Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Swamp cooler works i can hear the pumpon water is turned on but not getting cool air
  • 40 Answers
Just because the pump is on dose not mean its moving water. impellers can break and pump can get air lock
Posted on Apr 04, 2011
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
We have an older swamp cooler and need to have some windows in our home open to get best cooling. Does a mastercool need to have some windows open in our home to give max cooling?
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Apr 24, 2011 | Mastercool 67680 Evaporative Cooler Air...
How do I unclog the copper line?
The copper line and the pump. Which is the concern?
On the circuit breaker, Turn it off and in five minutes, back on.. Then check the outlet at the cooler to see if it's getting power.The copper water supply line? You do have water to the float control valve? or no?
Jul 10, 2009 | Heating & Cooling
No cool air fromm swamp cooler, water is on.
is the pump on? pull side panel make sure every thing is clean . Tom
Jun 30, 2009 | Heating & Cooling
Swamp cooler is not blowing cold air. Water is
is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Jun 25, 2009 | Heating & Cooling
Water is not going into swamp cooler
CK THE FLOAT THAT OPENS AND CLOSES THE water valve.. press down on float to see if water is available,if water flows float needs adjusting. If no water then check to seeit hasn't been turned off for the winter -good luck
May 11, 2009 | Mastercool 67471 Evaporative Cooler Air...
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Apr 21, 2009 | Mastercool 67471 Evaporative Cooler Air...
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Shouldn't it be cooler?
Just found at least one problem with mine. I pulled off the back screen and then pulled off the back cover by undoing the two screws at the top. There is a pad in there that rotates through the water reservoir. If this pad doesn't get wet, you won't get any cooling. My pad was bone dry. Turns out the wire for the motor that rotates the pad was disconnected from the front control panel. I reconnected the wire and now the pad rotates through the water reservoir. We'll see how this works.
May 21, 2008 | NewAir AF-330 Air Cooler Fan
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
140 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
acrman404a
Level 1 Expert
Steve F
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
