Question about Dell S2209W Monitor
My dell monitor screen, s2209w, is blinking and asks for password
My dell monitor screen, s2209w, has vertical gray lines with blinking white (dotted) horizontal lines. I can't read what the screen says exactly but it is asking for to "enter a password"
I took pictures of the screen the only thing I can make out is something about BIOS and enter password
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 53 Answers
Check in in the BIOS,(Press F2 key during the start up) if the same thing u see in than BIOS replace the monitor.
Posted on Aug 02, 2010
My dell monitor is too dark
There is a small light behind TFT screen which must have gone bad
Feb 15, 2013 | Dell S2209W Monitor
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
I have a Dell Monitor S2209W and it does not auto adjust when I change the resolution. It is connected to is a Dell PC running Windows XP. If I do not set the resolution to 1920 x 1080 the whole screen...
The S2209W is designed to be run at the optimal resolution of 1920 x 1080 http://support.dell.com/support/edocs/monitors/S2209W/en/ug/optimal.htm
selecting a lower resolution will result in generally unsatisfactory appearance. This is due to the hard wiring of the pixels in LCD screens.
What you can do to abate the text being too small is adjust the DPI setting from the default of 96 to 120, or even 144 if you need real large text
Oct 04, 2009 | Computers & Internet
Dell s2209w with a GeForce fx5200 blinks black
Make sure your refresh rate is not set too high. for the 192N it should probably be not much higher than 60Hertz
Jul 31, 2009 | XFX GeForce FX 5200, Graphic Card
My flatscreen dell monitor fades out to dark gray, sometimes pink
Its definetely the monitor thats having a problem. when it blacks out during th monitor self test. i suggest you can ask for a replacement monitor.
Mar 19, 2009 | Dell E193FP 19" LCD Monitor
My dell e196fp lcd monitor has white lines
Dell had a problem with horizontal lines in some of their monitors a little while back. I would try contacting Dell Tech Support to see if your monitor is one of the one effected. I think they were replacing the monitors that had the problem, but I'm not completely sure.
Mar 15, 2009 | Dell E196FP 19-inch Flat Panel Monitor -...
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
A big white vertical static band appears as soon a i turn on the power
Some of the transistors or the connection to the panel inside the monitor are damaged. There is no absolute fix for this problem.
You can try pushing on the bezel (NOT ON THE SCREEN) of the monitor at the edge of the screen directly at the lines and you may be able to push the connection back together well enough that the line goes away, but usually in desktop monitors the bezel is too rigid to allow you to put any pressure on the connections at the back of the LCD panel.
Mar 30, 2008 | Sony SDM-P234/B 23" LCD Monitor
Dell 1704fpt Screen turns white
ok,your monitor has a defective vertical ic.when vertical ic is defective you can see the horizontal line.
Oct 18, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell S2209W Monitor Logo
190 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
