Question about Whirlpool Dryers
Whirlpool dryer, will not run, belt is intact, I hear a ticking sound coming from the console on top
  • Whirlpool Master
  • 1,527 Answers
Hello there could be couple of problems 1 see if the long pin that inside on the door has not snaped off 2 the capacitor next to the motor could be faulty here is a picture of the capacitor whirlpool dryer, will not run, belt is intact, I - images?q=tbn:and9gcq6jy1uuiki2y4oc2osxtgkmo68nujktevhcxni843fr7ba3js&t=1&usg=__ekzprrbgzcpokz8cabc2fokk3qw=
Posted on Aug 02, 2010
Whirlpool dryer won't spin
Most dyers after you pull the top up, the front should just lift a little and it should come loose, sounds like you may have the belt intact, but the motor is not conected to the belt.
Jan 12, 2013 | Whirlpool Dryers
My dryer is not working because I can not hear a noise when I turn it to the desired time of drying. The noise sounds like a clock ticking when it works.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 17, 2011 | Whirlpool Dryers
Dryer just stop running, Have power to it and hear what sounds like the timer ticking But does not run?
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be real careful not to knock any of the wires off of the timer switch.
Remove the lint filter, and the two screws that hold the lint filter housing to
the top of the lid.
Then remove the top of the dryer.Most lids clip on to the base of the machine,
some slide off.
Remove the front of the machine, this will expose the belt and drum, remove
the drum and belt and this will expose the drum rollers, idler arm bracket
with pulley, and motor with pulley.
Pay attention to the route of the belt,this will come in handy when you go
to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum
not to turn.
While you have the drum out, I would recommend that you lubricate the drum
rollers at the shaft of the roller with a good grade of machine oil like 3
in One oil. This will save you a problem later with the rollers getting
noisy, also check your drum rollers for flat spots, if they have flat spots
on them this will cause a noise like a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Free answer...Please rate me
Dec 12, 2010 | Dryers
The dryer makes a new noise now when the drum is turning. It is a steady "tick -- tick -- tick -- tick --etc" which is laid over the normal sounds of the motor, the turning drum, and the...
You have done a good job of isolating the noise. Sounds like you will have to replace your drive motor. Very likely a mechanical problem in your motor, that is not going to fix itself. If you continue to run your dryer with the noise coming from your motor, you run the risk of the motor burning out electrically and causing a fire or a shock hazard. It is unlikely that this will happen, but it is possible and thereby not worth the risk of getting shocked or having a fire. The Whirlpool Duet Dryer is the best dryer built, so it is worth replacing the motor. Good luck, Appliance Specialists
Dec 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer won't run. I can hear the timer when I turn to a dryer level, but it won't turn.
tumble dryer / spin dryer seems to be making the right sort of noises, but the drum is not turning, unplug it, take the rear cover off and check to see if the drive belt is still intact and on the pulleys. If the belt has broken or stretched
Mar 09, 2010 | Whirlpool LGB6300 Gas Dryer
Pushed dial, dryer would not start. Heating coil on, can feel the heat and hear ticking.
If the heating elemnts are coming on but the drum is not spining then the motor could be bad or the belt could be broken that turns the drum. The motor could also be on a thermal overload in this case unplug the dryer or turn off the circuit breaker for 15 minutes and let everything cool down. After turn the breaker back on or plug it back in and give it a try if you hear the motor running but the drum is not spinning then the belt is probably broken and will have to be replaced.
Jan 12, 2010 | Whirlpool LER4634J Electric Dryer
Front loading whirlpool dryer won't turn, but you can hear what sounds like the motor running. The the heating element turns on.
This problem is commonly caused by a broken or loose dryer belt. Worse case scenario would be a bad drive motor, but you've already explained that you can hear the motor running. So, that would rule out a drive motor problem. You will need to open the dryer cabinet in order to verfiy if the belt is still intact. A visual inspection should confirm if the belt is still wrapped around the drum and tight. If the belt is missing, the only way it will come off the drum is if it breaks. You will need to replace it if this is the case.
If you need further guidance, please post back with your model number (located aorund the door opening) so that I may be able to provide better assistance. All dryers are not contructed the same and I will need to be able to explain to you how to open the cabinet. I hope this helps you.
Sep 10, 2009 | Dryers
Kenmore dryer not running
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
Dryer stopped spinning,timer still ticking,cannot get to restart.
Can you still hear the motor turning? If the motor is running but the drum is not then it is probably a broken belt or there may be something blocking the drum from spinning. The first thing to check is if the drum will turn by hand. If so, the next thing to check is if the belt has broken or slipped off. Although it is a bit cumbersome to replace, it is easy to diagnose. Unscrew the screws holding the back of the dryer on and pull the cover off. Look at the pulleys on the motor and see if the belt is intact. If those solutions don't do the trick, let me know and I will try to give you other options.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool, top-loading Ultimate Care, 20 lb washerm
The ticking sound is coming from the drive motor.
Removing the back and peering into the guts will tell you if there is a shredded belt causing the problem.
If the transmission has failed, the last one I bought years ago cost ~$130 wholesale.
Jul 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryers Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
