Question about Sharper Image Ionic Breeze 3.0 Air Purifier
My ionic breeze quit working. It won't even turn on sometimes it will turn on for just a second the light will go on make a bunch of noise and shut off. What's wrong
  • vail8150 Jun 22, 2008
    Just stopped working entirely. No lights, no nothing working.
    I have cleaned it but no luck... :(
  • Anonymous Aug 01, 2008
    won't turn on
    Scholar:
  • 62 Answers
My Ionic Breeze GP did the same thing and got worse and worse until it would not turn on anymore.
The problem on mine is the micro switch that detects whether the collector plates are inserted or not, so it is part of the safety mechanism. There is a about a one-inch cylindrical piece of plastic on the front of the collector plate handle. This cylinder goes through a hole and pushes on the micro switch (actually a plastic cover over the switch.
On mine, it appears that arcing inside the switch caused it to get hot, deforming the plastic a little bit and apparently ruining the inside of the switch.
The following URLs describe the switch, but I have not found a retailer that carries it:
http://www.dicgroup.com/pdf/SM/SM5-01N.pdf
http://www.dicgroup.com/e-pro01-sm.html
Another of the same model switch is used in the back of the unit to detect whether the rear cover is on (over the UV bulb).
If I cannot find a replacement, I am thinking of either bypassing the bad switch entirely or swapping the switch from the back. Either way would defeat a safety feature so it's probably not a good idea, but I consider the switch for the back cover to be pretty much limited risk, so I might take that route.
Posted on Aug 02, 2008
  • martinmarty Aug 09, 2008
    I found a suitable replacement switch at Mouser Electronics, mouser.com. It is Mouser part # 101-1203-EV. The problem is that the lever is too long, so I cut it with my Dremel cutting wheel before installing.
    Mouser also has a similar switch, part # 101-1201-EV on which the lever is the correct length, however it has solder lugs instead of PC board legs.
    I ordered both switches and then made my decision about which to use after looking at them. The choices are either cut (shorten) the lever on the 1203 switch or enlarge the holes on the mounting board to fit the 1201 switch. In my judgement it was easier to cut the lever.
    The new switch is installed and the unit is working fine again.
Have you cleaned it lately? It will automatically shut off when it needs to be cleaned.
Posted on Jun 21, 2008
I have 2 ionic breeze air purifiers sharper image.(germical )
I have the same problem as gerardperez7. One of my germicidal light quadras won't turn the light on and doesn't appear to be cleaning the air at all. I even put a new light bulb in it and it doesn't fix the problem.
Dec 19, 2009 | Sharper Image Professional Plus Ionic...
Ionic Breeze - Cleaning Overdue light stays on even after unit has been cleaned
Hi.
The filter is damaged and may need replacement.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Nov 18, 2009 | Sharper Image Ionic Breeze 3.0 Air...
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Unit does not work even tho blue light shows its on
The bad news is that Sharper Image filed for bankruptcy this year closing all their stores. There unable to honor the warranties on the units and even recalled all Ionic Breeze units.
Here is a link as to what happened to the company:
http://www.aircleaners.com/sharperimage.phtml
You can still get parts for Ionic Breeze at this link:
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=0&ProductId=473&gclid=CKfhotf9_JYCFRxNagodHR10Yg
It could just need some new plates for it.
Nov 17, 2008 | Sharper Image Ionic Breeze 3.0 Air...
GP Professional Series Ionic Breeze - Simply Quit Working
Sharper Image models are no longer supported because they have been recalled since they were proven to be ineffective.
Here is a link about the Chapter 11
Here is a link for the EPA about ionizers
Jul 06, 2008 | Sharper Image Professional Plus Ionic...
No power.
there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch.
Jan 29, 2008 | Sharper Image Ionic Breeze GP (SI730) Air...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
247 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
