Question about Magic Chef CGR3730 Gas Kitchen Range
HELLO, HAVE A MAGIC CHEF RANGE MODEL CGR374OADH PRE HEAT WILL NOT GO OFF. HELP THANKS RON
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Posted on Oct 18, 2007
  • 1314 Answers
SOURCE: magic chef range
if you give me a model number i be might be able to help try here get your model number off the serial plate from the range http://www.maytag.com/support/manuals_literature.jsp if that dont work reply to this thread with model number
Posted on Jan 15, 2008
  • 360 Answers
SOURCE: Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
Posted on Feb 07, 2009
Magic Chef CGR3742 Hi, I't has been pre heating, but took a very long time. Now it sometimes will heat up a little, but will not hold that temp. for long. I removed the bottom pan to see the burner and...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Magic Chef CGR3742 Gas Kitchen Range
My apartment has a small Magic Chef gas kitchen range, I don't know the model number but on the back top of the unit is a space that heat pours out of when I use the oven. is this supposed to happen?, is...
Yes,this is normal.
The heat must escape all ovens for them to function correctly.
The advantage is, you can place a pot or pan of food near the vent to stay warm while the baking continues.
Works good as a bread warmer wrapped in foil also.
Aug 23, 2010 | Magic Chef 31000 Gas Kitchen Range
Dimensions (especially depth) for Magic Chef 31213XAA gas range
www.magicchef.com/
Please get a manual from the above link. Or contact them. usually the dimensions are about 24" depth
Mar 28, 2010 | Kitchen Ranges
My magic chef stove model#31100paw oven will not heat up but all four stove burners are working just fin.what is going on?
This oven and range work from two separate regulators and it sounds like the one for the oven has failed. Have it replaced and that should get you going again. Hope this helps. Good luck.
Mar 15, 2010 | Magic Chef 31000 Gas Kitchen Range
Get too much of a gas smell when Magic Chef oven prheats up.
gas does NOT take that long to heat up!!
Shut that thing off before you kill your family !!!
Take it back or call someone to fix it !
This is a ticking bomb you have,...
If You smell gas then you should call the city or 911 .
Jan 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Fan in oven will not shut off, F-4
Hi jsachse,
The F4 fault code description is a shorted or open oven temperature sensor (RTD). Please check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Thank you for using FixYa.
Dec 18, 2008 | Magic Chef 31000 Gas Kitchen Range
Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
Nov 24, 2008 | Maytag MMC5000 Microwave Oven
Magic chef range
Jan 15, 2008 | Kitchen Ranges
Magic Chef CGR3730 Gas Kitchen Range Logo
47 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
