Question about Nintendo Wii Console
Suddenly the power doesn't come on. We've checked batteries and made sure all wires are connected but it still won't come on. It's like it's "burned out". What should I do?
    Problem Solver:
  • 10 Answers
Disconnect your wii and leave it alone for some time then reconnect it if it still doesn't work then try this process again till it dose work
Posted on Aug 02, 2010
My 95 sierra dies and won't start. no lights on dash then suddenly lights come on and truck will start. please help.
first check the connections at the battery. make sure there is no corrosion between the cable end and the battery.
When you say it wont start can you hear the starter cranking the engine over or is the vehicle completely dead?
If its completely dead I would check for power to the ignition switch. if there is power than I would check for power out of the switch. If there is no power than possible the ignition switch is failing.
I might be able to get you some wiring info if needed. just let me know.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Apr 02, 2013 | 1995 GMC Sierra
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
My harley wont turn over
Instructions
    • 1
      Make sure the key and kill switch are both in the "on" position. Ensure that the proper starting procedures for your bike are followed. Is it in neutral? Clutch pulled in? Gas in the tank? Then try to start your bike. Does it turn over? If not, check to see that the battery is properly connected and the terminals are not corroded. If they're loose or dirty, clean and tighten them. Then, using a voltmeter that measures ac/dc and ohms, check to see that your battery has enough charge to crank the engine. If not, replace or charge your battery and try again. If it still doesn't turn over, there may be a loose connection between your battery and starter; a bad ignition or starter switchl or a bad safety relay. Check a repair manual for proper testing procedures for your bike, as each motorcycle differs.
    • 2
      If your bike turns over but doesn't catch, check to see that it's getting fuel. If the bike has a fuel petcock, make sure it is in the "on" (or, on certain bikes, "prime") position. Then remove the main fuel hose and check to see that fuel is flowing freely. If fuel isn't getting to the carburetor or injection system, your bike won't run. If that's the case, your problem is likely something in the fuel system. If fuel is flowing freely, reattach the lines. If it's not, check to see if the fuel filter is clogged, if a line is pinched or if the petcock is working properly. One way to determine if the problem is in your fuel system is to put a few drops of fresh gas into each spark-plug hole, replace the plugs and turn the bike over. If it starts and then quits, the problem is likely in the fuel system.
  • If you're getting fuel and the bike turns over but still doesn't catch or start, check the spark plug or plugs. Start by pulling off a spark plug wire, then removing a plug using the spark plug socket supplied in your bike's toolkit. Now inspect the plug. It should not be wet (usually caused by fuel, when the plug is not firing) or coated in carbon/burned oil deposits. Now check to see if the bike is getting spark. Although you can get a special, insulated set of pliers to hold the plug, there's a "quick and dirty" method for this: After reattaching the plug wire, lay the threaded part of the plug against the engine (not over the plug hole, as the spark could ignite any fuel that is blown out when you try to start it). Now, making sure you're not in contact with the engine or plug, hit the starter. You should see a nice blue spark. If you don't, make sure the threaded portion of the plug is touching the engine (but the electrode is not) and try again. If you still don't see a spark, you either have a bad plug or a problem with the electrical system. Check to see that all the ignition wires are properly connected and that you can't see any cracks in the wires. If the wires are cracked, they should be replaced. If you're still not getting spark, it's time to consult a repair manual or call a mechanic.
  • 4
    If you've got fuel and spark, ascertain that your bike is getting enough air. Start by pulling off the air filter. If it's too dirty, you won't get the proper mixture of air and fuel in the carburetor or injection system. If it's clean, check to see that the air box is properly connected-- a loose hose or air leak can feed too much air into the system. If your bike is equipped with a choke, ensure that it's able to move freely and is not stuck in the "on" or "off" position.
  • 5
    If you've followed these steps and still can't get your bike to run, call in an expert. If you think you've narrowed down the source of the problem, describe the steps you've taken to point the mechanic in the right direction.
  • Buy F150 Parts.
    Jun 03, 2012 | Harley Davidson FXR Super Glide...
    My 1988 toyota 4runner won't show signs of getting power despite new battery
    Hello, open the fuse box and look for a large 80A fuse, replace it if necessary, if it doesn't have the fuse some early versions used fusible link wire from the positive battery terminal instead, this is a fuse and will burn out inside the insulation if there is a short, check it using a 12 volt test light, you can get fusible wire from the auto parts store.
    Apr 22, 2017 | 1988 Toyota 4Runner
    My 1996 Olds LSS doesn't idle properly,idling surges sometimes,the temp. gauge doesn't work and sometimes the heater doesn't work.It may stall while driving.If I get in and the power seats...
    Your first problem is to find out why the intermittent no-power problem. Honestly, that sounds like a loose conmnection somewhere. check all your grounds for clean and tight conditions Also, battery connections and alternator connections. Double check your power distribution center for any loose wires or poor connections. Once you solve that problem, then you can diagnose the other problems with poor idle and temp. gauge.
    Oct 17, 2011 | 1996 Oldsmobile LSS
    I have a 2002 Buick Rendevzeous. Sometimes the driver side low beam works, sometimes it doesn't. When it doesn't, the turn signal won't blink. It just stays dimmly lit. Right now, the low beam...
    You have a bad electrical connection. Check the wiring harness and both sides of it's connectors for corrosion and or breakage. The connector terminals will become worn and corroded and the wiring sheaths a prone to weathering and become brittle. Replace or clean as needed.
    Sep 04, 2011 | 2002 Buick Rendezvous
    Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
    take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
    Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
    Replaced battery, bike started fine. Let it sit overnight, won't start. Won't even crank, just clicks once then nothing, the Neutral light shuts off and the lights started flickering.
    To begin with, I'd have that battery load tested to see if it's any good. I've seen brand new batteries that were bad. It it checks OK, check all the connections that go to the battery. Be especially attentive to the smaller wires that attach to it. I've seen battery acid eat the wire out of the insulation leaving the insulation intact and the wire appeared fine. If the wire bends too easily, be suspect. If the wires have the "crimp on" connectors, make sure they're tight. Your problem sounds like a bad connection somewhere.
    Good Luck
    Steve
    May 19, 2011 | Harley Davidson FXST Softail Standard...
    Nintendo Wii Console Logo
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Zhenya Ogorodnikov
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
