Question about SanDisk 2GB microSD Memory Card
How to format a sd card sdhc card 4 gb - SanDisk 2GB microSD Memory Card
  • 31 Answers
If your using it by phone you go on to phone setting and memory manager then format the memory card
but if your wanting to format by pc
you need to go on my computer and right click there should be a menu saying format ect you need the format.
but if there is not format
just click on the memory card the wipe everything off
Posted on Aug 02, 2010
My lg does not read 2gb sd card.it tell me to insert a new one.Bt it can read 128 mb sd card
Your 2 Gb is not just an SD card, it is a SDHC card. The first 2Gb SD cards, still were SD, but 2Gb was the limit for the FAT 16 and 32 format and for the normal SD cards. The same happened with the hard disks. They developed the SDHC card, and made the new hardware downward compatible with the old SD cards. So in a new camera, you can insert SDXC, SDHC, SD and even MMC cards. But the cameras, card readers and phones, who were made for SD, can't use the SDHC or SDXC cards.
SDHC can work with memories up to 32 Gb and from that on, it is SDXC.
There still should be some 2Gb SD cards around, but not sure you still can fine one. The producers of memory cards now only make SDHC cards and up. Perhaps you only can get some 1Gb cards as SD card, but perhaps nobody will ever make these cards anymore.
I mannaged to buy a 4 GB SD card a few years ago, but that was the last I ever saw in the capacity. 25264488-uil2tdgcy05knvgzh4oup5lj-2-0.png
Nov 01, 2014 | Cameras
I have a Polaroid i1032 10.0 megapixel camera. the user guide says that i can use up to a 1 gb SD memory card. I've used a 2 gb SD card and it works fine. My question is can I use SDHC cards 2 gb, 4 gb, 8...
At the time your camera was made, 1GB was the max size standard SD card. Then along came 2GB standard SD, but this card also used the same format as previous cards, so yes it also worked in your camera. Now SDHC is a very different format with different file handling (although externally it looks exactly the same). I'm sorry to say, it is very unlikely that SDHC will work with your camera. Here on Fixya you'll see many folks asking why the brand new card they just bought doesn't work with their older camera. 9 time out of 10, this is the reason why.
Mar 22, 2011 | Polaroid i1032 Digital Camera
4 gb sd card not formatting
The C663 works with SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to go with SD cards, 2GB and smaller.
Nov 25, 2010 | Kodak EasyShare C663 Digital Camera
I purchased a 4 GB SDHC card for my kodak easy share dx6440. The camera keeps rejecting it because 'it is not formatted'. I formated it and it still does not read it. is the DX6440 limited to SD 2GB? ...
The DX6440 uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You are limited to SD cards 2GB and smaller.
Nov 09, 2010 | Kodak EasyShare DX6440 Digital Camera
Can not format a 4 gb sd card to my camera
The C340 uses MMC and SD cards. Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Oct 26, 2010 | Kodak EasyShare C340 Digital Camera
SDHC Card 4 GB SanDisk will not format. get
The Z740 uses SD cards, not SDHC cards. SDHC cards will physically fit into the card slot but are not compatible. It's a hardware incompatibility, not updatable in firmware. You'll have to stay with 2GB and smaller SD cards.
Feb 06, 2010 | Kodak EasyShare Z740 Digital Camera
My Kodak P850 do not accept SD cards 4 or 8GB, error message state that memory must be replaced. No way to format the SD in camera. How can I do that camera accept the SD card
Technically speaking, SD cards only go up to 2GB. (Actually, some very rare 4GB SD cards exist, but I doubt you have one of those.) Cards 4GB and up are SDHC (Secure Digital High Capacity) cards. Your camera was designed before the SDHC specs, and thus is not compatible with SDHC cards. This is not something that can be changed in firmware, since there is a hardware compatibility issue.
SDHC devices will accept SD cards, but the opposite does not hold true. SD devices will not accept SDHC cards.
Jan 18, 2010 | Kodak EasyShare P850 Digital Camera
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Oct 19, 2009 | Canon PowerShot A620 Digital Camera
Same as yours
The Z740 supports only MultiMediaCards & SD Memory Cards. 4GB and larger SD cards are usually SDHC (Secure Digital High Capacity) types - and bear the SDHC mark on the label. These cards are not compatible with this camera. Use only MMC and SD cards. SD cards are 2 GB and under - although *some* 4 GB cards are marked as SD too; these cards may or may not work. If you purchase a 4 GB SD (not SDHC) card, make sure that it can be returned if it doesn't work reliably in your camera.
Oct 05, 2009 | Kodak EasyShare Z740 Digital Camera
SanDisk 2GB microSD Memory Card Logo
93 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
