Question about Craftsman Garden
Need to find part # for self propelled cable, end is missing. right front wheel rotates but left does not. Any suggestions? is a craftsman 650 series zstart mower
    Problem Solver:
  • 11 Answers
Craftsman's website has a part data base. You simply type in the serial number found on the mower and it will bring up a bunch of different categories to choose from. Hope this helps you on your search.
Posted on Aug 02, 2010
I have a Craftsman front wheel self propelled mower. The front wheels no longer turn either in self-propel or in manual push mode. What can be done to fix this?
Take a good look at the wheel assembly. Is it rusted on from being left exposed to the elements? Remove the cover for the self propelled mechanism. Is the drive belt intact? Try turning the small pulley.
Aug 20, 2016 | Craftsman Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Self propelled lawn mower makes whinning noise
disconnect the spark plug turn the mower on its side and inspect the drive belt on the pulley above the blade (on the crankshaft) it may have a shroud over it. Also there is a small gear case that maybe dry that the belt drives, that goes to the wheels, Also try lifting the drive wheels up off the ground and engage them and see if it still does it. if it stops once lifted it might be the bushings on the axle its self.
Jul 19, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
The front drive self propelled wheels stick and squeal
why is the back wheels of my briggs stratton wont stop turning
Aug 29, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman 6.75 self-propelled...This is for a friend of mine. She has a broken arm and her mower will not operate as it should. The self-propelled function is not working. She spoke with someone who...
The self propel lever is the bottom one, the top one is the running lever. Have her check the cable coming out of that one. var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Aug 06, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
My 650 series self propelled is not working. the propell engage cable still has tension but when I grip it to engage it does nothing. It doesn't make any funny sounds or any thing like that. The mower...
I believe your problem to be with belt adjustment. Your engage cable is apparently working because there is tension. Check end of engage cable where it attaches to tighten belt, check to see if belt is broken or close to being broken, or so worn down there is no grip left. You may need to replace belt or just adjust belt. I hope this will ease your up hill struggles.
Jun 14, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Self propell wont work when wheels are in put in grass. I have changes cable and drive belt. what could be problem?
If you take off the wheels, you'll see gears inside the wheels, check for wear and tear. If their Ok, check the cogs and pins inside the cogs on the base (or chassis) for wear and tear
Jun 22, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Wheels will not turn on craftsman rear bagger lawn mower
Is the lever pushed up where the self propelled should be engaged? Yesterday, my wheels stopped turning. I have a break in the cable that goes to the self propelled. I will have to replace the cable.
Mar 27, 2010 | Garden
Garden Logo
220 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
