Question about Canon MX700 Office All-In-One InkJet Printer
700 MX error 5100 - Canon MX700 Office All-In-One InkJet Printer
SOURCE: when I start my canon pixma MX 700 series I gets error code 5100
First of all, make sure you pay attention to when your warranty expires, because this error tends to repeat and you get disgusted and request warranty support only too late. The problem is probably caused by a sticky paper sensor, but the printer must be turned off and turned back on to reset. If it persists in displaying the error, then you should lift open the main part (scanner) look carefully in the back right for the black plastic piece that is the paper sensor and poke it with a narrow scissors or something to nudge it back down. Then turn it back on and hopefully it clears the error. However, if that's the problem then it will likely recur.
Posted on Mar 26, 2009
SOURCE: mx 700 returns error 5100 message: Mac OS 10.5.8
how can I repare fault 5100???
Posted on Feb 09, 2010
pineworks
  • 4041 Answers
SOURCE: CANON MX 700 CODE 5100 TRIED EVERYTHING
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
SOURCE: Error 5100 on my canon mx 310.
the 5100 is the carriage error and can be caused by 4 different sensors. First off the "Timing Strip" that passes through the back of the Carriage Assembly can be contaminated with ink spots and this needs to be cleaned. Open the cover and use your flashlight to examine the timing strip as much as you can see. You really don't have much access to this strip unless you remove the covers,..and doing that is considerable work. The other items that can cause this error are the sensor inside the carriage unit, the drive motor for the carriage asm, and of course the main logic card. However, 99.6% of the time it is the Timing strip which is easitly contaminated with splattered ink.
Posted on Apr 02, 2010
pineworks
  • 4041 Answers
SOURCE: I have Cannon MX 700 printer. I cannot print due
Next try.
Solution 1:
Solution 2:
Posted on Apr 28, 2010
Mx 397 error 5100.
error support code 5100
Sep 24, 2013 | Office Equipment & Supplies
Canon MX328
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
error 5100 :
1. clean **** strip film
2. clean **** strip film sensor (back of head carriage)(use contact cleaner)
3. fix purge unit
Apr 24, 2010 | Office Equipment & Supplies
Apr 02, 2010 | Canon PIXMA MX310 All-In-One Printer
Next try.
Solution 1:
Solution 2:
Feb 16, 2010 | Canon MX700 Office All-In-One InkJet...
Cannon mx 310 error 5100 Says chck printr with alarm light flashi
heres the problem from service manual: error 5100, a error occured in your encoder signal, it list 4 things in the serice manual.
carriage unit. carriage motor, logic board, timing **** film.
ok my first thing i would look at is the film that runs directly behind the print head i would think it is dirty. just turn on printer and get print head to the middle and turn off machine, gentle move print head to one side and gentle clean the film strip with a cloth with a little metho on it, move print head to other side and clean other part of ****.
i reckon that will fix your problem its a common problem they tend to get a bit of grease on the timming ****.
Canon Tech
May 30, 2009 | Office Equipment & Supplies
Canon PIXMA MX 700 HAS ERROR 5100
Hi You can Try
Error Code 5100 Yes Same errors
Solution 1:
Solution 2:
May 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
When I start my canon pixma MX 700 series I gets error code 5100
Mar 14, 2009 | Canon MX700 Office All-In-One InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
27 people viewed this question
old marine
old marine
