Question about Intel PRO/Wireless 2200BG 802.11g/b
Wireless card not recognized
I have installed a wireless card called "wireless G notebook Adapter" to my pc. However, the bus slot does not recognize the adapter. This device worked properly before. It is even recognized by other pcs without installing the necessary software. Could you help me to solve this problem?
  • 1 more comment
  • kiki_wiki Apr 27, 2008
    The updating my drivers does not fix the problem. It seems like the problem with my computer is that it does not recognize the wireless card. Other pcs do recognize it instantly when it is plugged in and states, " new device found." However, my pc does not recognize it now. Do you know if my setting for my bus slot is incorrect or is my bus slot broken?
  • kiki_wiki Apr 28, 2008
    my pc is gateway and it is windows xp. The wireless card is Linksys and it is called Wireless-G nontebook adapter with SPX.
  • kiki_wiki Apr 29, 2008
    I have the lastest driver installed for the wireless adapter. The same problem still persists. I still think it is the bus port problem with recognizing the adapter though.
    Scholar:
  • 60 Answers
Posted on Apr 27, 2008
  • Jocelyn Viau
    Jocelyn Viau Apr 27, 2008
    What is the brand and model of your PC?
    What is the exact brand and model of your Wireless card?
  • Jocelyn Viau
    Jocelyn Viau Apr 28, 2008
    Is THIS your adapter?
    If so, you will find the latest driver HERE. Forget about the Intel driver I suggested you earlier, I had gone by what I read in the title of your problem.
    If your bought your PC in 2005 or later, it should have no problem detecting the card. All that is left is to install the right driver.
Cant find where to install a wireless card internally to my dell inspiron 2600
You can't install any cards internally as there isn't any room inside. If you want to add wireless capability you'll need a USB wireless adapter which you just plug in to one of the USB ports. This computer also has PCMCIA (card-bus) slots, but that's older technology. USB adapters are much easier to find.
Jul 31, 2011 | Dell Inspiron 2600 Notebook
Tip
How to setup a Wireless Network
1. <b>Connect Your Wireless Router</b> <br /><b>a.</b> Power off your cable modem and your wired PC.<br /><b>b.</b> Unplug the Ethernet cable from your cable/DSL modem and plug it into one of the LAN ports on the back of the wireless router. Leave other end of the cable connected to your PC.<br /><b>c.</b> Connect another Ethernet cable between your modem's Ethernet port and the wireless router's WAN port. (The WAN port should be separate from the other grouped LAN ports.)<br /><b>d.</b> Power on the modem and watch for the status lights to indicate that it's connected to your Internet service. This may take a minute or so.<br /><b>e.</b> Plug in the router. The status lights will blink as it runs through its diagnostics; this may also take a minute or so.<br /><b>f.</b> Start up your wired PC.<br />2. <b>Configure your Wireless Router</b><br /><b>a.</b> Refer to the router's quick-start guide, launch Internet Explorer, and type in the address indicated in the guide.<br /><b>b.</b> Follow the on-screen setup wizard, which will guide you through the process step by step.<br /><b>c.</b> Enable your router's security functions. This is very important if you don't want other people attaching to your wireless signal. The options will be WEP and WPA. Both will ask you to enter a key. Depending on the router's manufacturer, you may have to go into Advanced Settings to accomplish this step.<br /><b>d.</b> Change the default administrator's password, Almost all hackers know them.<br /><b>e.</b> Change the SSID-the name of your wireless network. Again, hackers know many of the default SSIDs and can use them to hack your network.<br />3. <b>Install a Wireless PCI Card in a Desktop PC</b> <br /><b>a.</b> Refer to the card manufacturer's quick-start guide. If necessary, run the software installation program.<br /><b>b.</b> Power down the PC.<br /><b>c.</b> Remove the cover.<br /><b>d.</b> Find an available PCI slot and remove the slot cover from the back of the PC.<br /><b>e.</b> Carefully insert the antenna through the open slot in the back of the PC, carefully push the card in the slot, and secure it. Replace the cover. <br /><b>f.</b> Start up the PC. It should recognize and install the new PCI card.<br /><b>g.</b> Go to the Control Panel, select Network connections, select Wireless Networking connection. Click on Properties button. Click on Wireless Networking tab. Select the wireless networking name (see step 2e). Click on Configure button. Configure your security settings to match the ones on your wireless router.<br />4. <b>Install a Wireless PC Card in a Notebook PC</b> <br />Many notebooks have built-in wireless cards. However, If yours doesn't, you can install either a USB wireless adapter or a wireless PC card just follow these instructions.<br /><b>a.</b> Refer to the card manufacturer's quick-start guide. If necessary, run the software installation program.<br /><b>b.</b> Power down the PC.<br /><b>c.</b> Plug your USB wireless Adapter or wireless PC Card into an available slot on the side of your notebook.<br /><b>d</b>. Start up the PC. It should recognize and install the new PCI card.<br /><b>e</b>. Go to the Control Panel, select Network connections, select Wireless Networking connection. Click on Properties button. Click on Wireless Networking tab. Select the wireless networking name (see step 2e). Click on Configure button. Configure your security settings to match the ones on your wireless router. well, thats pretty much it. Hope this is helpful to all you home networkers.<br />
on Jul 11, 2011 | Computers & Internet
Reformatted Windows XP does not recognize D-Link wireless adapter
I ran recently across the same problem and solved it by changing the PCI slot where the card was installed... it makes little sense to humans, but apparently make a world of difference to the PC hardware ;)
Assuming you had installed unsuccessfully both Card and Driver you have them (like I did) both on your PC. In such ase, the solution for me was as follows: 1) Turn Off PC 2) Remove the card from the current PCI slot 3) Turn PC back On and remove driver 4) Turn Off PC, remove power cord and wait a minute or two 5) Do not install card yet 6) Turn PC back On and install the driver 7) Turn Off PC remove power cord 8) Install the Wireless card in a different PCI slot THIS IS VERY IMPORTANT!!! Can't be the same slot as where it was installed before!!! Note: If you have none available swap PCI slots or remove a PCI card to free up a different slot for the wireless card... remove a card you need the least and in its place install the Dlink Card. You may want to hold off on installing in a second step the card you have just removed, to be on the "safest" side.
