We took apart and washed pluged back in amd fuse keeps blowing
  • 674 Answers
Take it back apart and make sure everything is dry. You can use a hair dryer to help.
Posted on Aug 02, 2010
The pump stoped running I took the pump off and pluged it in a power cord and it runs
Mine did same thing I took pump apart and found that the impeller was stripped out replaced pump works fine now.
Aug 11, 2013 | Frigidaire FEX831CS Top Load Stacked...
Fuse keep blowing after crossing speaker wires.
Fuses blow when there is an overload. In your case when you crossed the speaker wires you shorted the main amp. This now has a part that is acting just like a strand of wire.
Trace back the channel you crossed the wires and find the main output device(s). Then replace them. They will be located on a heat sink if that helps.
Jul 03, 2017 | Sony MHC-MG510AV Shelf System
Alero fuse 46 keeps blowing
I have seen this before were the 46 fuse keeps blowing and it is usually after somone has had the radio and heater control out. There should be 2 wire harnesses that plug into the back of the heater control but the 1 will fit the extra plug on the back of the radio and the customer had the heater harness pluged into the radio. Radio worked fine but the rear defogger and a few other heater controls did not and it would blow the 46 fuse as soon as the key is turned on,.
Dec 04, 2011 | 1999 Oldsmobile Alero
I have a GE washing machine 175D2750G223 it keeps filling up and not agitatting and over flowing i have to manually put it in spin cyle,what cuold it be
the hose from the tub to the level switch is pluged or broke take 4 screws out of top and take hose off level switch and see if u can blow threw it or if it is broke there should be a paper manual there to so u can take it apart good luck
Aug 24, 2009 | General Electric Washing Machines
The fuse from the AC keeps blowing up< what can be the cause?
i had this problem....it was the little ac fan in front of the radiator. must have picked up a rock and offset the fan blades so the shaft wouldn't turn and of course blow the fuse everytime i turned it on.
Aug 11, 2009 | 2000 Chevrolet Tracker
Keeps Blowing Fuse
You obviousely have a short somewhere. Take it to a repair place.
May 26, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Smells like it's burning and smoke coming out of chimney vent
Get the filter housing out of the machine and wash it out. Blow out the blowers housing. Change the control thermostat.It mounts right next to the fuse on the back:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 07, 2008 | Roper REX4634KQ Electric Dryer
My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Jul 07, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Ilp iwt3206 32" sdtv
Next best guess is the larger filter capacitors in the power supply are bad and shorted out, you can check with an ohm meter across capacitor leads (with power unplugged)
Apr 21, 2008 | iLO 3200 32 in. LCD Television
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
