Question about Sony KV-36XBR450 36" TV
KV-36XBR200 Green in lower left corner
Hello Fixya,
My XNR200 is about 7 years old. Recently, the color in the lower left corner is green. For example, when watching a hockey game with a white sheet of ice, the lower left corner of the screen is green - about 12" tall by 4-6" in. I've reset everything and turned the TV off for 24 hours. It is still gree in the corner. Is there anything I can do to fix it?
Thanks,
mike
    Genius:
  • Sony Master
  • 1,689 Answers
The most common cause is, shadowmask inside of the CRT is magnetized. It sounds by your description that the TV's internal degausser for the CRT is not working. This is serviceable by a service tech.
Most of the time the cause of a failed degausser is the thermoresistor. This is a common type of failure.
Another cause that can show the fault you are seeing is if the shadowmask in the CRT is defective. Sometimes the mask is damaged when the set is being moved, and is accidently banged against something. The CRT is sensitive to this type of treatement.
If the mask inside of the CRT is defvective, the only fix is a new CRT.
Jerry G.
Posted on Apr 25, 2008
Green and purple shadows in the left upper corner
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Hello. I am trying to change my Y color toner but only the blue color is accessible. How do I get the printer to move the cartridges so that Y/yellow is accessible to change? By the way, I LOVE this...
The instructions for this are posted on back left of the front panel when open. As indicated, push the green button in the lower-left corner with an embossed "1" next to it. Then, turn the green knob next to it with an embossed "2" next to it until the next cartridge is fully visible and the button from step 1 pops back out. Repeat step 2 until the correct cartridge is in place. Then pull the green handle above and to the left of the cartridge.
Aug 22, 2009 | Konica Minolta magicolor 2300DL Laser...
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Intermitant color bursts of red, green, purple
Kevin,
for the color problem,most likely you do have problem with loose contact of components from C-board ( small board connected at the back of CRT "picture tube" which drives every color and size of the screen)if you have knowledge with soldering electronic component parts, resolder this board and also check main board for possible loose contact.
cheers,
mark
Feb 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Yellow spot in lower right hand corner
You have pretty much narrowed it down to being a bad optical block. This isn;t good news, since the optical block is probably the most expensive part in the set. Your best bet is to contact Sony customer support to see if the will allow some kind of accommodation for the repairs. Sorry for the bad new; hope it doesn't effect the rating you give me for the solution. Thanks!
Nov 11, 2008 | Sony Grand WEGA KF-42SX300 42" LCD TV
Philips Rear Projection Issue with Color Alignment.
this seems to be convergence problem in your tv .............
Aug 23, 2008 | Televison & Video
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Jun 04, 2008 | Zenith A36B41W 36" TV
Green colors are seperated from rest
You might have a bad green convergence output IC either loose from the circuit board or open internally OR shorted. Stargazer
Apr 22, 2007 | Pioneer PRO-99 TV
Sony kv-32hv600 picture problems
Problem 1. Color patches at lower corners. These are caused by magnetic sources close to the TV. Do you have any Speakers close to the sides of the TV? Are they Magnetically sheilded? No? Move them away from the TV. Problem should then resolve itself in a couple of days. Problem2. Screen Slumping. Most likely a problem with the Pin cushion correction ckts. Get a good technician to have look. cost should not be much. Under 100$ plus Technician fees.
Aug 18, 2006 | Sony FD Trinitron KV-32HV600 32" TV
Screen Color Looks Like a Rainbow
Good day.
The problem includes malfunctioning of you units deflection yoke, color circuit and failures in the chroma system.
Have it check by a repairman.
chris
Aug 04, 2006 | Toshiba 36A40 36" TV
Sony KV-36XBR450 36" TV Logo
74 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
