Question about KitchenAid Refrigerators
My model is a Side by side KSRP25F,25.3 Cubic feet. Every once in a while my ice maker stalls and does not make ice. The,all of a sudden it starts again ,makes a few cubes and stalls again. can you help me??? Carlos Puerto Rico
    President:
  • 1,554 Answers
Visually check the icemaker when it stalls. The ice maker arm must be fully lowered to "ON" position. Check for free movement of the feeler arm and remove any ice cubes that may be keeping the feeler from lowering to the “ON” position. Thaw the fill tube if frozen or blocked with ice. Otherwise, proceed to the next step.
Check for ice or water in the mold. Either the icemaker has failed, the voltage to the icemaker is missing or there’s a problem with the water supply if the mold is empty. Proceed to the next step if water supply is okay.
Jump out the icemaker thermostat by shorting test terminals H to T
thermostat and the icemaker should start. Check voltage to icemaker if it fails to start. Replace the icemaker if voltage is present; otherwise, check wire harness and connection to icemaker.
Check for heat at the bottom of the icamaker if it starts. Replace the icemaker if there's no heat. Allow the icemaker to advance to fill cycle. Check voltage at water valve if it doesn’t energize. Check the wire harness if no voltage to water valve. Replace the icemaker if the harness is okay. Troubleshoot the water supply if the water valve energizes but no water enters the icemaker.
Feel free to update us about the development of the troubleshooting and repair. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 02, 2010
Water dispenser is not working. Ice dispenser is working
If your model is the PSS25MGMWW and the water dispenser is not workingthe problem is most likely the=> WR57X10026 Water Inlet Valve Most times the ice dispenser and water to the ice maker will continue to work properly while the half of the water control valve will fail and stop water to the dispenser or ice maker. Follow the instructions in the video and I will be here if you have questions, Thanks Sea Breeze
Sep 12, 2013 | GE Profile Arctica 25.4 Cubic Feet...
Won't dispense ice
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE Profile Arctica 25.4 Cubic Feet...
I just purcased a home that has a model KSRP25F Kitchenaid REFRIGERATOR built in 2004, 25.3 cubic feet. There is a red light flashing on the right wall of the freezer and the ice maker is not working. Also...
Go to the page here=> Appliance 911 at top of page and right side you will see Whirlpool Logo like this=> sea_breeze_151.jpg Click Here for this user manual=> KSRP25FNBL00_User_Manual.pdf There are many models that fall under the KSRP25F prefix so if answers to your question beginning on page 13 in user manual don't cover the answer to your question please contact me. Thanks, Sea Breeze
Apr 25, 2011 | KitchenAid Architect 25.3 Cu. Ft....
I have a model PSF26NGTA WW and the ice auger does not work, can you help?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 27, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
Dec 12, 2008 | Kenmore 53542 / 53544 Side by Side...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not working
the water valve soleniod on the lower back of frig. is bad,get the model number out of the frig. top right and replace,let me know-mike
Sep 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
73 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
