Question about Peg Perego John Deere Gator HPX Ride on Toy
Our John Deere Gator stopped running. The battery
Our John Deere Gator stopped running. The battery is fine and I attempted to check the wiring and swithces. After some manipulation I was able to get one side motor running and only in 2nd gear. Any help would greatly be appreciated
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Bad motor, you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 13, 2012
3 Suggested Answers
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
espressonist
  • 1711 Answers
SOURCE: I have a John Deere
From your description the problem is a motor problem. You should turn the wheel manually and is it can rotate freely, if not then the motor is stuck and you can check the ball bearing if it is rusty or dirty or both and this can make it hard to rotate and that is why it become warm.
Posted on Nov 13, 2010
Bought new battery for the john deere gator ride on toy but only runs for a short time then battery needs recharging
Hi, How long does it run? Typically you should get at least 45 min of run time out a fully charged battery. If it's slowing gradually and dying in just a few minutes its the battery. If it's goign full speed and then stopping suddenly, it's probably the thermal breaker located in the shift mechanism.
Aug 25, 2014 | Peg Perego John Deere Gator HPX Ride on...
The gator was running and just stopped. I checked all the wiring and recharged the battery. It will not go in any gear. I also checked the fuse.
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Aug 28, 2010 | Peg Perego John Deere Gator HPX Ride on...
We have a John Deere peg perego gator that was working fine last summer and this summer will not even start at all. The battery is charged. Any suggestions?
Jul 13, 2010 | Peg Perego John Deere Gator HPX Ride on...
Gator wont run put new battery in.last summer would work fine
Jun 30, 2010 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
Apr 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator not responding with new battery.
I upgraded my Peg Perego shifter and it came with the wiring harness.
I bought it at http://www.shopjandl.com/
Hope this helps.
Jun 20, 2009 | Peg Perego John Deere Gator HPX Ride on...
Old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Dec 15, 2008 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
563 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
