Question about Peg Perego John Deere Gator HPX Ride on Toy
Will not run checked foot pedal switch and is ok also intalled a new battery
    Genius:
  • Peg Perego Master
  • 1,508 Answers
First of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Posted on Jun 14, 2012
My Olympus RS25 foot switch stopped working.
Yes, you can assume that after 6+ years, the pedals have gone bad and you need new ones.
Jan 08, 2016 | Olympus AS-2300 PC Transcription Kit
Tractor will not start, when I turn the key it is dead.
check for faulty safety micro switches and wires on foot pedal, seat ,clutch etc.
May 19, 2015 | Toro Heavy Machinery
My gator just stopped can't get it to do anything
power goes from battery to foot pedal, then to shifter, then to motors. I'd check the shifter switch and make sure that its connected securely, if it is then disconnect one of the rear motors and try again, then reconnect and then disconnect the other rear motor and try again. If the problem goes away with one of the rear motors disconnected then that motor was your problem
Jun 12, 2014 | Peg Perego John Deere Gator HPX Ride on...
My foot pedal won't stop the machine from running when I release it.
I just fixed a Bernina foot pedal with this problem. There is a metal piece that presses down on a small switch when the pedal is released. The switch wasn't being pressed down hard enough to completely disconnect the power. As a result the machine kept slowly sewing when the pedal was released. I bent the metal piece down slightly with needle nose pliers so the switch would be fully pressed when the pedal is released. The hardest part was opening the foot pedal because there were no visible screws. I used a flathead screwdriver to pry the base off the foot pedal at the pivot points.
May 02, 2014 | Euro-Pro 9130 Sewing Machine
Foot pedal not working
yes, it is possible that the foot pedal can go out,, it would be a good
idea to have the foot pedal checked at a repair shop to see for
sure
Aug 27, 2012 | PfaFF Tiptronic 2040
The Rear lights work but neither brake light comes on when braking checked fuses they are ok. Can both brake lights go out at the same time or could there be a wiring problem?
The first thing to do is check the brake light switch under the driver side panel up a little where the brake pedal bends. This brake light switch is mounted under the panel so that a small plunger extends to where the brake pedal contacts it when the pedal is at rest (your foot off). This plunger is held in by spring pressure built into the switch and is in the off position. When you step on the brake, the pedal moves forward releasing tension on the switch spring turning the brake lights on. If the switch is stuck or jammed in the off position, no lights, if it is stuck on the on position, brake lights all the time and a run down battery.
This switch cost a couple dollars on the internet, but shipping makes it about ten bucks. You can buy one at an automotive supply "Auto Zone?" for about seven bucks. and it mounts to a bracket under that panel. This switch is about the size of your thumg with a two inch plunger.
Dec 29, 2010 | Dodge Stratus Cars & Trucks
Wont hold idle will start with foot depressing gas pedal will run with foot on gas but stalls when foot removed
Check and clean Idle air control valve. Make sure its responding to signal as well. Also make sure ther are no vacuum hoses disconnected. This may not be a "cure" but it's a good place to start.
Apr 14, 2009 | 2001 Jeep Grand Cherokee
Olympus AS-2000 Dictation Kit - Foot switch doesn't work on Vista
HTML clipboard Olympus AS-2000 is not Vista compatible, you need to upgrade your software, I am not sure which version you have, but I think its version 6 ? You need to upgrade your software from version 6 to 7 (free) and then from version 7 to Standard (also free ) . check your foot pedal if it's RS-23 ( check the back of it ) then you need a new foot pedal ( RS-25 or RS-27 ) , if you have the RS-25 or RS27 you are ok .
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
Hope this will help
Joseph
Feb 09, 2009 | Olympus AS-2300 PC Transcription Kit
Peg Perego John Deere Gator HPX Ride on Toy Logo
95 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
