Question about Whirlpool Refrigerators
Fridgerator is freezing everything even at lowest setting it is an whirlpool energy star side by side
    President:
  • 1,099 Answers
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check the plastic air deflector at the top rear of the frig had been knocked off. I replaced it and all is OK. I thought you might add this to your suggestion list. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Hope this helpout in solving your problem
Posted on Aug 02, 2010
My refridgerator freezes everything even on the lowest setting
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 20, 2011 | GE GSL25JFPBS Side by Side Refrigerator
The fridgerator keep freezing the food. it is on the lowest setting but still it freezed the food. whirlpool MODEL: ET18NMXAW03 SERIAL: ED3042768 have had someone tell me to clear the food so that it...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 25, 2011 | Whirlpool Refrigerators
Have a whirlpool refrig. both sides freezing up even when set on lowest level model # ed5phaxtsoo cleaned coils fan runs allthe time.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
JCD2290HES Side by Side Refrigerator: my jenn air side by side is freezing everything an...
i have the same problem i clean the coils and work for two weeks and now is freezing need solution thanks
May 16, 2010 | Jenn-Air JCD2290HES Side by Side...
Freezer temp turned down but still freezing everying
just look for a better fan to buy to prevent the compressor from having problem . thanks.
Feb 15, 2010 | Freezers
WATER DISPENSER FREEZES THE TEMP IS SET ON THE LOWEST SETTING. FREEZER IS FINE
There is a heater kit , pt # WR49X10173 , which can be installed . This part comes with instructions on how to install .
Nov 08, 2009 | GE Profile¿ Arctica® Energy...
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
Refrigeration side of my side by side is freezing
only the thrmostat cost around 80.00rands
May 12, 2009 | Whirlpool Refrigerators
Produce freezing
I had the same problem when one of my kids changed the setting of the chef's pantry (full-width drawer) to higher setting and everything started freezing. The setting should be at "lowest setting". Give it a try. deborah.
Feb 07, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Refrigerators Logo
155 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
