Question about Porter Cable 7336 6 Inch Variable Speed Random Orbit Sander Only
How to change pad?
How do you unscrew the 6" pad? No screws are visable and if a wrench is needed I dont have one.
  • 700 Answers
This is easy done, just follow the steps:
1. disconnect the power cord
2. turn polisher pad up
3, grip firmly randomiser in one hand (that is this bulky bit between pad and polisher)
4. grip pad and rotate it against arrow direction.
if you just need to change the abrasive, these are on hook and loop and you just lift it from the pad and replace with new one.
this action will separate pad from randomiser, if you need to remove randomiser as well, you will need spanner of appriopriate size or adjustable.
you have manual available for download on this site:
http://powertool.manualsonline.com/manuals/mfg/portercable/7335_7336_7336sp_7355_7366_7424.html
if you find my advice useful, please do not hesitate to leave a comment and vote4 for me, thanx!
Posted on Aug 02, 2010
How do I open my Maytag dryer model # SDE305DAYW Legacy series?
Unplug
use a scrapper/puddy knife just under top find clips and push in on clips at same time pulling up on the top
Sep 17, 2014 | Maytag Dryers
Removing carbine 4011 deadbolt
remove the screws with proper screwdriver then perform the replcment
if u need any details
Oct 04, 2008 | Deadbolt RF Remote , Satin Nickel
How do i change the sanding pad Ingersoll Rand Ingersollrand Dual Action Air Sander - 6
It simply unscrews. The pad is held on by a small bolt length attached to the pad. Unscrew it.
Jan 15, 2012 | Ingersoll Rand Ingersollrand Dual Action...
How to replacet rhe frount break pads
Their is a flat head screw on the callipar. Unscrew it first. Inside of the flathead screw is an allen wrench nut. Break the allen wrench nut loose. Now unscrew the two bolts that hold the calipar in place. Remove them completely. Slide the calipar off from the disc. Finishing unscrewing the allen head nut that we talked about earlier. Pull it all the way out. Remove the shoes unless they fall out.. Easy to take out.. Blow off the calipar. Replace the shoes. Now put that Allen head screw back in that holds the shoes in place. No need to tighten it yet. Just snug. Spread the shoes apart by using a screwdriver being careful not to damage the pads. Large screwdriver. Slide the calipars over the disc and now put some locktight onto those two mounting bolts for the calipars. Tighten to about 40 lbs. Now tighten the allen set screw that holds the shoes in place. Replace the flattip screw that covers the allen head. Use a impact driver to tighten by hitting it once. Pull on break handle about 4 times to set the shoes to the disc. Do this before you start your bike.. You have brakes.. It was easy.. Way to go!!!
Jan 30, 2011 | 2004 Honda VT 1100 C2 Shadow Sabre
2000 sentra how to colapse rear brake calipers
Make your own tool using the old pads or 2 pieces of 10mm flat bar. Drill a hole in one of them(Drilling old pads is difficult - Theyre extremely hard). Flatbar is easier to drill. Weld a nut over the hole so that a bolt(should be about 80mm 2-3 inches) screwed into the nut will pass through the hole. Use as per diagram. Unscrewing the bolt will pry the caliper open. (Be sure to open the brake fluid reservoir.)
Making this will take you 10 minutes and cost next to nothing.
Dont go forcing the calipers with a screwdriver, wrenches, crowbars or other manner of strongarm tactics. :-p. It will damage the piston and/the caliper guide pins ccd07e1.jpg
Jul 06, 2010 | 2000 Nissan Sentra
87 suzuki samurai change front brake pads
the allen wrench bolts should be the correct bolts to remove brake caliper to allow access to pads.
hint: there will be only two bolts to remove and they will be the same maybe different lengths
May 02, 2009 | 1987 Suzuki Samurai
Changing motor hayward 1.5 HP
Super pumps are very easy. If it is a northstar it is more difficult. Super pump. You will need 1 motor, 1 pump seal, 1 diffuser gasket, 1 housing gasket. turn off breaker, disconnect wires -noting whether it is 110 or 220 volts- , unscrew four bolts on back of pump housing (shaft side of motor), pull out motor with rear housing and diffuser (sometimes diffuser sticks inside), on wire side of motor hold shaft with wrench (flathead in some cases, but it is harder), unscrew impeller counter clockwise (like normal screw - you will nee a big pair of channel locks or a strap wrench), there are two pieces of the back housing and once the impailer is off you can remove the half that is closest to the end of the shaft to reveal four more screws, unscrew those four screws. screw back part of rear housing onto new motor. Install new pump seal to front part of rear housing and impeller, slide on front part of rear housing and then screw on impeller while holding shaft on wire side with wrench (only hand tight), replace housing gasket, replace diffuser gasket, slide into front housing and screw in four bolts. If electrical was 110 you will need to move the jumper on the wire end..if it was 220 then just hook kup wires...doesnt matter which is which as long as green or bare goes to the ground screw.
Mar 14, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Changing the brake pads on 1998 s70
look for a rubber protective cap and remove it. Use an allen wrench to unscrew the pin.
Sep 30, 2008 | 1998 Volvo S70
Replacing the rear rotors on a 2003 E320
So this is what it takes to replace rear brake rotors on a 2003 Mercedes E320;
1) open the bonnet (hood) of the car and loosen/remove the cap off of the brake fluid resevior.
2) remove outer spring clamp from brake assembly (it clips in to the iner edge of the holes of the caliper).
3)using a 7 MM allen wrench, remove the brake caliper.
4) using 18 MM box wrench, remove the caliper housing assembly off of the wheel hub.
5) using a star wrench, unscrew the rotor locking screw from the rotor
6) squirt some liquid wrench on the rotor hub and knock the rotor with a hammer to work the liquid wrench in.
7) using the same hammer, knock the rotor off the hub.
8) using a metal file, lightly file old residue off of the hub and place the new rotor on the hub.
9) set the hub by screwing in the lug nuts and then screw in the hub locking screw using the star wrench, then remove the lug nuts.
10) reinstall the caliper housing assembly onto the wheel hub using the 18 MM box wrench.
11) push back the brake claiper piston to its home position and install the inner brake pad (the one with the snap clips)
12) insert the outer brake pad in the claper housing assembly.
13) slide on the caliper housing with the inner brake pad in place (over the outer brake pad) and screw in the caliper screw rods using the 7 MM allen wrench
14) on the right wheel brakes, DO NOT FORGET to slide in the brake sensor (the one with the black connector) and connect it to the connector on the caliper housing.
15) be sure to reinsert the spring clamp onto the outer brake assembly to set the assembly squarely onto the wheel (there should be no wiggle in the brake assembly after the spring clamps are installed).
16) finally mount the wheels.
17) you can bleed the brakes at this point to release any trapped air (which is unlikely) but be sure to pump the brakes after starting the car BUT BEFORE MOVING IT to re-preassurize the brake system before driving the car.
17) ONE WEEK LATER - recheck brake assembly to ensure all is okay and brake fluid.
This proposed solution is for a 2003 Mercedes Benz E320 and NOT a 2005 model as stated by the limited option selection provided by FIXYA.com when initially describing the problem.
Jul 09, 2008 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Relic Wet watch
Like many other watches, the Relic Wet's battery can't be changed by the owner. It requires a Jeweler's wrench. Said wrench has prongs that fit into the 6 indentations on the back of the watch. The wrench is than used to unscrew the back plate, exposing the battery. Any reputable jewelry store will have one.
Apr 01, 2008 | Watches
Porter Cable 7336 6 Inch Variable Speed Random Orbit Sander Only Logo
781 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
