Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Coin stuck in insinkerator disposal - Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
  • Ace Hardware Master
  • 43,501 Answers
Hi, A long needle nose pliers or if you are proficient with chop sticks...
Here is a tip the I wrote that may help you to figure out what is going on withyour garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Posted on Sep 23, 2010
A spoon is stuck in the disposal, any suggestions?
You might have to drop the disposal free from the sink to get vice grips on the spoon.
I wrote EZ disposal replacement tips, that include how to remove and reinstall disposal and tubular drain pipe.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jun 23, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My mother-in-law's insinkerator shakes violently when turned on. She believes I broke it when I put some small watermelon rinds down it recently. Any advice?
You cant break stainless steel cutter blade, welded parts and steel ball bearings with water mellon rinds.
Even a metal fork should not break a garbage disposal ... the fork will wedge against the side wall and cause cutter blade to get stuck. Once the fork is removed, no damage is done.
If insinkerator is shaking, then either a bearing has rusted out, or the shaft has finally worn out.
The stainless cutter blade is permanently attached to a steel shaft that goes into the sealed bearing. If the cutter weld is broken, then the disposal will wobble. If the bearing wears out, then the steel shaft will wobble. If the steel shaft is worn down at the bearing, then the cutter plate will wobble. A tiny bit of wobble will cause the disposal to shake. A brand new disposal will vibrate.
Check date of purchase receipt.
Amazon shows warranty is 2 years:
http://www.amazon.com/InSinkErator-Badger-Food-Waste-Disposer/dp/B00004U9JO/ref=sr_1_3?ie=UTF8&qid=1303015273&sr=8-3
If disposal is 3-5 years old then that is a short lifetime for a solid product like the 1/2 HP.
If disposal is 5-8 years old, that's a good run. 8-12 years is very good.
I wrote tips for replacing disposal from days when I worked apartment maintenance:
We replaced disposals every 6-7 years. Some never wore out. Others went bad right away.
Apr 16, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
What will happen if a coin falls into a garbage disposal
It will bounce around in the disposal and make a lot of noise. Best case, it can become lodged between a beater arm on the rotor and the cutting holes along the side of the disposal and lock your disposal up. Worst case, it's possible for the beater arms to hit it in a way to send it flying out of the disposal. You really need to remove it, it will never get chopped up enough to pass through the disposal. Take out the rubber insert in the sink and fish out the coil, if you're good with them chop sticks work great for this.
Jan 28, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: I have a Badger InSinkErator, it suddenly just sto...
May 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Blades are stuck! Help!!
have been a pluming mechcanic (yes no license) for 25 yr's and have never ben able to replace blade's on any disposal , from any manufact. do believe some blade's are stationary.
Apr 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Badger InSinkErator 1/3 hp has cloth stuck beneath blades. Does not turn. Can I fix?
peeling potatoes for Thanksgiving and now my disposal will not work. Yes, have tries reset button and not working. When it's plugged in it just makes this strange noise. Please help
Sep 23, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal will not go on. Breaker is on, reset has been tried.
Yes. It is possible. Is the push button in with this switch box? Because the push button could be bad.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jay_17408fb1a2cad107
May 24, 2009 | Emerson InSinkErator STC-BLK Sink Top...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
745 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
