Question about Sony KDF46E2000 46" Projection HDTV
I replaced to lamp on a Sony KDF 46E2000.The TV worked for 2 days then went off. The tv won't come but has 3 blinking lights now.I removed the new light and installed the old light. The tv will stay on for about 30 minutes.This was long enought to go into service mode. I have a code 1 on the lamp cover and lamp driver .Any help you could give would be greatly apprecited. Thanks
  • Sony Master
  • 1,230 Answers
I have not repaired this particular model. Some of the problems for refusing to stay on are....Your color wheel may have lost its RPMs and or the cooling fan may be running slow. It is essential the fan is running at high speed. Without proper cooling your set may shut down. The power supply to the fan may also need a capacitor and resistor replaced to sustain speed in addition to replacing this fan! And when you replace the lamp be sure you do not use your bear hands to install this. Use a pair of plastic gloves or a clean pair of cotton ones. The oils on your hand to the bulb will shorten its life. I offer food for thought.....Hope this will clue you in a repair. Thanks for asking!
Posted on Aug 01, 2010
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
6 blinking lights after changing replacement bulb
You have an open thermal fuse in the lamp housing. The fuse has an upgrade and is only accessible from the back of the TV>
Apr 15, 2009 | Televison & Video
Tv is shutting down then restarting.
How old is this TV, if its more then 2 years old and have not replaced lamp yet then its problem of weak lamp. Please replace its lamp and always purchase Sony original lamp for smooth TV function.
Mar 25, 2009 | Sony KDF46E2000 46" Projection HDTV
No picture or sound
3 times error shows that lamp is not installed properly or lamp cover is off / not fixed.
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Jan 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Sony KDF-46E2000 LCD Projection TV
4 flashes is a bad fan, 3 flashes is lamp door switch
Jun 29, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF46E2000 46" Projection HDTV Logo
277 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
