Nad 502 doesn't spin the cd, ejects ok. I have replaced the cd mechanism so suspect main pcb error - any thoughts?
  • tatstats Apr 26, 2008
    yep - laser pickup included
Could be the main board, but check on your power supply for the board as well.
Posted on Apr 26, 2008
    Novelist:
    Champion:
  • 236 Answers
When you replaced the CD mech... does that include the laser pick-up?
Posted on Apr 25, 2008
LG dvd model no: HT 302, doesn;t eject & if eject the cd manualy , disc doesn;t spin & the laser not coming on. what could be a problem?
there are switches needs to be in contact when the loading tray is closed and open. it is placed under the tray mechanism. investigate ribbon cuts and bends. replace it
Feb 25, 2011 | LG Televison & Video
2003 Lincoln LS
that's a mechanical issue, actually...i'm assuming the rest of the cd player is working?
Feb 29, 2008 | Car Audio & Video
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Nov 16, 2008 | NAD C541 CD Player
Nad c350 no power at all
Solution if all fuses checked out OK and +/-40V are present on main PCB DC connector from power supply:
Check for +37V and -37V on small sub-power supply PCB - mounted vertically on the main power supply PCB. (next to ribbon cable connector is a layout with voltages.) If the +/-37V are missing check (replace) C501 (0.1uF) on the small power supply PCB for leakage, but also check (replace) R401 (2R2) and R402 (2R2) on the main power supply PCB. Both resistors are fuse-resistors and will have gone open circuit when C501 has gone leaky.
Aug 21, 2008 | NAD C350 2-Channel Amplifier
NAD 502 CD player problem
Does it have a failing drawer belt? My 522 was fixed after that.
Jun 18, 2008 | NAD C521 CD Player
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
NAD 502 CD player LCD problem
hey, well, typical problem i nad cd players, and also receivers by the way. The proble are tha nad use standard glow lamps. And as we know, the blow!! And often when you move around with the cd. Well i do have repair note for this one also. http://www.miguelovitch.dk/ go to the menu: 'amplifier repair notes' (yes includes cd players ;) ) Here you can find free amplifier repair notes, an go fore nad 705 repair fix (same fault with defect bulb's as in you nad cd) And also a technical repair movie showing you the hole process of the 'workaround' this fault i NAD 522 (NAD 501, 502, 512 and more) http://freemovies.s-educator.org/repair_movies/nad/nad_cdplayers_defect_lamp_in_display_stremingvideo.html best regards michael miguelovitch
Sep 06, 2007 | Audio Players & Recorders
Power light switches to red.
I suggest rechecking the speaker wiring in case there is a small "whisker" of wire touching either the case or adjacent terminal, also check the speaker end of the wires for same. Do you have a pet? I have seen wires chewed partly through by cats (& rabbits)! See the information from the manual below: http://207.228.230.231/manual/NAD-C370.pdf
Jul 26, 2007 | NAD C370 2-Channel Amplifier
109 people viewed this question
 Grubhead
Grubhead
