Question about ASUS P5KPL-AM SE Motherboard
When i press the power button on my computer, the fans are spinning but the computer does not boot up... I had this problem before and i got a technician to reset the asus p5kpl-c/1600 board, but now i just want help on how to reset it, thanks..
    Scholar:
  • 72 Answers
I can't find your specific motherboard after a quick look on ASUSTeK's website, but the procedure is generally the same for resetting your motherboard's BIOS. There is a jumper on the motherboard, and it may be labeled BIOS or something similar.
The following I cannot verify without your specific motherboard model, and you may be doing so at your own risk. To reduce your risk, please make sure your computer is unplugged, and you have grounded yourself (i.e., basement floor, metal water faucet - don't get wet!, pipe, etc.).
There will be 3 pins, and the jumper should be across two of them. You will need to move this jumper to the other side of the 3 pins and start up your computer. After the computer powers up, you may or may not need to shut it down (and re-unplug everything) and move the jumper back to its original location. Your BIOS should now be reset.
Posted on Aug 02, 2010
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
Reset button on a powerbook g4
The Powerbook G4 power button functions like a reset button if you hold the power button in for a few seconds until the computer powers down.
  1. Hold the power button in for a few seconds (until you see the screen turn off/go black and hear the fans & hard drive stop spinning).
  2. Press the power button again to turn your computer on.
  3. If you have more trouble, you may need to boot in Safe Mode or "perform a Safe Boot":
    Press and hold down the "Shift" key immediately after you hear the start-up tone. Release the "Shift" key when the gray Apple icon appears on the screen.
May 02, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
NO DISPLAY on screen but processor fan is work
If it seems like the computer booted up all the way except the screen is blank.
If so try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok and works, then the video card inside the computer is good, but the original monitor is bad. If the Borrowed monitor does not work, then the video card inside the computer is bad.
If it does not seem like the computer booted up all the way try the steps below.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Jun 09, 2012 | Intel Computers & Internet
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Sony Computers & Internet
I turn on my tower and the fans move and the disk try clicks like it wants to spin then i turn the monitor on and it turns green them orange right away and says entering power save mode waht do i do
1) Unplug the computer from power.
2) Press the Power On button in, and hold it in for a count of 10 seconds.
(Count)
Let go of the Power On button.
Do this same procedure two more times. (Or until the Power On LED does not light up anymore)
3) Plug the computer into power. WAIT 1 minute, turn the computer on.
The fans should spin at high speed for a few seconds, then settle down.
Let's see if the computer boots.
Post back in a Comment, and we will go from there.
Regards,
joecoolvette
Feb 26, 2012 | Gateway 702GE PC Desktop
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
This should work....all the best
May 19, 2010 | Computers & Internet
I have a Gateway Mx6440 Laptop and et CPU FAN error upon boot. afte w while i try spinning th efan and it starts working, i belive it is the heat sink that is defective but where can i find the proper fan...
"Turn off computer and unplug power cord. <br>Disconnect all external devices. <br>Remove the battery. <br>Press power button and hold for 10 to 15 seconds. <br>Plug power cord back into computer and press power button. <br>Check front panel LEDs (lights) on bezel (front face) or optical drives and listen for power supply fan. <br>If LEDs are on or power supply fan starts spinning, watch for boot screen on monitor. <br>If computer begins to start, turn it off. <br>Reconnect any external devices. <br>Press the power button and make sure the computer starts.
Please save this steps and go through that. If in case you require further help, you need to contact Answers by Gateway department which is a paid support. The phone number for Answers by Gateway is 1.800-237-6483. Or please consider contact with a local technician for a detailed troubleshooting."
worked for mee!! good luck
Feb 22, 2009 | HP (158800-001) for Compaq Presario 1246,...
Computer won't boot
turn off the system remove all the cables from the back of the computer press and hold down the power button for 10 seconds now connect just the poer cable and try to tun on the system and as soon as it turns on tab the F8 key on the keyboard and then boot into last known good configuration
May 28, 2008 | Computers & Internet
ASUS P5KPL-AM SE Motherboard Logo
194 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
