Question about Whirlpool Dryers
WHIRLPOOL DRYER HEATS BUT WILL ONLY SHUT OFF MANUALLY
I THINK THIS DRYER IS ABOUT 12 YRS OLD. IT DRYS BUT WON'T SHUT OFF IN ANY CYCLE, ONLY MANUALLY. IS THIS AN EXPENSIVE FIX? I'M GUESSING A TIMER PROBLEM BUT REALLY DON'T KNOW
  • LINDA RADER Aug 03, 2010
    Thanks Phil, I will keep it open for now. When I get the part I will let you know how it goes and if I need help or just reassurance that I am doing it right, I will contact you.
    Linda
    President:
  • 949 Answers
You are correct. If the dryer will not turn off in the timed dry setting the timer is the component that has failed.
If you can send me the model number from the tag just inside the door I can get you a ballpark price on what the timer will cost.
Thanks!
Posted on Aug 01, 2010
  • 8 more comments
  • LINDA RADER Aug 02, 2010
    THE WHIRLPOOL DRYER MODEL NO. IS LER4634DQ0 THANKS
  • Philip Aug 02, 2010
    The timer is part number 3393934 and runs about $75.00
    THANK YOU SO MUCH. IS THIS AN EASY FIX LIKE JUST REMOVING WIRES TO REMOVE TIMER, ETC. OR SOMETHING MORE COMPLICATED?
    It is pretty easy, just do not remove the old one until you get the new one. Replace one wire at a time and it will go easy, be sure to the power is off before you take it apart.
    I will be around to assist when you make repairs if needed.
    Phil
    ONE LAST QUESTION, I HOPE. IS THIS JUST A TIMER MOTOR? I HAVE READ THINGS ABOUT TIMER MOTORS NEEDING REPLACED AND THAT SOME HAVE TO HAVE A COMPLETE TIMER ASSEMBLY REPLACED. JUST WANT TO KNOW WHAT I MAY BE GETTING INTO? I AM A DO IT YOURSELF KIND OF WOMAN, BUT IF ITS MORE THAT UNCONNECTING & RECONNECTING WIRES, I MAY BE IN OVER MY HEAD. THANKS
    I am sure you can do it. It is an assembly, only a few screws and a few wires, but they are terminal for terminal.
    Thanks Phil. I will order the part, its defintely work fixing if that's all it will cost. If I close this out and withdraw my problem, how do I get in touch with you again on the website
    if I run into any problems when the part arrives?
    Thank you so much for your quick responses. I was getting ready to get rid of the dryer because someone told me to replace a dryer timer would cost me about $300 parts and labor and no one told me it would be something I could do myself. I really appreciate your help.
    Linda
    Hi Linda,
    You can keep this question open if you like until you get the part. If not I think you can search for my name. We are not allowed to post our email addresses but can view those posted for us.
    Phil
  • LINDA RADER Aug 04, 2010
    Hi Phil,
    Someone told me that one time they had a bad resistor that stopped the timer, have you ever heard of this?
    Linda
    Hi Phil, Someone told me that one time they had a bad resistor that stopped the timer, have you ever heard of this? Linda View More Comments Collapse X
Changed timer/whirlpool model leq9508kq1/dryer runs in accudry mode, wont shut off,what is wrong?
if it wont shut off this is a timer problem contacts fused closed,are you sure this is a new timer?(some are remanufactured)
Feb 12, 2013 | Whirlpool GEW9250 Electric Dryer
The dryer works and heats up but it won't shut off
I believe that your timer has run out of time! ;) Seriously though, Your problem is more than likely your selector (the dryer timer knob) is worn out. Time to replace it with a new one.
Good Luck my friend!
Phillip
Dec 27, 2011 | Whirlpool Washing Machines
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
Heats for the first 3 minutes or so and then just drys cold air.. is it a thermostate problem?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 24, 2010 | Whirlpool LER5636P Electric Dryer
I have a LER4634EQ1 WHIRLPOOL electric dryer. Last week it started to shut down before completing a cycle. The other day it completed the cycle but the clothes weren't dry. It also makes a loud noise when...
if the noise is a rumbling sound tha that would be your roller's.the other problem sounds like a bad timer.time to think,do i put that kind of money in a 12 year old dryer or get a new one.
Nov 05, 2009 | Whirlpool LER5636P Electric Dryer
3 yrs old stopped in the middle of a cycle .
need to change thermal fuse,when dryer gets filled with lint they pop,it is a safety device that pops when dryer over heats
Nov 03, 2009 | Maytag Dryers
Dryers Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
