Question about Acer Aspire One PC Notebook
Chkdsk hangs at 4% in step 1 - Acer Aspire One PC Notebook
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 58 Answers
If you never used a registry cleaner, I highly reco AUSLOGICS REGISTRY CLEANER...it's free from download dot com.I've used it without issue for about 5yrs now.If you decide to try that, post back your results.I regularly use registry cleaner and defrag......and I have a smooth running machine
Posted on Apr 24, 2012
  • 942 Answers
You may turn off the laptop, remove the cables and battery. And then press and hold power button for 8 secs. Reinsert back the cables and battery then turn on the laptop. Check if chkdsk still hangs at 4%, this might be a hard disk issue. You may reseat the Hard drive by turning the equipment off, remove cables and battery, remove the screws underneath the 4 corners of the laptop, and then remove the Harddrive. You may reinsert it back and follow the sequence in descending manner. If all else fails, you may call Acer for repair...
Posted on Aug 01, 2010
What is oxc00000eg
This paper provides an overview of this configuration data - called boot configuration data (BCD) - and describes how to use the related tools to manage boot options. Step 1
Perform chkdsk which will repair the bad sectors of the hard drive.
To do this, follow these steps:
1.Click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator.
2.Type chkdsk/ f, chkdsk/r, chkdsk/i, chkdsk/c in the commands listed belowi.e. (/f, /r , /i, /c).
Step 2
Try to load BIOS to default and check if you have similar issue.
Step 3
I would suggest you to rebuilt BCD. To do this, follow these steps:
To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
  1. Put the Windows Vista or Windows 7 installation disc in the disc drive, and then start the computer.
  2. Press a key when you are prompted.
  3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  4. Click Repair your computer.
  5. Click the operating system that you want to repair, and then click Next.
  6. In the System Recovery Options dialog box, click Command Prompt.
  7. Type Bootrec.exe, and then press ENTER.
8.Type bootrec /RebuildBcd , and press Enter.
For more information refer the link given below:
How to use the Bootrec.exe tool in the Windows Recovery Environment to troubleshoot and repair startup issues in Windows
http://support.microsoft.com/kb/927392
Apr 11, 2014 | Computers & Internet
Tip
How to Remove Check disk on every restart
Whenever the computer reboots the computer perform a check disk to find if there is any errors on the volume.
Instructions Things You'll Need:
  • Windows xp
  1. Step 1 Click on your start menu and open the run dialog.
  2. Step 2 Type "cmd" and return (note: don't enter quotes)
  3. Step 3 Next type "fsutil dirty query X:"( If it's your C: drive you should move the virtual memory to another drive).
    Where X :- is the Drive icon name
  4. Step 4 If the return message indicates that the volume is dirty go to step 5
  5. Step 5 Next type "chkdsk e: /f /x"
  6. Step 6 After that finshes repeat step 3.
  7. Step 7 If it is no longer dirty then reboot and you should notice no more
    CHKDSK.
on Feb 18, 2010 | Computers & Internet
Solve hang problem
There are some possibilities through you can increase performance and solve ur hanging problem.
1. Open command prompt and type chkdsk and press Enter. after few seconds it will ask for Y/N and type Y and press Enter.
2. Type defrag c: -f and press enter. It ill defrag your c drive.
3.Click on Start>All Programs>Accessories>System tools>desk Cleanup and it will scan the temp files and will delete them after clicking on OK after scanned.
4. If this not solve the issue then run the system in safe mode and check is it hanging on the safe mode then there might be some issue in hardware otherwise needs to install the OS again.
Sep 02, 2013 | Compaq evo Computers & Internet
Windows 7 will not start
First you need to try safe mode and check if you are able to boot to the system....
If not then ...
Note this issue is caused due to the boot file corruption and in order to troubleshoot this issue we will run chkdsk from Win RE (Windows Recovery Environment )mode and check for the issue, to do that follow the below steps.
To run check disk, you have to have Windows 7 DVD, boot the computer to Win RE from the elevated command prompt, and try to do a CHKDSK. You can follow these steps to run CHKDSK :
1) Use the Windows 7 DVD to start the computer in Windows Recovery (WinRE).
2) In WinRE, open a command prompt. To do this, follow these steps:
On the Install Windows screen, select the appropriate Language to install, Time and
currency format, and Keyboard or input method options, and then click Next.
3) Click Repair your computer.
4) Click the 7 installation that you want to repair, and then click Next.
5) Click Command Prompt.
At the command prompt, type the following command, and then press ENTER:
chkdsk drive: /f and chkdsk drive: /r
source link
Jan 14, 2013 | Computers & Internet
Game freeze got 4 gb ram and i have 9500 gt xfx graphic card. dual core optimizer installed.... help me
Bro follow this steps. 1. click windows " Start " button beside your Taskbar. 2. select "Run". 3. type " cmd ". 4. type " chkdsk /f " to repair your entire system errors. 5. your done.
Mar 30, 2010 | AMD Athlon 64 X2 6000+, 3.0 GHz...
Arcsoft VideoImpression
This is windows Vista? What have you changed since it started crashing? The most common cause of crashing programs like this are the result of a graphics driver.
Mar 07, 2017 | Arcsoft VideoImpression 2 for PC
Iphone hang up logo not going
You should restore it with ituns.First put your iphone in dfu mode and then restore it with itunes
Dec 25, 2008 | Apple iPhone Smartphone
Help
No
You need to Go for Pc Recovery from HP it self or you can get the recovery cds for it.
Try :-
Opening Recovery Console
The following steps open a Recovery Console:
1. Shut Down Your Computer and as soon as you turn your computer On Keep pressing F10 key on the Key board,
You will get an welcome to recovery manager screen after that it will ask you if you want ot run recovery.
after that you need to follow the screen Instructions.
Or either try.
Using the Checkdisk Utility
Use the following steps start the recovery console and use chkdsk to resolve startup issues:
1.Open a recovery console. For more information about how to open a recovery console, refer to the section above: Opening Recovery Console .
2. At the C:\Windows> prompt in the recovery console enter chkdsk /r .
NOTE:If chkdsk /r fails to start from the selected prompt, type chkdsk c: /r (note the space before and after the drives c:). If you are using a recovery console or Tools CD, type chkdsk d: /r , or chkdsk h: /r .
Chkdsk starts.
The time required depends on the size of the hard drive (it checks unused portions of the hard drive) and the amount of software installed. When chkdsk /r completes the screen displays the size of the volume checked and the allocation units. If errors are detected the result are displayed as CHKDSK found and fixed one or more errors on the volume . This is normal.
3.Type EXIT and press Enter on the keyboard.
The PC restarts.
4.If you used the Recovery Console from a CD, while the PC is restarting, press the Eject button on the CD drive and wait a few seconds for the drive tray to open. Remove Recovery Console from the optical drive.
Oct 14, 2008 | HP Pavilion a350n PC Desktop
My iphone hang. Only shows apple ph. kindly help to restart & back to normal.
try this pls,,, Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Alternative Method:
Step 1. Connect iphone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.
Aug 31, 2008 | Apple iPhone Smartphone
Iphone Hangs
do this: Step 1. Turn off your iPhone.
Alternative Method:
Jun 30, 2008 | Apple iPhone Smartphone
Acer Aspire One  PC Notebook Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
