been removed, determine which hinge bolts must be loosed to effect alignment.
  1. Loosen the necessary bolts just enough to allow the door to be moved with a padded prybar.
  2. Move the door in small movements and check the fit after each movement.
Be sure that there is no binding or interference with adjacent panels.
  1. Repeat this procedure until the door is properly aligned.
R/V Series:
Door edge-to-rocker panel: 6mm Door edge-to-roof panel: 5mm Door edge-to-rear pillar: 5mm Door edge-to-front pillar: 2mm
C/K Series:
Door edge-to-rocker panel: 6mm Door edge-to-roof panel: 6mm Door edge-to-rear pillar: 4mm Door edge-to-front pillar: 7mm Door front edge-to-fender: 5mm
  1. Tighten all the bolts to 26 ft. lbs. (35 Nm).
Shims may be either fabricated or purchased to install behind the hinges as an aid in alignment.
Hope this help, TY for using Fixya (remember comment and rated this). Good luck.
Apr 01, 2010 | 1994 Chevrolet Silverado 2500
Driver's side door not latching / closing
pull the outside handle and unlatch the latching assembly by hand by insertins a screwdriver where the striker would normally be if the door were closed - and pry out.
You can adjust the striker by loosening the bolts, and moving it in toward the cabin.
If the door itself is droopy, adjustments are made by the hinge by loosening the bolts and lifting up or down.
Multiple attempts will be necessary to get it just right.
Dont get frustrated if it doesnt fit properly in the 1st or second attempt.
Good Luck!!
Jan 16, 2009 | 2000 Chevrolet Blazer
94 jeep cherokee door troubles
from the late 80's to the 90's jeep cherokees have a known problem with there front door hinges. the first time i seen this on a jeep i thought it was a fluke but now owning a 93 cherokee i am goin through the same problem... most of the time its not the door pins (i am not saying this is not what is wrong with yours, but for the most part it is not the pins). on the inside of the sheet metal, where the door hinges are welded onto, tend to rust/wear out and cause up and down play in the top door hinge. the only way to fix it is to take the door off and reweld a new brace or support underneath the sheet metal, and the weld the door back into place... my jeep is goin threw this process right now... but if you dont fix the door soon it will acually rip the top door hinge out of place, allowing the door to almost touch the ground when opened.
Sep 27, 2008 | 1995 Jeep Cherokee
69 chevelle
hello..!!! no the bolt's to the door hinge are on the inside .!!! when you open the door you can see then .!!! where the hinge is .!!! you can't miss them.!!! the only other thing is that the door might have bad pin's and bushing .!!! and that's why it move's up and down.!!! becouse there wore out.!!! and need to be replaced.!!! hope this help's you let me know ."good luck"
Aug 06, 2008 | Chevrolet Malibu Cars & Trucks
Hardware & Accessories Logo
100 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
