Question about Nikon Coolpix S4000 Digital Camera
When I play back video, the sound and the video are out of sinc. What's wrong? Also, the video seems to be in slower motion than it should be.
  • 182 Answers
Settings of Audio and Video speed are mismatched
Just go on to the settings options in the camera and restore/reset it to factory defaults
Cheers!!
Posted on Aug 02, 2010
Internet issue , web freezes or partially feezes..i,e audio but frozen picture..or audio in slow motion mode
Your memory is constipated from all the ---- you have running in background. Either add more memory, reboot when you have something critical, or add the ad block software to your browser to cut down all pop ins. DO you have an older computer with slower processor? That will do it also since nowadays they load the web pages with so much garbage that it is hard to keep up with for a slower, older cpu.
Sep 05, 2017 | YouTube Computers & Internet
My sound is real funny like chipmunk sounds
If the pitch of the sound being played by your computer speakers has changed dramatically or songs and videos are playing faster or slower than they typically should be, the problem is with the sound speed on your computer. This could mean a hardware issue with your speakers or sound card or a software issue with the program that you're using to play a digital media file.
Double-check your speaker connections. If one of the audio cables that runs off of your speakers isn't plugged correctly into your computer, this could cause the audio coming from them to speed up or slow down. Make sure all cables are properly connected to their proper inputs and try to play your audio again. Update the driver for your computer's sound card. Go to the website of the company that made your sound card and look for your unit's product page. Under the "Support" section, click on the download link for the latest device driver. Once the file is on your computer, double-click on it to install it. Then restart your computer and try to play your audio again. Make sure you haven't accidentally sped up or slowed down the media file you are trying to play. Many digital media programs like iTunes or Windows Media Player have features that allow you to play a song or video in slow or fast motion. If this becomes accidentally selected, the audio will also be in slow or fast motion. Click "Stop" to stop your media file from playing and then click "Play" again to allow it to play normally. Restart your computer. This will free up system memory when your computer restarts. If your sound was playing too slow or too fast due to an error with not having enough memory to play properly, that error will now be fixed and your sound should return to normal speed. Hope this helps.
Dec 28, 2012 | eMachines Computers & Internet
When I record a video using my Nikon Coolpix s4000, when I try to play it back the sound plays at normal speed but the picture is in slow motion! This happens everytime I record a video, is there anything...
Look for a Menu then FPS (Frames per second) option.30 fps should solve your issue. sometimes in order to keep file size low the setting is slower causing this issue.Good Luck.
Jul 29, 2011 | Nikon Coolpix S4000 Digital Camera
I am able to get the motion of the video but there
The C182 records audio but does not play it back. To hear your videos, first transfer them to your computer and play them back there.
Jun 01, 2010 | Kodak Easyshare C182 12MP Digital Camera
Quickplay on laptop plays everything slow motion and no sound, no sound for games most of time.
Are you running xp or Vista?
In XP go to device manager and expand list of IDE ATA ATAPI controllers. Right click on primary IDE controller and select properties. In advanced screen check primary IDE mode - that should be DMA.
IF that is in PIO mode - that is your problem.
Just click on driver tab in the same window and click uninstall.
REstart computer twice and problem should be solved.
Please leave your feedback if issue is solved
May 28, 2009 | Computers & Internet
Streaming Video Freezes sound continues
You have the wrong screen resolution. Lower your resolution and it will work fine.
Mar 30, 2009 | Acer Aspire 5920-6727 Notebook
Whenever i am trying to play video then the picture is ok in minimized mode but as i swith to full screen mode the picture starts playing in slow motion,Also while dragging the window the window moves in...
Most videos are a set size for viewing if you enlarge the viewing of them. They will run slower and be pixelated because it has more work to do to play it It is normal for this to happen.
You could try "VLC Player" and see if it makes a difference
I use it for all videos and music files
Jan 30, 2009 | Asrock P4I45GV R5 Motherboard
When playing DVD sound stutters and gets slower and slower
you have to look for audio uploads for your machine additional audio bass drivers
Jan 18, 2009 | Toshiba Satellite M105-S3021 Notebook
Blocks of noise
Don't know about the slow motion, but the noise is usually from dirty heads. Just like a cassette player it needs them cleaned periodically. Dip a Q-tip in rubbing alcohol and rub over the entire path the tape takes. You'll see a little block that actually reads the tape. Thats what you need to clean.
Make sure you eject the tape and remove the battery while the tape drive is open to clean it. Rubbing alcohol dries fast but give it an extra ten minutes and check it again.
Video recorder while the heads were dirty will not change however new video should be clean.
You may also have a bent tape carrier that is putting your video off track. It needs to be pushed or pulled to realign it.
It it's not the cause though, this can make playing back the earlier tapes more difficult since they will read and record in a slightly different part of the tape.
Jul 10, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
VIDEO ACCELERATOR NOT DETECTED
Sounds very much like a video driver issue. Most likely from the aspect that the video driver MAY not have compatibility with your reinstalled o/s. Look for the video driver option, under system then hardware configuration. You MAY need to remove that video from the list, then have the Plug and Play reinstall it. The driver is perhaps on the accessories disk you should have with your Dell.
Feb 02, 2008 | Dell Inspiron™ E1505 PC Notebook
Nikon Coolpix S4000 Digital Camera Logo
165 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
