Question about HP Pavilion tx1000z Notebook
Need to fix rotating screen back to horizontal!
The screen on my HP Pavillion tx1417d (rotating screen) is stuck in vertical position and I don't know how to upright it!
    President:
  • 2,600 Answers
I think you are referring to the picture on the laptop screen has rotated away from landscape or upside down. If this is the case, right click on the desktop away from icons and scroll down to "Nvidia or ATI control Panel", when this window opens look to the left and you will see a refrence to "Screen Orientation", click the drop down menu and select "Landscape". If you do not have the "control Panel" option, go to the bottom and choose "Properties", then display settings, then advanced settings, look for screen orientation, and choose landscape.
Posted on Aug 01, 2010
My Kindle only shows the books horizontally on the screen. When I turn the Kindle, the words do not move into the vertical position.
There is probably a rotation screen lock in the settings if this is on the screen will not rotate when the tablet is turned to the desired position the option should be in the settings menu need more info to determine where in the settings it is at
Jan 24, 2015 | Tablets & eReaders
Can only get the vertical view on screen. it will not turn to horizontal mode
Drag your finger down from the top to get the Quick Menu icons along to top of the screen.
Top LEFT of the Quick Menu is a Circle icon. Tap it to turn on/off the Screen rotation lock.
(If 1 finger does not work then use two fingers. You have turned on Accessibilty. Go to Settings / Accessibility to turn on/off)
Dec 23, 2013 | Amazon Kindle Fire HD
My screen is side ways how do i put it back to normal
Do you have a rotating monitor? There are a few that can be rotated 90 degrees in the plane of the screen for a "portrait view" instead of the standard landscape view, and they will automatically swap horizontal and vertical signals as needed. If you have one of these, the position detector switch is stuck in the wrong position. You may be able to get it unstuck by rotating to the other position and back again.
There are some programs (e. g., Acrobat Reader) that let you rotate the view of the file you have open, but that only affects the contents of the window, not everything on the screen. I'm not aware of a program that rotates the full screen view for the entire system.
Nov 19, 2010 | Computers & Internet
Display switched from horizontal to vertical while monitor is in the horizontal position. What keystrokes are necessary to return the display to horizontal?
Try pressing these key combination:
1. CTRL + Arrow Keys
2. ALT + Arrow Keys
3. CTRL + ALT + Arrows keys
These are shortcuts defined by your Video Card's support programs like NVidia or something alike.
The arrows key directions determine the direction to which the screen will rotate.
Jun 05, 2010 | HP w2207 Monitor
How to rotate display vertically on HP L1925
Press control alt arrow key (up or down to rotate vertically and right or left to rotate horizontally) simultaneously to rotate the screen.
Good Luck and have a nice day
Jun 02, 2010 | HP L1925 19" LCD Monitor
Where is the system battery on the hp pavillion 533c
Without the mother model/type it's impossible to tell you where the Bios Battery is located. But there's not much difficulty, generally only two types of alignments, as shown below, horizontally on the motherboard and vertically : a74f1de.jpg
Vertical,
Horizontal.
May 14, 2010 | HP Pavilion 533c (P9939AR#ABA) PC Desktop
Change Landscape to Potrait veiw
Hello, You need an application called HP MyDisplay, you can download this at the link below, this app will register in which way the monitor is (landscape or Portrait) and when you pivot (rotate) the screen it will rotate the screen as well.
Download: http://www.portrait.com/dtune/hpw/enu/upgrade_instructions.html kr Gijs
Sep 10, 2009 | HP Pavillion s7420n PC Desktop
Screen shows several horizontal and vertical lines.
this can be in your video cable or LCD Connector issue. but most problem is in the flex cable of LCD. some other cases cannot be fix and replace new LCD Screen.
Aug 14, 2009 | Samsung HP-S4253 Television
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
Computers & Internet Logo
347 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
