Question about GE GSH25JFR Side by Side Refrigerator
The refridgerator is not cooling - coils are not iced over. what should I try now? Both sides not working properly. This is a side by side model.
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
tut
Posted on Sep 30, 2010
First refrigerator stopped cooling, next freezer. Seemed like it was trying to defrost but their was lots of ice built up on coils. Jen-Air side by side, counter depth model number JCB2388ARB.
Causes of ice build up on coils:
Not enough freon (leak). Coil defrost heater not working (Coils on all freezers freeze up, but you should not notice). Coil defrost timer not working. Compressor thermostat not working (or end fell out of proper location).
:o).
Jun 04, 2011 | Jenn-Air JCB2388G Side by Side...
I have a Sub zero refridgerator 590, the refridgerator side is not getting cold, and it's icing up inside where the fresh foods are stored, yet the freezer is working fine. Please help
The freezer coils are iced up and that is blocking the sir flow to the fridge.... You have a defrost problem and that is causing the refrigerator to be warm...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
The refridgerator side of my side by side subzero is not cod enough. the coils are clean..what do I do now? the freezer portion is cold but is producing ice at a very very slow rate. the refridgerator is...
You probably have a leak in the evaporator and there is not enough refrigerant left to cool properly. Sub Zero has a 12 year warranty so You may want to replace the unit. You need to call a servicer to check it out.
Sep 22, 2009 | Refrigerators
Refrigerator side not cooling
The fresh food section is cooled by the freezer section by forced air supplied by a fan. If you have air flow, check the temp inside the freezer. It should be between 0 and -10. If not look inside your freezer and see if you have ice built up on the back panel. If so you have a defrost problem that is most likely a bad defrost heater, a bad termination thermostat or timer. If ther is no ice then check your fan under the refrig. If you can hear the compressor running it should be turning. If this all checks out then you have a freon system problem like. Low Freon pressure or a restriction.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have an admiral model HMG 67184 side by side and I can't figure out why my freezer section still works but doesn't get cold enough to make ice cubes and the other side doesn't work at all. I do have...
1. Get the Food out of the Ref and Freezer. Unplug the power cord from the wall.
2. The cooling coil is in the back wall of the freezer side. Working from inside the Freezer.
3. Remove the back plastic cover to expose the cooling coil. It's called the Evaporator coil.
4. Use a hair dryer to melt all ice off the coil.
5. Put it back together. It should work for 3 - 5 days now at least.
6. Put a thermometer in there. After 24 hrs. the freezer should be 0 to 10 degrees F. and the Ref. side 37 to 44 degree F.
7. Check the door gaskets for tight fit, using a dollar bill for a gauge.
Shut the door on the dollar and try to pull it out in several places.
If it ices up again in a week or two, you have a defrost heater problem. There is a electric heat strip around the cooling coil. This heat strip comes on about 10 minutes every 8 or 10 hours. This heater melts the ice off the coil. There is a clock timer device under the ref. that cycles the heat strip. You may have a bad clock, fuse device or burned out defrost heater strip. The cooling coil must be ice free to work properly.
Jul 06, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refridgerator not cooling
is it side by side or freezer on top/bottom...check to see if the fan inside the freezer is running when the compressor is running..also check to see if ice is covering the evaporator coils.. the freezing should be even with a thin layer of ice/ not partically melted..sometimes the ice forms in the vents and stops the air flow...to review...check and see if fan is working in freezer
check to see if vents are clogged......good luck!!
Apr 29, 2009 | Refrigerators
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
GE GSH25JFR Side by Side Refrigerator Logo
98 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
