Back to:
Tags:
Fuji FinePix E510 Digital Camera
USB Message keeps flashing
posted by KC77 on Apr 25, 2008
Whenever i turn my camera on and am about to take a picture, the USB message comes up on the screen, as it would when I plug it into the USB port on my laptop when I want to transfer the photos onto the computer. As a result, I cannot take any photos. When I tried to plug the camera into the USB port (via the cable) to my computer, the USB message comes up and then disappears and my computer says it cannot recognise the device being plugged in!!! Help!!!
I have the same problem except sometimes it decides to work and then if I switch it to play mode it seems to fall into the problem again, with just the USB message up and I can't change anything. I can connect it to the computer without a problem but it doesn't help? Any ideas???
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 25, 2008
Not Rated (0)
mangoeater2
Rank:Guru Guru
Rating: 86%, 124 votes
Do a Google search with the following string:
(Brand Name) (Model Number) +driver
Download and install the latest drivers for your camera, this should correct any software problems in your camera. The problem with the computer may be related to the software problem in the camera.
Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on USB Message keeps flashing:
I don't want to Accept this solution
Can you Help with these Digital Cameras problems?
I've replaces the batteries several times and the camera...
Half of lens cover in front of the lens has fallen off....
My viewer turns purple pink and green and wont show a...
i plugged my camera into my USB and then copied the pics...
how do i reduce the resoultion can't email or upload...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
