Question about Poulan Garden
Poulan 2ooo chainsaw not pumping gas to carburator how to fix
    Brigadier General:
  • 4,088 Answers
Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. Remove the carburetor, clean it inside and out with spray carburetor cleaner. Check the lower chamber diaphragm for flexibility and no damage. Check the impulse passage that comes from the crankcase, through gaskets and heat insulator, to the base of the carburetor. Does the primer bulb pump fuel into itself after several pumps? Hope some of this helps!
Posted on Aug 02, 2010
How to adjust carburator on 42cc poulan chainsaw engine?
One full turn out on low and high side for the initial start after rebuild.
Sep 03, 2014 | Poulan Garden
Need diagram how to reinstall carburator on poulan 295 pro chainsaw
partstree.com or jacksmallengines.com I dont know if there ever was a service manual. I havent seen one
Mar 25, 2014 | Garden
Poulan 3816, back fires through carburator, wont start.
water in the gas or carb needs to be removed and taken apart and cleaned
Feb 20, 2014 | Poulan/Pro 3314 3416 3816 3818 40184218...
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need a routing of the fuel lines from filter to, primer-in, primer-out, to carburator, out of carburator, back to tank. this is on a poulan chainsaw, 2550. Mod 952-05138. please respond.MARRY CHRISTMAS.
There are two holes in the fuel tank, it does not matter which line goes to which hole. The lines should run as follows: One line from the tank should have a filter on it, connect this line to the primer bulb and put a mark on it with a sharpie. Another line should run from the bulb to the carb, and the last should run from the carb back into the tank. After they are all in place, pump the bulb and watch the gas in the marked line. If gas is flowing from the tank through the marked line into the bulb and on to the carb you are done. If gas is flowing towards the tank in the marked line or not at all reverse the two lines on the bulb and you're done.
Dec 17, 2010 | Poulan Garden
Poulan 46cc has very little power
you need to adjust the gas an air on those two little screws on the carburator
Feb 03, 2009 | Poulan Pro Chain Saw 46cc 20"
I just replaced the piston ring on my poulan chainsaw it now has good compression but im not getting any gas to the piston area and if i shoot starting fluid to it. it dont even hit and try to start. i...
the engine is not sealed properly
check the gasket(seal glue)at crankshaft and other gaskets
check the carburator,clean it,inside there is a fine gas filter,check the needle,the diafragm,the fuel pump,the gas tube from the gas tank and the gas filter from inside the tank.
regards Mihai71
Nov 26, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
93 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
