Question about Fossil Watches
I have a Fossil (AM-3857). I have trying to find the correct battery size for this wath. The original battery has was not with the watch when I received it..
SOURCE: Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Posted on Aug 24, 2007
  • 3 Answers
SOURCE: Fossil Big Tic Watch - setting the correct time on the digital display
The watch is scrolling through the seconds, and is not something that needs to be set. If there is a bottom it is only there to change the way the seconds are scrolling? There are many different types of these, but most are just standard seconds.
Posted on Apr 06, 2008
SOURCE: Fossil watch
The watch has two batteries. underneath the large disk battery is a smaller button battery. replace the small button battery and your watch should start up again.
Posted on Apr 16, 2008
SOURCE: Changing the battery for my Fossil Watch
You have to have a tool to unscrew the back of the watch. I figured this out the hard way. I suggest taking it to a jewler for after I replaced my battery, the stinking thing still did not work. This sounds like a commom problem as I read more about them. Hope this helped.
Posted on Dec 24, 2008
escapement
  • 2334 Answers
SOURCE: Trouble sizing Fossil Watch CH-2506
Those arrows inside of the watch band are showing direction for pins or clips to come out. If you have two arrows in opposite directions on one link, that means there are two pins or clips and each one must be extracted from arrow pointing side.
If there is only one arrow on the link- there is only one clip or pin and must be extracted the arrow pointing way.
Some watch bands are held together by very specificly made clips or pins. In this case you will need a special tool to extract them.
Posted on Jan 02, 2009
Which 3 battery sizes go in fossil BG2131 watch?
Take your Fossil watch to a jeweler who will identify the battery type and may even be persuaded to install replacements. All for a reasonable sum.
May 24, 2018 | Fossil Watches
Fossil fs4141 battery size
  • Remove back
  • Find battery location. Note mounting arrangement for later new battery installation
  • Identify battery type (not size)
  • Obtain replacement battery
  • Install in correct position with correct polarity
  • Check operation
  • Install back
  • Set time, etc.
Sep 12, 2016 | Fossil Watches
Need watch battery size for a fossil blue watch model number Tl-5073
  • Remove back
  • Find battery mounting. Note for later battery installation
  • Read battery type (not size)
  • Obtain exact battery replacement
  • Remove old battery; install new
  • Check operation
  • install back
  • Set watch
Sep 09, 2016 | Fossil Watches
The watch don't show the Hours on display
Google (fossil)(PH1085)(manual) without parens for instructions.
May 28, 2014 | Fossil Watch PH1085
Battary size for fossil blue watch bq8775
Thanks for contacting Fossil.
The only way to know the battery size is to pull out the old one. It might also be in your manual. It might be on the outside of the watch.
If battery is missing, then you will have to measure the cavity and match it against a battery chart.
Best wishes.
Aug 26, 2010 | Fossil AM3784 Wrist Watch
I don't have the original battery to my watch, and am looking for a replacement. The watch is a Fossil Arkitekt FS-3031
<P>Thank you for contacting FixYa.</P><P>Unfortunately, unless it is stamped on the back of the watch, or it is in your manual, there is no way of knowing the battery that goes in any watch without the old one, or very accurate sizing of the area it goes in. You can try to contact Fossil via this link:</P><P><A href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</A></P><P>Best regards.</P>
Aug 24, 2010 | Fossil Watches
My Fossil watch worked when I took it off, it just needed a new battery. Now, I tried to replace the battery, and it won't work
Check that the battery is in the correct way up.
Try cleaning the battery with surgical spirit.
If these steps fail, take it to a watch shop.
If this also fails, find you nearest Fossil dealer (Fossil/customer care - store locator
Feb 11, 2010 | Fossil AM3784 Wrist Watch
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Fossil watch battery
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi SDMIKED
I suggest you consult your authorized Fossil Dealers for the correct battery replacement of your watch.
Thank you.
Nov 11, 2007 | Fossil AU4003 Wristwatch
Watches Logo
257 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
john h
Are you a Fossil Watch Expert? Answer questions, earn points and help others
