Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
Baracuda stopped working. it is not vibrating but
Baracuda stopped working. it is not vibrating but there is water going thru filter.
whats wrong?
  • 990 Answers
Could be a small rock or stick stuck in the diaprahm. If you pull the head you can look down both ends, use a ling stick or wire to clear or take the unit apart to find and clear this.
Posted on Aug 02, 2010
    New Friend:
My barracuda is working but not doing the figure 8 keeps going in a circle not cleaning well what can it be
Posted on Jun 04, 2015
Water no longer pumps thru the machine. We made a pot of coffee and it stopped after brewing about two cups into the carafe. What is wrong?
Hi - You did not say what machine you have - Does the machine still make that 'vibrating' pumping sound?. If not it may be the pump that has failed. But then with no details it may not have a pump either.
More details are needed - Brand , Model, etc otherwise anyone looking is just guessing
Cheers
Mike
Dec 11, 2017 | Coffee Makers & Espresso Machines
Baracuda stopped working. it is not vibrating but not moving
it ended up being that the hose had a kink in it. It's working fine now.
Feb 05, 2013 | Pool & Spa
My barracuda stops moving
There are several steps that you want go through to find the problem with your automatic pool cleaner. Check for air in your system, including hose connections, all fittings at the pump, checking the gasket in pump basket for wear.Make sure that your filter is backwashed and your pump basket is empty. Make sure that your main drain is closed and use your water flow gauge to make sure that you have enough water flow. Finally, check the diaphragm for wear and tear and replace if necessary
Aug 24, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Thru the door component stop working...what parts need replaced? going to take? lights come one but nothing works...water or ice.
It sounds like one of two things 1. your water filter is clogged or frozen, if you still have the bypass try that. if it works after that you just need a new filter, around $40 or 2. your waterline is frooze, try pulling out the crisper drawers anf heating the line with a hair dryer
Good luck
Jun 07, 2010 | GE Caf? 25.4 Cu. Ft. Side-by-Side...
Can Baracuda Diaphragm be replaced?
If you can't find any junk in the diaphram or throught. The best thing to do is take it to a store they can show you how to do this and they will not usually charge for more than just the part.
May 28, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My Baracuda Zodiac works for a few minutes and
check the diaphragm for debris, damage, or deformity. unthread the collar above the handle and push the tube downward. Inspect the rubber diaphragm, any damage or deformity will cause erratic behavior.
Apr 07, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Hello,I just hooked my Baracuda G3 up today.I feel like I followed directions and it does travel around the pool.However it follows the same track each time in a somewhat figure 8 pattern and only cleans...
Try changing the angle of your return jets in the pool they will have a tendency to set a current running in the pool. This was always what you wanted before to get the water to run past the skimmer but now it will give the cleaner a hard time getting around the pool. If you don't have directionals on you returns Baracuda makes an aftermarket dirvirter to fit most returns.
Oct 11, 2009 | Zodiac Baracuda Zippy Pool Cleaner
Think Pump or boiler broken as water doesn't flow through
If you cannot get hot water from machine(brew unit or steam valve), then there is something wrong with boiler elements.
If water won't flow thru coffee(pump is not vibrating) and you've tried adjusting the grind to a coarser setting, then you will have to replace the pump($50).
However, since no water is going thru machine and it does not heat up then the problem might be the board or the inline fuse on the machine.
May 16, 2009 | Saeco Vienna De Luxe Espresso Machine
My pool sand filter pump isnt filtering the water
sounds like the sand has clumped together inside filter. you can open filter and replace sand charge or dump into wheel barrow loosen sand and flush clean with hose and put back in
May 13, 2009 | Pentair Sand Dollar 19" Filter with 1 Hp...
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
978 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