9) Once the card is installed, Power up your PC 10) Once windows will be back up and running the hardware wizard should kick in and tell you that new hardware was found. 11) Follow the on-screen instructions 12) click "Continue Anyway" when XP will warn you that the driver hasn't been signed 13) Installation should be completed after you click Finish at the end of the New Hardware Wizard process 14) Simply go to your wireless networks and make sure all works in order
(I know that this process may sound a bit "anal" in some steps, but I was no longer willing to deal with any possibility of problems of any kind as I was ready to rip that wireless card to shreds!)
I hope this will help those who struggled with reviving an old PC to give to a friend!
Aug 02, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
Connection wireless adapter to laptop dell
Open up PC, Plug it wireless network into a PCI slot, turn on PC, the network device will be recognized and ask for drivers, you insert the CD/DVD that came with it, or use the software you downloaded from Belkin web site and install the WiFi card.. Run the Belkin software and it is installed. reboot PC, put case side back on.
Mar 02, 2010 | Belkin (F5D7000) 802.11g/b Wireless...
Netgear wpn511 computer not detecting
mccree08 on Nov 26, 2008
i have an acer aspire 5315 notebook 3 months old i purchased a netgear wpn 511 rangemax wireless card to help with my signal.the software installed fine but when i look in the device drivers i dont see the card as if the computer isnt recognizing it. there are also no lights on the card when plugged in. is my express card slot not working?
Wednesday, August 05, 2009 09:55
Hello mccree08,
The installed network adapters can be viewed in the windows device manager which can be accessed through the windows control panel as follows:
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
•In the Control Panel, Select Device Manager
•In Device Manager, Select 'Network Adapters'
The netgear wpn 511 adapter will appear there if it is correctly installed.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Nov 26, 2008 | HP ProCurve Wireless 802.11b Access Point...
WIRELESS ADAPTER
To install your wireless adapter, plug in the wireless card, and put your cd driver into the laptop. Once the adapter is plugged in, your laptop should recognize a new hardware has been installed, and will ask you for a driver (whether to automatically search for it or you can install it yourself. Pick the option of you installing yourself, and put the cd driver in. Then just go through the wizard to install your wireless card. You should be good to go from there! Any other questions, let me know!
Nov 21, 2008 | HP Compaq Evo n610c Notebook
IEEE 1394 adapter not recognized
Greetings,
Assuming you have a new laptop (based on having vista) your laptop is most likely equipped with an express card slot instead of the older standard. Here is a link to illustrate what I am talking about:
http://www.newegg.com/Product/Product.aspx?Item=N82E16839147002
Note that it is a different shape than the card you purchased from Best buy. Hope that helped.
Take Care,
-WN
May 05, 2008 | Televison & Video
Think pad wireless card
You may try the following:
1) Plug the wireless card on another slot
2) Update the drivers of the wireless card
If those does not work, you may try to install the wireless card on another computer just to isolate if the problem is on the wireless card or on the slot of the computer
Jan 13, 2008 | IBM - 19K5544 Network Adapter
DELL 6400 pc card slot issue
check in device manager via control panel, then click classic view; that the pcmcia card bus controller is present in the list and install the card reader driver if one was supplied, if not then there is no need for a driver and it must be a fault with the pcmcia driver.
Sep 03, 2007 | Dell Inspiron 6400 Notebook
Pccard slots
have you tryed any of netgears cards?
Jun 28, 2007 | Toshiba Tecra 500CDT Notebook
Intel PRO/Wireless 2200BG 802.11g/b Logo
230 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
