You meant the DV4,s, VGA jack works plugged in to any VGA real monitor ,right.
well then the flashlight tests works on the local screen.
1:yes, then the CCFL black lamps are bad, or the DC/DC inverter cards is bad,
2: no? then screen new is wrong or the main chip driving is bad or the cable driving the screen is bad.
what did the old screen do??? when broken.
its only 5 parts, there. (one is bad)
LCD
cable
ccfl tubes
inverter
and the driver chip (mobo bad)
BIOS dead,,local,
now lets do, carbon dating (its should be first, see why )
dv4-1540-us
2012 year laptop? it seems. no longer suppored by HP.
retired, and legacy status now.
This PC does not have the 2008 solderballs from H3LL problems.
what does this DO? this is test 1, always, on all CCFL back lamps
like yours. has. !!!
http://www.pcdied.com/monitors.html#flashlighttest
here is what must work if the flash light fails. inverter CCFL
https://www.ebay.com/itm/HP-dv4-2164us-Inverter-429-1/302624527851?hash=item4675d3d5eb:g:HawAAOSwfZ1WbIPr
SOURCE: HP L2000 Screen DIM
Might be the brightness. Check if there are is a key combination for adjusting brightness.
SOURCE: Trying to scan, but keeps on saying "USB not connected" BEWARE SPAM NUMBER 1-800-532-4187
I had the same problem. The thing is I was pressing the scan button on the printer and getting the lovely "USB not connected" message. However, if you open the printer icon in the dock (Mine is "HP Photosmart C4200 series") and click the Scanner button in the upper right hand corner, then click "New Scan," voila! presto! and all is right with the world again.
Yes, it is obnoxious that HP made a defective scanner button, and I may download the driver again when I get a chance. But yay for quick fixes!
SOURCE: HP Compaq Presario V5000 LCD Problem
I have the same problem. I thought the problem was due to a loose cable so I opened the computer up only to find out the cables are all good. I still haven't found a solution
SOURCE: connect computer HDMI to Projection TV HDMI to watch web TV
use a s-video cable or a monitor ext cable and use fn+f4 to switch
pc mon to ext mon.
n.b. f key is usually f4 , models vary.look for square icon on f key.
fn+ that key; thats fn and say f4 pressed together.
