Question about KDS K22mdwb LCD Monitor
White screen KDS flat screen monitor
The screen on shows white
5 Suggested Answers
  • 55 Answers
SOURCE: KDS K717s 17" LCD Monitor
The white screen tells me that the display cable (inside your monitor) may be unattached or broken.
The color bands if they are vertical or horizontal lines tell me that your display cable needs to be replaced.
So overall replace your display cable. If this doesn't entirely fix the problem your logic board (inside the monitor) needs to be replaced.
Posted on Mar 14, 2008
  • 3940 Answers
SOURCE: KDS FLAT MONITOR
best I can tell, the Rad 5S is out of warranty, and you appear to be having a problem with the image inverter.
#1 Try the monitor on another system and ensure that the issue is the monitor, and not the video card it is attached to as the point of failure.
#2 If the monitor appears to be failing, contact a local TV repair shop on a repair estimate. Likely answer is that you can buy a larger better monitor cheaper than you can get the one you have repaired, even if the parts cost is low, due to the bench fee/labot cost of repairs.
Here is one site I like for monitors:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010190020+4017&name=%24100+-+%24200
Posted on Jul 25, 2008
  • 263 Answers
SOURCE: flat monitor..it only appear white in the screen...how to repair?
I think the monitor has had it unfortunately it would cost too much money to repair it , you would be better off buying a new one as they are so cheap nowadays.John
Posted on Jul 30, 2009
  • 55 Answers
SOURCE: I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Posted on Jan 05, 2010
Jan 05, 2010 | KDS Computers & Internet
Computer monitor doesn't show colors good only white and blue
Drivers not installed properlyu...install properly the driver, if then same proble check the VGA card for the desktop/ vga chepset chep in laptop.. or cable connection og vga...
May 31, 2009 | KDS Radius RAD-7 17" Flat Panel LCD...
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Problems with screen display colors
If you seeing an absence of greens it usually means your connector at the back of the flat panel are not tightened firmly. Use a screwdriver to get them snug. The same goes for the connector at the back of the PC.
May 09, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Feb 21, 2008 | KDS K717s 17" LCD Monitor
Reinstall of windows xp
This won't have anything to do with the monitor in the control panel, you should be looking at "Sounds and Audio Devices". Did the sound ever work?
Dec 19, 2007 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Black screen
Not enough information given! Do the monitor power light come on? Is the monitor making some type of noise? Can you feel satic on the face of the monitor
Nov 30, 2007 | KDS Avitron 195TF Monitor
Moniter
I resolve a similar problem by unplugging the power cord for three seconds.
Oct 12, 2007 | KDS Radius RAD-5 15 in. Flat Panel LCD...
KDS K22mdwb LCD Monitor Logo
214 people viewed this question
Top KDS Computers & Internet Experts
Denise
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
