Question about HP ProBook 4510s FM849UT Notebook
Cant use hdmi with a hp probook 4510 and a polaroid 42' tv.
I have a hp probook 4510 and a polaroid 42' tv. i got a hdmi cable but when i plug it to the computer it just dosnt get a signal.
  • leojadue7 Aug 02, 2010
    i have windows 7, where can i add the tv as an external monitor?
    President:
  • 2,600 Answers
Did you try "Cycling" through the video out presets? Hold down the "Fn" key and tap the F4 key, do it slowly to give the computer time to react to the input. You should see it cycle through the available presets. If not, you may have to get into the display settings and "Add" the tv as an external monitor.
Posted on Aug 01, 2010
  • 1 more comment
  • leojadue7 Aug 08, 2010
    y tried cycling and nothing happens... how do i add the tv as an external monitor???
    i tried to add it but theres no hdmi option, theres only vga and something like mobile pc display...
  • Chip
    Chip Aug 09, 2010
    Your system has an HDMI port which carries high definition video and audio and you have a VGA port which carries the analog video signal
Hp probook 4510 not powering up (orange light flashes a few times when power button is pressed
Disconnect power adapter.
Remove the battery
hold down power button 10 seconds
plug in Power adapter
press Power on
Aug 08, 2016 | HP ProBook Computers & Internet
How to change sound output mode of HP probook 4510s
You need to connect laptop headphone connector to TV for sound.
Feb 25, 2012 | HP ProBook 4510s Notebook
Xp shutdown not working laptop hp probook 4510
That's probably due to some software changes. Try to shutdown using the power button. Then reboot your laptop, check if problem still occurs.
OR you can do this...
1. Open RUN
2. Type shutdown -s -f -t 0
3. Press Enter
Thanks & Regards,
(-_-)
Mar 22, 2011 | HP ProBook 4510s FM849UT Notebook
Poloroid 42" lcd - high pitched sound from the
That HDMI port is shorted and dying.Just don't used that HDMI port.That the cheapest and easy way,just by pass that HDMI port.Other wise than u have to spend like $130 -150 to buy a whole refurbish tv Tuner signal board for the replacement.Because those HDMI ports,dosen't have any indiviual sell by itself as HDMI port as part.
Nov 15, 2010 | Polaroid TDX-03211C LCD TV
I Cant connect probook4510s via hdmi to tv. I have 2 probook4510s 1 with the original windows xp and another one that i installed windows 7 on it. When i try connecting the hdmi cable to any both of them...
How many HDMI ports does your TV have? Have you cycled through all of them? Have you tried going into the graphics properties of the laptop (right click on the desktop and select "properties" then "settings) and setting monitor number two to "extend my Windows desktop onto this monitor"?
I would think it highly unlikely both laptops are faulty
Aug 08, 2010 | HP ProBook 4510s FM849UT Notebook
42 IN CH POLAROID HDMI BLACK SCREEN
i had the same problem. i opened the panel in the back of the tv (3 screws) and opened the aluminum panel (3 screws). there's a red led light located at the bottom left corner of the top board. to the right of the led light, you will find this thing with 4 switches. i turned the two bottom switches "burn" and "epmw" to on. so far tv have been working.
Jun 12, 2009 | Polaroid FLM-2632 Television
Selecting 1080p
Hd tv only has 720p picture ability
bluray xbox playstation 3 needs a hdmi cable connected to enable 1080p
Apr 19, 2009 | Polaroid FLM-4201 42 in. LCD Television
I cant figure out how to plug in the direct tv cable
Ther is no "cable" connector on this model tv. Check your direct tv control module "cable box" for a hdmi output. If you have that output, you will need ahdmi cable for HD broadcast. If you donot have a hdmi output on your direct tv box, contact direct tv for the right one. Do not use RCA connectors because the picture will be fuzzy do to in-ability for rca connectoe to send HD signal. You MUST have hdmi signal from cablle box to tv.
Good luck.
Mar 07, 2009 | Akai LCT4216 42 in. LCD Television
HP ProBook 4510s FM849UT Notebook Logo
1,235 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
