Question about Vacuums
My dehumidifier, model # HD 456E, : motor runs continually, no water being pulled, bin is always dry. Also, how do I set the humidity/temp control to keep my basement dry? D
  • dfrazier06 Aug 02, 2010
    Thank you for giving me the percents for best humidity levels to aim for in a home basement. D
  • Vacuums Master
  • 3,083 Answers
First, check and clean your filter, since a clogged filter could be your problem. Here's suggestions for the humidity levels from answerbag.com:
On One Hand: Low Humidity Levels According to an Associated Press article, "Wrong Humidity Turns Your House into a Hassle" published in USA Today, "if the humidity is too low, it can cause cracks in both your fingers and the house's drywall."
On the Other: High Humidity Levels A humidity level above 50 percent can produce mold, attract pests and may cause damage to your home by staining walls or causing paint and wallpaper to peel.
Bottom Line Aim to keep your humidity level between 40 percent and 50 percent to achieve the best results.
Good luck, and hope this helps.
Posted on Aug 02, 2010
How to order / replace motor exhaust foam filter?
Hi, it's Allie from Crucial Vacuum!
Maintaining your unit's filter clean and clog-free is crucial in keeping your unit working properly. Your Dyson DC39 has a washable and reusable pre-filter, part number 923413-01.
Washable filters are recommended to be washed after every 1 or 2 uses and replaced every 3 to 6 months, depending on the use of your unit.
First, make sure your unit is 'off' and unplugged. Remove the dust bin by pushing the button next to your unit's handle and remove the filter from the bin. Wash your filter under running lukewarm water until the water runs clear. Allow your filter to air dry for 24 hours before placing it back into your unit. Do not use any soaps or detergents and only dry your filter naturally. Placing your unit in a dishwasher and/or dryer may damage the filter.
Having a spare filter is a great idea to have while washing the unit's filter.
You can purchase direct your replacement filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc39-pre-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 04, 2014 | Dyson Vacuums
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Our dehumidier is running but there is not water in the tray???
If the machine's compressor runs when you switch it on, then turn the machine on maximum and let it run for an hour or so. Then check the coils in the back with your hand. If they are not getting cold at all, then there is a significant problem with the refrigeration process in the unit. It may have developed a leak and allowed your refrigerant gas to escape, or there may be another internal problem with the compressor. Either way you would need to have it serviced by a fridge technician, or more likely just replaced with a whole new unit since both options can potentially cost about the same.
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. If your dehumidifier is freezing up then that probably means it is actually working well. The humidity level in the room may be relatively low and you probably have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit. Remember to also clean the air intake filter while you are at it.
The ambient temperature in the room may also be a bit too low, so you can try adding some heat to the room if necessary. A dehumidifier will not work properly if the ambient air temperature is too low. Basically, the warmer and more humid the room is, the better they work.Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where the air is warmer.
You can click on the following link for a general operating and troubleshooting guide with additional tips on effective dehumidifier operation:
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 29, 2011 | Vacuums
I just purchased a used portable air conditioner, a danby dpac120068. It is not producing any water when in dehumidify mode. Also, it seems as though the air conditioner is on even when in dehumidify...
The A/C will be on when dehumidifying... that's how it does that...
If it is not collecting water, it is probably because the humidity is too low in the house already...
I would give it more time....
heatman101
May 25, 2011 | Vacuums
It turns on and shuts off just like it is supposed to but the thing is bone dry. The humidity is at 56% so it should be able to dehumidify. It is just a little over 1 year old, help me please?!!
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. If your dehumidifier is freezing up then that probably means it is actually working well. The humidity level in the room is probably just relatively low and you probably have the unit turned up too high for the conditions.
Joe.
