Question about Mustang Rzt 50" Zero Turn Riding Lawn Mower
Need to replace the drive belt on a troy-built Rzt 50" Mustang mower, how do you remove the drive shaft belt to install the new belt?
4 Suggested Answers
  • 3911 Answers
SOURCE: On the Troy-bilt RZT 50,
have you considered removing the pulley from the top of the mandrel? might be easier to put the belt on by taking off a nut than breaking welds and rewelding when you are done. i do not have a lot of respect for troy bilt, but even they know belts have to be replaced at least once in the life of a product so there must be some less drastic way. have you troubled yourself to take a look under "support" over on the troy-bilt website?
Posted on Sep 11, 2011
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
  • 146 Answers
SOURCE: Put mower in reverse, turned it off and mower
There are safety interlocks on zero turn mowers. These prevent starting unless you have: 1. the handles in 'neutral' position 2. the brake on 3. the mower engagement (PTO) switch off 4. yourself in the seat.
Chances are one of these conditions hasn't been met. Since you were reversing when it happened, perhaps you haven't got the handles back to neutral position?
Posted on Jul 07, 2010
I have a ZTS7500 when i engage thepto or drive arms the mower dies
On my Cub Cadet RZT and my Troy Built RZT Mustang you have to turn off the Parking Brake before you can move the handles or the PTO button, also the parking brake has to be on before the starter will turn the mower engine over. Real Brain teaser at times
May 20, 2016 | Garden
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
Mower: Troy Bilt 42 Mustang Zero-turn mower: The
Hello Donna,
I would remove the battery and have it tested at a local parts store. It sounds like the battery to me.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 08, 2013 | Mustang Rzt 50" Zero Turn Riding Lawn...
How much oil goes in my Troy Bilt Mustang RZT 50"
at least one quart up to 2 quarts
May 23, 2012 | Garden
REMOVE 2009 RZT 50 VT CLUTCH
A impact wrench will do the job in 2 seconds.
May 07, 2012 | MTD LAWN MOWER PART # 603-04285 FRAME-RZT
When I turn the key on to start my Troy-Bilt RZT 50 zero turn mower, there is nothing. No ignition light, nothing. I have a new battery and I put a new fuse unit but still nothing. Help!
Do you hear a clicking sound???NO ?? Do you have the speed ?turning handles in the extrem OUT position? Is the ground cable connected to the engine block?? Is the Red cable connected to the + Positive post on the battery?? Is the BLACK cable connected to the - Negetive post on the battery?? Why did you need to replace the fuse? Is the battery charged??
If none of the above corrects the problem replace the ignition switch
May 02, 2011 | Mustang Rzt 50" Zero Turn Riding Lawn...
Why is my troy-bilt mustang 50 zero turn lawn tractor is smoking and burning oil?
it could need a oil change if it as some age to it could need a new ring set or a new overhaul and it my need a new plug ...
Aug 04, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Mustang Rzt 50" Zero Turn Riding Lawn Mower Logo
1,952 people viewed this question
Top Mustang Garden Experts
Dennis Key
Dennis Key
Randy Schumann
Randy Schumann
Randy Bower
Are you a Mustang Garden Expert? Answer questions, earn points and help others
