Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Water is draining into the refrigerator. It fills
Water is draining into the refrigerator. It fills up the draws in the frig. The drain pain underneath is dry. How do I unclog the drain.
    President:
  • 1,218 Answers
Good day,
In the freezer if it has an ice maker, it will have to be removed.
Remove the back panel. Below the cooling coil is a drain pan.
It has a drain hole in it. If it is iced over you will have to defrost it, with the machine off.
Many use a hair dryer, but hot water with a turkey basting tool is
safer.
Once the drain hole is open, you will have to follow thru since the water drains into a cup in the fresh food compartment then thru the back wall into a drain hose on the rear.
Blockage can occur anywhere thru that area.
Service techs usually use compressed air with a hose to blow the lines clear.
If you have no access to something like that you wil have to get creative. Removing all the components and flushing them out is one option.
Posted on Aug 02, 2010
Water collecting under bottom draws inside frig
That water is very likely dripping from the freezer because the drain for the defrost is blocked,so instead of the water draining its dripping through the vents down under the crispers. This tip i wrote will help ya to clear that drain to keep the water from dripping through the vents.
http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 14, 2011 | Magic Chef CTF1826AR Top Freezer...
Kenmore model # 2571832104 water is leaking inside from Refrigerator control. I have a container catching the water. Was away for a month and crisper baskets were completely filled with water. Drain pan...
the evaporator drain is plugged up and when it defrosts it overflows down thru the damper vent door into the refrigerator compartment you need to remove rear inner panel in freezer and get drain hole unplugged with a wire
May 29, 2011 | Refrigerators
Water at bottome of refrigerator
Under the draws in the back, there should be a drain hole that drains water down to the drain pan under the unit. Check to make sure it's not blocked with food or frozen water.
Jul 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
I am geeting water on the bottom shelf of my
There is a defrost drain located at the rear wall inside the frig.
I usually take a large syrenge with a rubber hose attached to it. I fill it with hot water and insert it into the drain cup sealing it to the small hole at the rear of the cup. Force the hot water through the hole in the rear of the cup and this should clear anything stuck in the drain.
I hope this helps.
Dec 31, 2009 | Refrigerators
Leaking water into frig when defrosts
The problem is the defrost drain is pluged. At the rear of the frig section up at the top you will see a small cup where the water drains into. I always used a large syringe with a rubber hose attached. Fill the syringe with hot tap water and flush the ice out of the drain tube. Once cleaned out and the water runs freely your problem will be solved.
Dec 27, 2009 | Kenmore Refrigerators
We have a refrigerator model ET18NKXFW03 that drips water from the ceiling of the frig. We put a pan to collect the water but several times a week a stream of water leaks as well. It seems to happen more...
You will need to remove the food from the freezer and remove the ice maker if so equipped . Remove the 2 screws from the bottom freezer panel ( you will probably see a layer of ice here ) , and the 2 screws holding the inside rear freezer panel . Using a hair dryer , start in the center , below the coils , defrosting , until you see a drain hole . You want to defrost this hole ( hot water helps ) until water starts to flow down . Use a small hose inserted into the drain hole and blow thru it , to remove any unseen debris , built up inside the drain line . Reassemble the freezer .
Oct 11, 2009 | Whirlpool Refrigerators
My freezer drain line must be stopped up. It fill the freezer with water and freezes a thick layer of ice. It then drips in to the frig!! How can I upstop the drain line? I have poured hot water and used a...
The backed up ice must be completely removed and the line cleared all the way to the collection pan.make sure the frig is positioned so the water drains quickly. you can also wrap a piece of 10 gauge copper wire around the defrost heater and allow it to stick into the drain hole a few inches without touching the drain tube to keep it from refreezing again. Eric
Aug 11, 2009 | Refrigerators
Kenmore 106.78202890 Ref. Icemaker seems to work fine. No water leaks when it fills but I have water in the refrigerator section that seems to be draining from the freezer. Any ideas?
Hi there, I believe you may have a defrost drain problem. See the water has to drain somewhere else when the drain is stopped up. So instead of into the catch basin on the bottom of the frig it cascades down the backside of the frig and ends up under the crispers. To fix the problem you must clear the defrost drain. It is located beneith the evaporator coils. When the frost on those coils melt it turns to water. Remove the freezer access panel, and clean out the drain. Use some hot water or a shop vac.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 12, 2009 | Refrigerators
Water acculation in refridgerator.
I had a similar problem with my old hotpoint frig (top freezer, bottom frig). the defrost cycle would come on and melt the ice, but since the drain plug in the back of the freezer below the coils would eventually freeze up closed due to ice accumulation. It got to the point I had to shut down the whole unit and leave it open for around 8 hours to let it naturally melt the ice in the drain tube. I hear a gurgle sound and then a sound of water flowing, so I knew it was now draining again.
Jun 08, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
113 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
