Question about Whirlpool RBS275PD Electric Single Oven
Oven shut off not working - Whirlpool RBS275PD Electric Single Oven
    Guru:
  • 310 Answers
First make sure you have power to the control board. If so, the control board has failed. It is no-longer-available but can be rebuilt by fixyourboard.com.
Posted on Aug 02, 2010
Oven shuts off in middle of cooking/baking. stove top burners work just fine.
GE oven - SHUTS OFF ON IT'S OWN
I have a built-in GE Electric oven - model #JTP20B0F7BB. It shuts off in the middle of cooking sometimes, but not all of the time. It does it about 1 out of 4 times that I use the oven. Any help would be appreciated?
Apr 17, 2011 | Jenn-Air Ovens
Oven lights and works fine till it reaches set temp then panel goes blank and oven shuts off
Check the cooling fan inside of your control panel. Most likely the computer board overheats and shuts itself down.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 25, 2011 | GE JGRS14 Gas Single Oven
Eob5630w oven shutting down before set temp isreaced aprox 198c also cooling fan not comingon
The reason the oven is shutting down is because it is overheating due to the cooling fan not working, and a safety thermostat is turning the oven off.
You need to repair or replace the exterior cooling fan.
Jan 05, 2011 | Electrolux EOB5630 Ultrafan Electric...
Stove top working, oven is not
you need to check the heating elements and make sure you have continuity if you do then replace the control board
Jan 29, 2010 | Frigidaire FEB27S5A Electric Single Oven
Oven shuts off while in use.
Did you ever resolve this problem?
I have the same oven and I am having the same problem.
Thanks,
Jamie
May 03, 2009 | Ovens
GE oven only heats up to 300 then shuts off
just a thought but maby the
tempature sensure has gone bad
Jan 21, 2009 | GE Profile JTP18 Electric Single Oven
Blodgett 961-P pizza oven
Go here find what you seek.
BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Great Co.
Sep 30, 2008 | Blodgett 911-DOUBLE Gas Oven
KitchenAid KERA807PSS01 oven won't shut off until breaker thrown
assuming its a stainless stell oven? if so heres the par tyou need its a membrane switch( your cancel button ceased to operate corrrect???not a bad part to install you need to remove a few screws from under control panel itself( perhaps a few on the sides, the front control will lift off and this part is installed from behind the control panel (SHUT THE BREAKER(S))
part number 9756595ES
in the mean time instead of shuttin off the breaker toreset you can simply( requires reading manual ) set your oven to time bake. it will shut off automatically after predetermined time has been obtained.
Apr 27, 2008 | Ovens
Built-in Electric Double Oven
The fan is controlled by a temperature sensitive switch. Apparently the switch is not shutting off when it should. It will have to be replaced. If you are not comfortable working around appliances, you will need to call a service technician. There is usually a set of maintenance instructions in the top of the oven. Check it out for any suggestions. Temperature switches can be purchased on line.
May 18, 2007 | Whirlpool RBD306PD Electric Double Oven
Whirlpool RBS275PD Electric Single Oven Logo
60 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
