Question about Husqvarna Garden
The trimmer head stopped turning What could be wrong
Husqvarna 225L trimmer
the trimmer head stopped turning
What could be wrong
  • 252 Answers
Here is web site for parts
http://www.partstree.com/parts/?lc=husqvarna&mn=225+L+%281994-06%29
almost sounds like the driving drum engagement end has rounded off or the end of drive shaft broke off at either end , or the gear head end is broken / damaged
have a look at the splines on the output shaft on the gear head , check the plate that engages those splines too
physicaly take off the tube / shaft assy from power head and check drum and clutch rotating , check drive shaft end (s)
if ok refit tube / shaft assy ( make sure engaged properly)
tighten mount bolts - remove gear head from end of shaft, start motor and run see if shaft turns ok with some rev s if so
problem is in the gear head
check out website good site
cheers paul hope it helps
Posted on Aug 02, 2010
Drive head rotates counter-clockwise. Can't get it back into position. Use to be able to simply turn it back around. Can't now.
Husqvarna 128 LD Weedeater Repair Questions,... - Fixya
www.fixya.com > Forum > Lawn Trimmers & Edgers > Husqvarna
Recent Husqvarna 128 LD Weedeater questions, problems & answers. Free expert DIY tips, ... Drive head rotates counter-clockwise. Can't get it back into ...
HOW TO CHANGE HEADS ON HUSQVARNA 128LD - Fixya
www.fixya.com/support/t20975899-change_heads_husqvarna_128ld
Oct 25, 2013 - Question about Husqvarna 128 LD Weedeater ... SOURCE: MyHusqvarna 128LD primer bulb .... Drive head rotates counter-clockwise.
Weed eater bogs out at full throttle - Fixya
Oct 07, 2015 | Husqvarna 128 LD Weedeater
Used 323l husqvarna weed eater. Head stopped spinning. How do I fix it?
you need to find what stopped the head. Did debris wrap around the head / shaft and stop it or did the clutch fail. Try to remove the trimmer head and determine if the drive shaft is spinning.
Jun 30, 2014 | Husqvarna 323L
Husqvarna trimmer starts but head doesn't spin, made a high squelling sound but continued to cut, the next time I went to start it the cord pulled quickly then caught started turned briefly then quit while...
Make sure there is not debris stopping the head. Try removing the trimmer head and make sure the shaft turns freely. If it does the problem could be either the engine or clutch.
Jun 25, 2014 | Husqvarna 28cc Gas Line Trimmer
225l husqvarna trimmer stops after 5-10 minutes,no spark
There was two different units on this machine, a Phelon unit that ran with a three magnet flywheel, and a Walbro unit that ran with a two magnet flywheel, they are not inter changable, neither of these units were the best quaility, so you cannot rule out the new unit is also faulty, do a quick test to rule out the switch and the wireing by removing both wires from the unit and run the machine, if it keeps running your problem is with the wiring or switch, if it still stops you need to face the fact that the unit needs replacing.
Dec 15, 2012 | Garden
How do you keep the shaft from turning when working on it
If you're refering to working on the cutting head without the shaft turning then you should be able to lock the cutting head to remove it. There is a small hole in the top of the gear head that you need to put a small rod in to jam the head from turning.. this inturn will also stop the drive shaft from turning.
Sep 03, 2012 | Husqvarna 28cc Gas Line Trimmer
I have a husqvarna 125L trimmer. I need to get the starter cup off. It's held by a coupling nut. How do I lock the shaft and which way do you turn the nut (left or right hand thread)?
Its a clockwise thread to undo the bolt,you need to put a small bar in the gear head tho to stop it turning. You may have the type of gear head that you hold the top of the shaft with a spanner
May 03, 2011 | Husqvarna Garden
225l weed eater loses power when trimming won't hold power trimmer right under year old
Air leak in the system, could be a damaged fuel line or a damahed diaphragm, blocked air filter.
Apr 19, 2011 | Husqvarna 28cc Gas Line Trimmer
How to change blades
Use a large pair of pliers to hold the turning metal ring above the T35 trimmer head. I used a medium-sized pair of Channel Lock pliers. Then, turn the trimmer head counter-clockwise and it should unscrew from the mount. There's no need to open the trimmer head for this operation. Then, follow the parts diagram in the trimmer user manual to install the blade parts in the right order.
Mar 16, 2009 | Husqvarna Garden
Garden Logo
573 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