May 24, 2011 | Kenmore Vacuums
Our dehumidifier(Simplicity Model 43-54006 ) all of a sudden has stopped pulling water out of the air. It runs but it does nothing. Any suggestions? Thank you.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 02, 2010 | Vacuums
Motor won't start
Most times this will be caused by one of 3 items, the cord, the switch or the carbon brushes in the motor. Inspect the plug area on the cord for strain twist it gently and look to see if the cord appears a bit white where it meets the plug or if the cord appears crushed just before the plug.
Also inspect where the cord meets the body of the vac for the same signs of wear or any locations where it may have been caught in the power head , etc.
If you have test meter, check for resistance change at the plug while twisting and finally try the same twisting with the vac plugged in if necessary but keep your fingers back from the plug in case the cord blows... gently twist and pull slightly to see if the motor continues to run.
Most often when a switch fails it just dies and doesn't become intermitant... so with a meter it will generally test good or bad , nothing else..
Sometimes on a well worn vac when the motor doesn't start the carbon brushes in the motor have worn down. A heavy duty motor such as the Rexair can often be rebuilt if brushes are required.
If you turn the machine on and bump or jolt the side of the body as if to spin it, you can often "trick " the motor into starting. If this happens it is most likely a carbon brush issue , if not time for a new motor.
Rainbow/Rexair machines have a fairly good motor however because of how they run drawing moist air through they often rust as they age. This is a tedius rebuild and best left to a pro shop with parts on hand if requiring brushes. Most shops will simpley scrap a worn motor if rusty and replace it completely.
Before you spend big $ on a repair or replacement....
One last thing....... pull the exhaust cap at the back of the vac. You will seen fine powder dust and residue.Wipe your finger across it. This is what the Rexair releases into your home each time it runs, but you don't smell it because it comes out in the form of humidity...like after a spring rain.
That same humidity is rusting your motor gradually year by year. Although this motor has a long life span, consider that you have been breathing dirty humidity as it runs. If you put orange drink crystals in the water bucket and run the vac, the exhaust air would smell like orange juice,... so what is in the tank comes out in the air, including your dirty water.
Most Rexair owners buy thinking they are helping to reduce allergins.. yet what is on that exhaust plug proves otherwise. If your home is essentially carpet free and you are vigilant maintaining and rinsing the bucket, you might consider rebuilding this vac.. Otherwise consider a good High end European vac like a SEBO,MIELE, Nilfisk etc for better filtration and reliability
Oct 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Panasonic MC-E4013 has lots of **** but won't pick up. Drive belts and brush roller go round OK, Any ideas?
There are a few things to check.
The Twin Bin model could have clogged filters, So you'll have to depress the button on the top and check that the first top filter isn't clogged, then check the removable black filter and check that it isn't clogged with dust. Once these have been removed ensure that the mesh filters are completely clear. Although Panasonic dont suggest it, you can wash the top grid white filter and the black filter but you must ensure that both are dry before installing them. Low temp tumble dry in a pillow case will get the sponges dry in around 10 to 20 minutes but dont use a high temp as the plastic grid will melt! The mesh filters can be cleaned using the on board upholstery brush. Failing that use a paint brush to dislodge any clogged dirt - the worst for cutting suction is the powdery greyish white powder which always clogs the mesh filters.
Then before putting everything back, take the bottom hose out of the front by unhooking it before putting the bin back on. Remove the sole plate and the whole tube should be able to come off although you may need to unscrew the holder at the soleplate area which holds the bottom hose to the bottom of the cleaner. Once that is done the entire hose should come off free and by sticking a blunt stick down this hose slowly, there may well be a clog.
This model and the rest of the Twin Bin series aren't particularly well designed. Ive had two models from Panasonic over the years, both of them being the Twin Bin design uprights (MCE 4003 and MCE 4103) which still have the same inherent problems of pick up when the filters or hose gets blocked. The beauty of the Panasonic however is that the hose handle can be removed by pushing in the lugs and getting around the machine for maintenance is easy but time consuming.
Remember that you do have two drive belts on this machine so make sure the motor pulley belt to the drive belt is secure.
Hope that helps!
Mar 21, 2008 | Vacuums
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
