Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Where is the water filter on galaxy model #106.55122700
At the bottom below door
Posted on Jun 28, 2014
4 Suggested Answers
  • 52 Answers
SOURCE: How can I buy more shelfs for my fridge Galaxy 106
yes you can they are spendy the shelf is a 2 part. the glass which is like 70.00 or better. and you have the shelf frame. that is priced around 50.00 plus shipping. hope this helps. There are several parts warehouses where you can purchase them. glass shelf part number is 2177986 and the frame is 2163572. this is for the fridge side.
Posted on Oct 22, 2009
imufo2
  • 3773 Answers
SOURCE: I have a kenmore model
Check water volume at wall cutoff
Did you install the filter backwards?
If it is an inline filter in the back you can install it wrong way.
Check for kink in water line in back
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 06, 2010
BIKER T
  • 909 Answers
SOURCE: Does water supply need to
Actually, by shutting the water supply is a good idea because the line pressure is still sitting there at the filter.. Firstly, shut water valve off, then press the water dispencer button to reduce line pressure, then remove the filter.(The pressure build up will make the filter hard to remove and it will be messy)..
Posted on Sep 08, 2010
WHAT IS THE CORRECT ITEM NUMBER FOR THE WATER FILTER FOR A GALAXY SIDE BY SIDE REFRIGERATOR MODEL #106.55622500
Hi Roy,
Number part number you seek with the model number given is EDR5RXD1, this is a grill mounted filter. Good Luck
Mar 12, 2016 | Refrigerators
How to change the water filter on a galaxy 25.4 cu. ft. side-by-side refridgerator
Check the "grill". Best Buy's ad spec sheet stated the filter was located in the grill. I believe there's an access panel on the bottom front of the grill below the doors.
Jul 28, 2014 | GALAXY Microsystems 25.4 cu. ft....
WATER DISPENSER ON GALAXY SIDE BY SIDE REFRIGERATOR DOESN'T WORK
Sounds like if your ice maker is still working, you're having an issue with your filter maybe freezing. Check to make sure your water filter isn't froze. What you're talking about with the overflow is a coincidence, but unless the internal wiring for the unit inside of the dispenser got damaged, i doubt thats the reason why. It's either a frozen filter or bad water valve. Try dethawing the filter or taking it out and seeing how much pressure there is built up in it. There's also a water reservoir in the back of this unit that may be froze too.
Nov 27, 2013 | GALAXY Microsystems 25.4 cu. ft....
My Galaxy side by side refridgerator is leaking from the water filter system. When I removed the water filter the leak stopped. Do I need to replace the filter cartridge or is it something else?
Start with the cartridge. If the cartridge was frozen then you'll more than likely have to change the housing as well. This is only if the filter is on the inside of the machine. If its located underneath then change the filter and just check the lines that go to it by removing the kickpkate and taking a glance
Jun 03, 2012 | GALAXY Microsystems 25.4 cu. ft....
Common complaints
I found a few, and they're easy to get to. At the top of this page, under the FixYa logo, click on the underlined blue bar that says '25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water'. This will direct you to a page for Galaxy fridges with these features. Scroll down to see the complaints.
Best regards, --W/D--
Aug 08, 2009 | GALAXY Microsystems 25.4 cu. ft....
Water filter replacements
Hello Shawna, Yes, you are absolutely correct. The Galaxy and the Kenmore use the same filter. Best regards, nightdiver
Aug 23, 2006 | GALAXY Microsystems 55622
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
394 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
