Question about LG Electronics LRM-519 Digital Media Recorder
I CAN'T GET GUIDE TO DOWNLOAD.I DO HAVE AN IP ADDRESS THAT SHOWS UP IN MY SYSTEM SETTINGS AND I'VE TRIED CHANGING MY CONNECTION TO WIRED INSTEAD OF WIRELESS THAT DIDN'T WORK. I EVEN TRIED TO RUN THE SETUP WIZZARD AGAIN. I AM NOT GOING THROUGH A CABLE BOX I AM JUST HOOKED UP VIA STANDARD CABLE. I GOT A CONNECTION ERROR CHECK NETWORK CONNECTION.TRY AGAIN LATER. LAST SUCCESSFULL DOWNLOAD WAS 7-9-10 ANY THOUGHTS ON WHAT CAN BE PROBLEM? THANKS, J C
  • LG Master
  • 5,586 Answers
Can you ping the recorder from your computer on the network? In Windows, Start > All Programs > Accesssories > Command Prompt. At the prompt, type ping and the IP address of the recorder from the Start menu, Settings > Settings > System Information page. Press Enter after typing all 4 sections of the IP address. If you can't ping the recorder, I'd look for bad cables and connection issues with your router or modem (broadband or dial-up). Depending on your devices, you may be able to find a log file of the downtime.
Remember the guide takes a while to download, so if you are losing connectivity that could cause the failure. If you have your recorder, router and modem on an uninterruptible power supply, double check that they are plugged into the battery protected outlets and that the battery has sufficient charge to maintain the devices. Older UPS batteries will not keep a system running. Also check if your provider has been having downtime issues.
Check your Microsoft Program Guide subscription status.
I hope this helps.
(Upstream downtime issues have sometimes been a problem for me. I have created a batch file to check if my router, DSL hub (the point where my local loop connects to the ISP's network), DNS servers and regularly accessed sites are available. This started as a text file then I did a file save as "pingisp.bat" (with the quotes). The text file has several lines: each starts with ping and either the IP numbers for each device (or location) or address of a site. The browsing to the router status page gave me most of the IP numbers I needed. Any site that is not connecting gives a site unreachable message for several attempts. Working sites report how long it took for the packet to return.)
Posted on Aug 02, 2010
Why would the ethernet internet connection not work - but the wireless connection would?
You might be out of IPs in the router. There's a setting where you can allow a set amount of IPs (like 5 or 10 devices). If the IP is 169.x.x.x it means the TV didn't get an IP and the laptop working means that it already has an IP designated in the router.
Anyway, go into the router settings and look for the "IP scope" and increase it by 5-10 and save it, then try again.
Usually home routers have a default setting and all devices get a similar IP (wireless and wired alike), so I would venture to guess that you are out of them, what with cell phones, laptops, tablets etc.
Aug 10, 2014 | Sharp Aquos Televison & Video
Will not assign IP address
Steps for these found on http://support.xbox.com/en-US/xbox-live/connecting/error-cant-obtain-ip-address-router-modem-978976 and include
1. Restart modem and router2. Check wireless password3. Configure IP settings manually 4. Set an alternate MAC Address5. Turn on DHCP.6. Bypass router entirely and connect instead to the modem using a wired connection
Aug 09, 2012 | D-Link DGL-4500 Wireless Router
I have a wired connection that i share thru my wireless internet.i can get on the internet with my computer.i have the connection being shared but everytime i do the test i get a IP address but internet...
have you restarted the modem, and then plugged in the wireless connection afterwards, you may need to configure your system to have a static ip address, this may help, here is a guid to help guide you.
Mar 29, 2011 | Video Game Consoles & Games
How come the http://192.168.123.254 address isnt working?
Find your computer's IP address : Windows 7, Vista, and XP, using the command prompt
  1. Click Start, and then select All Programs. Note: If this doesn't match what you see, refer to About navigation settings in Windows.
  2. Click Accessories, and then Command Prompt.
  3. At the command prompt, enter: ipconfig The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx (i.e., 156.56.27.32).
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
  1. In the system tray, click the network connection icon and select Open Network and Sharing Center.
  2. To view the IP address of a wired connection, click Local Area Connection. To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
  3. Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
  1. From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
  2. To view the IP address of a wired connection, click View Status to the right of Local Area Connection. To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
  3. Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
  1. From the Start menu, right-click My Network Places, and then click Properties.
  2. To view the IP address of a wired connection, double-click Local Area Connection. To view the IP address of a wireless adapter, double-click Wireless Network Connection.
  3. Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the 192.168.123.xxx range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 26, 2010 | Asante FriendlyNET FR1104-G Wireless...
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
When i try to get my ip password it shows up as
Is your X-box wireless ? If it is wireless and you are trying to connect to the wireless network, then make sure that you have all the wireless settings correct. IF the network is secured then make sure that you have the correct network key.
You tried manual IP address. The manual IP address should be in the range of the router IP address.
Click Here
for more information about the router and x-box
Feb 28, 2010 | Microsoft Xbox 360 Console
Linksys WRT54GX4 loses internet connection
Not a problem, you have to consider maybe other devices and or networks competing/interferring with your network. If you know how to enter the Linksys router menu I would 1. change the frequency the router operates on 2. change the channel the router will use 3. change the default password to something else besides the default.
All of the settings for your router out of the box are at default, wonder how many other people are running the same thing in your neighborhood? I always change from the default, you may also be receiving interference from devices using the same freq/channel as your router. Changing these will eliminate those possibilities.
Don't forget to encrypt your network, that is most important.
Jul 15, 2009 | Linksys WRT54GX4 WIRELESS 802.11G...
Belkin 54G works OK with wireless connections but not wired!!!
In the end I replaced the ethernet cable with another one and it worked!!! That simple....................
Mar 30, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
LG Electronics LRM-519 Digital Media Recorder Logo
130 people viewed this question
